How doI connect my Panasonic TC-P50S1 Plasma TV to my Vizio sound bar? The only audio out on the tv is digital audio out, but both don't seem to accept a digital optical audio cable.
  • SimplyNo Dec 08, 2012
    My tv only has a digital audio out. My tv doesn't take any other audio output such as analog or Digital Coaxial cable
SOURCE: Vizio SV470XVT will not output Dolby 5.1 from optical out..
TV's only will output 5.1 from HD stations. If you have a DVD player, XBOX 360, etc connected through HDMI, then the TV will only send stereo PCM through the optical out.
Posted on Jul 10, 2009
JollyRoger00
  • 59 Answers
SOURCE: Digital Audio Output Problem
connect the optical line from the DTV box to the audio system directly.
Posted on Sep 24, 2009
  • 205 Answers
SOURCE: How can I get tv audio thru my surround reciever
check to make sure you connected the RCA jacks to the audio output on the tv then go to the set up menu on the tv and select external speakers
Posted on Oct 15, 2009
falter
  • 245 Answers
SOURCE: TV- some channels don't have any sound, other channels do
RE TUNE UR TV AGAIN AND LET IT FIND ALL THE CHANNELS.......IF PROBLEM PRESISTS CALL PANASONIC SERVICE AND TELL THEM OR PROBLEM U HAVE IM SURE THEY WILL TELL U WHAT TO DO .........OR MAY OFFER U FREE SERVICE......WHAT WILL BE UNDER THE WARREN TIE U HAVE FOR 12 MONTS
Posted on Nov 20, 2009
  • 8457 Answers
SOURCE: I am getting vertical lines scrolling up on my new
Call for warenty service,prob. with ur backlight video board.
Posted on Nov 23, 2009
My Panasonic TC-p50s1 sound stops working. If I change th channel the sound comes back then it stops again how can I fix it
Check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Sep 01, 2014 | Panasonic VIERA TC-P50ST50 50-Inch 1080p...
How can I hook a vizio soundbar 2.0 to a Panasonic t.v. Model number tc-p42c1
TV's generally have optical / toslink connections for their digital audio output. I'm assuming the sound bar has a coax digital input, in which case you will need an adapter module. I have seen these on eBay for around $15.
Try searching: Optical Toslink Audio Converter to Digital S/PDIF Coax
Jan 22, 2014 | Panasonic TCP42C1 Plasma TV
How to hook sound bar to panasonic viera 42 inch model TC-P42X5
The aftermarket audio/video cannot allow you hook your Tv and Dolbys stereos becauses of incompatibility issues.
Jul 24, 2012 | Panasonic Viera Tc-p42x5 42" Inch Flat...
I have a Panasonic Model TC-P50S1 plasma TV and the red indicator light continuously blinks and the TV never does come on. Can this be fixed?
Panasonic utilizes the blinking light as a form of self-diagnostics, similar to the "check engine" light in your car. If you've ever experienced that, you know that a check engine light could indicate anything from a loose gas cap to a major failure.
Panasonic uses the number of times the light blinks, to aid the technician in trouble-shooting the problem. The blinking light indicates an area of concern and helps the technician to isolate the problem and order the correct parts. This in turn speeds up the repair process, keeps parts cost down, and helps both you and the servicer by allowing the technician to complete a repair in one trip in most cases.
So contact an authorized service center.
May 28, 2011 | Panasonic TC-P50S1 50 in. Plasma LCD HDTV
WHILE WATCHING MY TV TONIGHT I HEARD A LOUD POP AND NOW NO PICTURE JUST BLINKING RED LIGHT
10 blinks for this tv is not always an A Board issue. It can be a problem with the power board as well. A technician should look at the set to dertermine where the problem lies otherwise it is just a guessing game of inni minni miny moe.
Apr 03, 2011 | Panasonic TC-P50S1 50 in. Plasma LCD HDTV
I have a vertical white bar running down the middle of my screen. I have seen it before, but it has disappeared within a few minutes. Now it won't go away even after turning off the tv and letting it sit.
Your plasma panel is in the process of dying.
There is no economically feasible way to fix this, your best bet would be to start shopping for a new TV. A replacement panel for your TV would cost 80-90% of the value of a new TV.
Good luck.
Mar 15, 2011 | Panasonic TC-P50S1 50 in. Plasma LCD HDTV
I have a Panasonic TC-P50S1 Plasma HDTV. I am trying to run my PC into it via DVI to HDMI. It will work, sort of, for a little bit. Then eventually the screen flickers and I lose the picture completely. I...
I BELIEVE THE ISSUE IS THE RESOLUTION THAT THE VIDEO CARD IS SET AT. IF YOU ARE USING THE SAME RESOLUTION AS THE PC, IT WON'T WORK.
TRY SETTING THE VIDEO CARD RESOLUTION AT 1920 X 1080. THIS SHOULD WORK.
ED P
Jan 20, 2010 | Panasonic TC-P50S1 50 in. Plasma LCD HDTV
Connect home theater to tv
Do you have the cables connected to line out on tv ? Do you have the correct source and audio type selected in the home theater (analog/digital/coaxial).
Jan 18, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Televison & Video Logo
146 people viewed this question
Top Televison & Video Experts
Electro Med Services...
