Question about Refrigerators
WHERE IS THE RECHARGE PORT FOR A GE MINI FRIDGE WMR04BAPBB
2 Suggested Answers
  • 63 Answers
SOURCE: Shelving for mini GE refridgerator, model
Try www.repairclinic.com. It is around $50. Good luck.
Posted on Oct 12, 2009
My GE TFX27PP fridge is no longer cooling or freezing
Unplug fridge for 24hours fan could be froze up
Apr 03, 2015 | GE Refrigerators
Can you recharge freon tank on Daewoo #fr-094r mini fridge
You can but they have no fill valves. You have to add fill valves and if you don't do it correctly you can seriously injure your self or others during the recharge process. You can also injure yourself while trying to empty the system. Best thing your could prolly do is just replace the mini fridge.
Mar 16, 2015 | Daewoo Refrigerators
Refrigerant charge
There is no port unless you use a line tap if your refrigerator is less than 10 years old the manufacturer will pay for the repair unless it will continue to leak and compromise your compressor
Oct 19, 2013 | GE GSL25JFPBS Side by Side Refrigerator
My mouse isn't working. it is ge 98768 retractable mini mouse
hi
this is because of lose coonection in the wire. r the USB port got damaged. jus trying using another mouse if it works in your computer then the problem with the usb port.
Jul 05, 2010 | Jasco GE Notebook Mini Retractable Mouse -...
GE fridge does not get cold, 60 deg in freezer 70 deg in fridge, compressor is running condensor fan is running and fan inside of fridge is working
You have either a bad compressor or a refrigerant leak.Some times a compressor runs but doesn't compress the gas.It is more likely the unit has a sealed system leak which would have to be located,repaired,and evacuated,then recharged.(not a simple task).
Jun 01, 2010 | GE Refrigerators
I need wiring diagram for our General electric Fridge Freezer
I don't like the idea of someone just recharging a system without knowing what's truely wrong.
At this point, based on what you've said, I strongly recommend you call G.E. factory service or a dealer with a qualified service tech in the G.E. line.
G.E. has made the use of a lot of solid state boards, which may well be some if not all of your problems. It will be pricey, but a refrigerator is not a toy. I would advise the tech as well, that you had a recharge performed, and let him follow up on it.
Sounds like whoever worked on your machine isn't well qualified to service it. Newer G.E.'s can be a real bear. Sorry....
Oct 19, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Replace Evaporator in mini fridge
The system will definitely have to be recharged; the escaped gas was under pressure and you cannot remove the evaporator without losing its charge.
Since labor costs are not cheap, you might consider looking at craigslist for your area and buy a used one. Even new, they are mostly around $100 US which might be $30 higher than your planned evaporator swap.
Sep 24, 2009 | Refrigerators
My GE Profile Fridge doesn't get cold. The top Freezer is working and seems to be always Running. Any Idea's?
Check at the back under fridge If 2 compressors then possible gas recharge to the fridge one
If 1 compressor check thermostat in fridge and/or that the temp control is not set at defrost [some do this by being pushed in like a push button on/off]
Jun 17, 2009 | GE PTC22MB Top Freezer Refrigerator
Refrigerators Logo
69 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
