SYSTEM RESTORE Windows XP
Switch ON the PC, boot the PC
in 'Safe Mode' by continuously tapping F8 button after you switch On until you
get the Safe Mode Option.
Let windows boot in Safe Mode and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->Click
'System Restore'
A 'System Restore' window will appear.
Here you will have to check "Restore computer to an earlier time' and
click Next
Note: It is better if you could remember from which date you are
facing the issue, try to select a date prior to that date. The detail of that particular date should show "System
Checkpoint" and time on the right hand side box. Select that date.
Now you will find one Month Calendar window with Dates below, go to
the previous month by clicking the '
Now, Click on Next and System Restore will start and windows will take a
reboot.
After reboot your problem should be resolved.
yes, a real purchased copy! No upgrades at all
I have tried safe mode, safe mode with networking, last know configuration (basically all of them) and it just keeps rebooting
I did repair the drive. When I first turned it on and it was rebooting constantly I formatted the drive and reinstalled windows XP from the CD, then it was super slow so I clicked on drive C from within windows and did check disk and told it to repair. Windows said it was repairing some things, then everything was great until I was almost done installing ALL the updates and then it started rebooting itself again. Is repairing the drive from the CD at start-up better/different than doing it inside of windows?
you could always do a restore... which is pointless advice when you can't even get in... repair seems the only option at the moment
on your next ... tell me about the computer as well
insert the xp cd... reboot to it.... keep going until you get to the point at which it shows your hard drive.... you should see a selection for repair. repair it... do not mistake this for recovery console.
Robert
reboot the computer tapping the f8 key... select last known good configuration... if that doesn't work.... safe mode... let me know how that goes
Robert
is that a genuine copy of xp ??
