Cell Phones Logo
Posted on Dec 08, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Unlock samsung gem - Samsung Cell Phones
Computer Repairing
Level 3:
  • Samsung Master 14,641 Answers
  • Posted on Dec 08, 2012
Computer Repairing
Samsung Master
Level 3:
Answers
14641
Questions
0
Helped
719340
Points
53082
Dear Brother;
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Where is the relay for the door locks on a 2007 ford focus
Doesn't have any relay's for the door locks . The (GEM) generic electronic module controls the door locks . Your best bet , take it to a qualified repair shop.
The Door Lock Function When a door lock control switch is moved into the lock position or a door lock cylinder is rotated to the lock position, a ground is provided to the lock circuit input to the generic electronic module (GEM). The GEM then provides 12 volts to one side of the door lock actuators contained in the door latch assembly and simultaneously grounds the other side of the door lock actuators. This completes the door lock actuator circuit, causing the door lock actuators to rotate a cam assembly, which then locks the doors.
The Door Unlock Function When a door lock control switch is moved into the unlock position, the door lock switch grounds the unlock circuit input to the GEM. The GEM then provides 12 volts to the opposite side (relative to locking the door) of the door lock actuator(s) contained in the door latch assembly and simultaneously grounds the other side of the door lock actuator(s). This completes the door lock actuator circuit, causing the door lock actuator(s) to rotate a cam assembly in the opposite direction, which then unlocks the door(s).
Generic Electronic Module (GEM) Diagnostic Trouble Code (DTC) Index DTC Description Source Action B1300 Power Door Lock Circuit Failure GEM Go To Pinpoint Test D . B1309 Power Door Lock Circuit Short to Ground GEM Go To Pinpoint Test D . B1310 Power Door Unlock Circuit Failure GEM Go To Pinpoint Test D . B1341 Power Door Unlock Circuit Short to Ground GEM Go To Pinpoint Test D .
Have a qualified technican diagnose the problem .
What are the animal jam gem codes?
Below is the most recently updated list of codes available on animal jam in 2014!
kama - 500 gems
thanks - imprisoned phantoms
adventure - 500 gems
ngexplorer -1000 gems
friendship - 500 gems
tigris - 500 gems (thanks fish301!)
ganges - 500 gems (thanks ARCTICKWOLFGIRL!)
zambezi - 500 gems (thanks ARCTICKWOLFGIRL!)
chimbu - 500 gems (thanks Nikola!)
nile - 500 gems (thanks Lucas!)
drawing - 500 gems
Alphas - 500 gems
bemybuddy - 500 gems
shadows - 500 gems (thanks Abby!)
explorer - 100 gems
ajbday3 - Animal Jam 3rd birthday cake
10million - 10 million banner
Pattern unlock
Attempt hard reset and wipe data and cache Vol up+home+switch off button
95helpful
13answers
I want 100,000,000 gems on dragon city
i want 999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999 gems
How do you unlock a Samsung gem
There are many methods for unlocking mobile phones, that is through software, codes,calculator,some tools , hardware and all ,but in that codes are best one,because it is easy to understand the instructions and enter into your mobile ,just give your IMEI number, country & network lock ,then you can get the unlock code..........
For the good place to get the unlock code for your mobile phone, Just visit this site Simpleunlocking.com , It provides the step by step instructions and simple methods for unlocking mobile phones at a safe way...........
I have a 2000 ford mustang. Suddenly my keyless entry remote stopped working. I replaced the battery and turned the off and on 8 times and the locks cycled. after which i pushed the unlock but nothing...
The keyless entry system is controlled by the (GEM) - generic electronic module .
Keyless Entry The electronic door lock system has two main components:
  • generic electronic module (GEM)(14B204)
  • keyless entry remote transmitter (15K601)
  • NOTE: Battery power and ground must be remove before disconnecting the GEM connectors to avoid setting false codes.
    Power Locks Operation The power locks feature allows the customer to lock and unlock the doors via momentary switches located on the driver and passenger door. When the GEM detects a momentary press of the driver or passenger lock button, the GEM will supply power to the driver or passenger lock actuators for approximately 250 ms from relays internal to the GEM. When the GEM detects a momentary press of the driver or passenger unlock button, the GEM will supply power to the driver or passenger unlock actuators for approximately 250 ms from relays internal to the GEM.
    Remote Keyless Entry Door Locks Operation The remote entry feature allows the customer to unlock the driver door, unlock all doors, and lock all doors using a valid remote transmitter as long as the ignition switch is not in RUN or START. The driver door is unlocked whenever the GEM detects a valid remote transmitter unlock transmission. All the doors are unlocked when the GEM detects a second valid remote transmitter unlock transmission within three seconds of the first transmission. All the doors are locked when the GEM detects a valid remote transmitter lock transmission. If the GEM detects a second valid remote transmitter lock transmission within three seconds of the first transmission, the doors will lock again, the horn will sound for 20 ms and the parking lamps will flash for 200 ms to indicate the doors are locked. If the GEM detects the driver or passenger door is ajar during the second lock transmission, the doors are locked again and the horn is sounded twice. If the GEM detects a valid remote transmitter lock transmission within three seconds of detecting a valid remote transmitter unlock transmission, the GEM will lock all the doors
    • The doors do not lock/unlock using the remote transmitter
    • Ignition switch.
    • GEM.
    • Remote transmitter.
    • Remote transmitter batteries.
    • GO to Pinpoint Test C .
    You followed the program instructions to the letter ? Programming -Keyless Entry Remote Transmitter NOTE: All keyless entry remote transmitters (15K601) must be programmed at the same time.
    NOTE: All previous transmitter identification codes (TIC's) will be erased when programming mode is entered.
    NOTE: To program (or reprogram) the keyless entry remote transmitters into the generic electronic module (GEM)(14B204), perform the following steps.
    1. Turn the ignition from OFF to RUN eight times within 10 seconds, ending in RUN. If the GEM has successfully entered program mode, it will lock and unlock all the doors.
    1. NOTE: The first TIC must be entered within 7.5 seconds of entering the program mode and additional TICs must be entered within 7.5 seconds of the first TIC. The programming mode is exited whenever the timing constraints are not met.
      Press any button on a keyless entry remote transmitter, and the doors will lock and then unlock to confirm that each keyless entry remote transmitter has been programmed.
    1. If the door locks do not respond for any keyless entry remote transmitter, wait for several seconds and press the button again.
    1. Turn the ignition switch to the OFF position, or wait up to five minutes after step 1, to exit program mode. If a keyless entry remote transmitter has been programmed (or reprogrammed), the GEM will lock and unlock all the doors one last time.
    1. Take an have the vehicle checked for DTC'S
B1396 Power Door Lock Circuit Short to Battery GEM GO to Pinpoint Test B . B1397 Power Door Unlock Circuit Short to Battery GEM
Unlock a samsung gem
Well if you are tied to a particular network all you have to do is to unlock your phone to use it any other GSM network. You can get the unlock code through online. Give your IMEI number & get the unlock code for ur mobile .............You also get through online..........I will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
Sep 01, 2011 • Cell Phones
We have a 2001 Ford Escape with a small problem. The remote key fob locks the doors and unlocks the doors but the lights don't flash anymore when you lock the door. The horn also won't honk after hitting...
I think you need to reprogram the module, you deleted the horn chirp and light flash confirmation. he dealer can reprogram for you.
Customer Preference Items NOTE: If using the WDS, select Module Configuration and Programming, then follow the screen prompts.
NOTE: Make sure module is listed as supporting customer preference items and supports the specific item to be configured in the Module Configuration Index in this section.
  1. Select Service Bay Functions on the diagnostic tool.
  1. Select the module that contains the customer preference item to be programmed. Refer to the Module Configuration Index in this section.
  1. Select Customer Preference Items on the diagnostic tool.
  1. Select Module Option Content.
  1. Select the item to be enabled or disabled.
  1. Enable or disable the item as necessary to reflect the customer preference.
Principles of Operation
Power Door Locks
The generic electronic module (GEM) controls the power door lock and keyless entry system. Lock and unlock operation is achieved through the use of internal relays in the GEM. The relays are all door lock, all door unlock and driver door unlock. The normal path of the relays is to ground.
Pressing the door lock control switch to lock or unlock sends a ground signal to the GEM. The same GEM pin is used for unlock and lock input. The unlock signal is a direct connection to ground. The lock signal is altered by an internal resistor in the door lock control switch. This varied resistance identifies lock or unlock command to the GEM.
The door locks can also be controlled by the door key cylinder switches. For the liftgate door lock switch, turning the key to lock or unlock sends a ground signal to the GEM. The GEM will then ground the all door lock or all door unlock relay supplying voltage to the actuators. Turning the driver door key cylinder to the lock position sends a ground signal to the GEM. The GEM will then ground the all door lock relay supplying voltage to the actuators. Turning the driver door key cylinder to unlock sends a ground signal to GEM. The GEM will ground the driver door unlock relay and supply voltage to only the driver door actuator. If a second unlock ground is received within three seconds of the first, the GEM will ground the all door unlock relay supplying voltage to the passenger door actuators (if 2-stage unlock is equipped).
Keyless Entry
The keyless entry remote transmitter sends a signal that is received by the GEM internal antenna. Depending on the signal received, the GEM module will ground the appropriate internal relay and lock all doors or unlock the driver door. If the unlock signal is received again within three seconds of the first unlock, the GEM will ground the internal all door unlock relay unlocking all doors. The lock and unlock relay output to the actuators is controlled by the GEM, the same as power door lock operation from the control switch.
If the signal received is for the panic button, the GEM will cycle ground to the park lamp relay coil and horn relay coil. The park lamps and horn will continue to cycle until the panic button is pressed again or the ignition switch is turned to the RUN position, or after the timer expires.
1helpful
Key Pad Entry does not work
does the key pad light when you press a button at night? If yes, the fuse is ok.
Do you have the plastic card with the permanent code in your owner manual packet? If yes, tryit.
report back.
Keyless Entry The keyless entry keypad is hardwired to the GEM. The GEM interprets the inputs from the keyless entry keypad and then controls the associated operation. The keyless entry keypad will be illuminated for five seconds when any button is pressed. Additionally, it will request the illuminated entry feature to turn the courtesy lamps on. If a lock all doors code is entered, the illumination will turn off, as well as request the illuminated entry feature to turn off the courtesy lamps. When pressed, the keyless entry keypad supplies the ground signal to the GEM or the GEM receives a signal from the keyless entry remote transmitter. Then the GEM outputs a ground signal to the appropriate lock or unlock relay which supplies the power to the actuator to lock or unlocks all doors, including the luggage compartment. The keyless entry remote transmitter also unlocks the liftgate or activates the panic alarm by sending a signal to the GEM.
--------------------------------------------------------------- Visual Inspection Chart Mechanical Electrical
  • Keyless entry keypad
  • Keyless entry remote transmitter
  • Central junction box (CJB) Fuse F222 (20A)
  • Circuitry
  • Generic electronic module (GEM)
  • No communication with generic electronic module (GEM)
  • Generic electronic module.
  • Circuitry.
  • REFER to Section 419-10 .
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
