Question about Horizon T91 Treadmill
Horizon treadmill shuts off soon as I turn it on
I had the motor checked out and the motor is find. Soon as I turn it on the treadmill it starts and then in a second it shuts off.
4 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: I have a Horizon elite 507 treadmill, everything
Unplug your treadmill and remove motor shroud ,locate Motor control board their a series of LEDs . Now without getting on treadmill hit start look down and you should a light starting to flicker this is your PWM signal, t the upper console sends a signal to the lower board and instructs the motor to start. This tells me that the upper board and cable are functioning properly and our problem is either the board or motor.
DC motors can be easily tested in a number of ways. Many times a motor is replaced only to find another problem exists so be sure to test the motor if you think it is a problem. Methods to test a motor: 1) Cordless drill battery- get a fully-charged, 18 volt (preferred) cordless drill battery and on most treadmills connect the red and black motor leads to the battery (some have different colors but if you have two wires and get it hooked up backwards, the motor will just run backwards and won’t be harmed). If good, the motor should operate at about 1 MPH. 2) Car battery- these are 12VDC high amp batteries so the motor will turn slowly but you can walk on the belt. Always be careful with battery acid on these things so we don’t recommend bringing them in the house…take the treadmill to the battery.
If the motor test good then all fingers point to the Motor Control Board replace the board. When was the last time lubricated the running deck?
Answer: Never ! Then I suggest you purchase lubricant and apply it on the deck about 75% to 85% of the problems are belt and deck related.
Posted on May 23, 2010
Testimonial: "Many thanks for prompt response, seems that the treadmill works only when in the upright position and not the horizontal as per normal. Gonna have to learn to run up walls i guess"
maxtreadmill
  • 832 Answers
SOURCE: Horizon Treadmill T5.1. A sudden vibration and
To find a specific bearing that has gone bad in a treadmill you can use a long handled screwdriver and touch it to a non-moving portion of the rollers and then put your ear up to the handle and the screwdriver will amplify the noise of the part so you can find out which part is making the noise. If it is a bearing, it will be obvious which part is the problem because the grinding noise of the bad bearing with be amplified by the screwdriver.
Posted on Jun 11, 2010
SOURCE: horizon treadmill won't start running
The manual said that after lubricating the deck, press Stop and Speed buttons together for 5 minutes and this will reset the lubrication message and the treadmill should work.
Posted on Aug 22, 2010
My 5.2t Horizon Treadmill turns on, but as soon as I push the start button it blows the fuse to the outlet. I tried re-setting the breaker about 6 times and then I started smelling smoke. I opened the
First of all, never reset a breaker more the once. If it trips twice it's not going to magically, "heal " if you keep resetting it.
Two possibilities. Bad breaker or internal short in the machine.
Replace the breaker with one not tripping and then check out the machine for shorts.
Just switching out parts is a less specific and more costly solution.
Aug 10, 2014 | Horizon Exercise & Fitness
Horizon Treadmill won't run?
Check this attached link for trouble shooting information
May 31, 2014 | Horizon Fitness T101 Treadmill
Horizon treadmill t101
Go into tech rep mode and do a full calibration, then exit that and use as normal.
May 07, 2014 | Exercise & Fitness
My Horizon CT 7.0 treadmill slows down when i step on it
LUBE THE deck belt and rollers bearing . This happen because you must lube about 150 miles aprox. See the video and fix it. However if the problem persist. Time to replace the old board deck.
God bless you
Jan 25, 2013 | Horizon CT7.0 Motor Control Board
Not getting any digital display except power ''is on'' and thetreadmill doesnt start. Mine is a horizon CT5.2. Do i need to change the internal electronic circuit?
1) replace the old batteries by new ones with the same MARKS
2) Clean the contacts batteries, with c. cleaner very well
3) tight the Ribbon cables from keypads from display board.,and clean it
4) Adjust the REED swtich, see the diagram, clean it, and test for open or defective. tight the connector very well and try again.
God bless you
Jan 11, 2013 | Horizon 5.2t Motor Controller treadmill
I have problemwith my PROform 585 treadmill and recently it is stop working ,as soon as I put the machine on it makes 3 bbeps noise and its stays like that for ever ,could not get it start it at all a
1) lUBE THE deck belt vs deck, this produce shut down for to protect the treadmill in your electronic system
2) lUBE The rollers bearing very well.
3) Measure the input voltage motor , if there are voltage, the motor need repair.
4)Measure the output voltage board, for input voltage motor, if there are NOT the board is faulty.
see the diagram attached.
Jun 14, 2012 | Proform 585 CS Treadmill
The running belt motor does not work, everthing else works fine the belt will just not turn- no noise or anything
You need to pull the motor hood off to see if the belt is still on the motor. If it is and the motor is not turning, check the controler ( located on the otherside of treadmill) and you should see a red light on. When you tell the treadill to go.... the red light should start to flash, if it does then you need a new motor. If it just stays lit, you have lost communication from the console ( the upper controls ), and need to find out if something came dissconnected.
Hope this helps
Nov 10, 2010 | Horizon Fitness Horizon T91 Treadmill -...
My Proform XP 650e Treadmill starts and suddenly stops. The belt turns real fast then it suddenly shuts down like the power was turned off.
This condition is when the treadmill goes to full speed as soon as you power up the treadmill. Typically when this occurs, it is an indication of a short circuit in the motor controller.
Jun 28, 2010 | Proform XP Weight Loss 620 Treadmill
Can walk on treadmill but soon as i start to run it stops
Have you lubricated the the running deck? The lack of lubrication can increase friction thus causing the current limiting curcuit to activate thus shutting down the unit to prevent further damage, Go to your local hard ware store and purchase silicone spray. Apply Lubricant by lift one side of the running belt spray contents length wise starting at motor shroud to the back end repeat this process on the other side. If this unit shut down again then you will have replace the running belt and possibly the deck
May 20, 2010 | Reebok Vista Treadmill - RBTL13305
Horizon T91 Treadmill Logo
Top Horizon Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Trevor Turner
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
