Question about Garmin nuvi 205W GPS Receiver
How do I reset garmin 205 w
I am unable to reset my garmin 205 w. It still shows a place I was last week and the simulation drive keeps coming on.
    New Friend:
  • 9 Answers
Resetting Your nüvi 205W. PLEASE READ ALL BEFORE TRYING.
If your nüvi stops responding, turn the nüvi off, and then turn it back on.
If this does not help, reset your nüvi.
Press and hold the RESET button on the bottom of the nüvi for several seconds.
Clearing User Data CAUTION:
This deletes all user-entered information.
1. Hold your finger on the lower-right corner of the nüvi screen while turning on the nüvi.
2. Keep your finger pressed until the pop-up window appears.
3. Touch Yes to clear all user data.
All original settings are restored.
Any items that you have saved are erased.
Let me know if it solved it.thxx
Posted on Jan 14, 2009
  • jichang Dec 25, 2010
    Thank you this worked for nuvi 205. This trick was not even in the manual.
    And I was not able to change from Spanish to English. This made it possible.
    Again, thanks have Merry Christmas to all! JI
I have lost all my maps on my garmin nuvi 255W-
Do a hard reset on your GPS. Download and install Garmin Express from Garmin. Plug your GPS into your computer. The software will identify your GPS and allow you to download new maps to it.
Mar 19, 2017 | Garmin Nuvi 200 205 250 255 260 W
I have had my garmin forerunner 205 since end of May 2010. It recently started taking longer than normal to find satelites. On my last run it came up as saying battery low when I had only just charged and...
You need to contact Garmin and have them replace or repair the watch. If the watch is less than a year old, it will be under warranty. Older than a year it may be a repair or replace only situation, Garmin will have to determine that. It is not unusual for the forerunner series to have rechargeable batteries that die off.
Jan 04, 2011 | Garmin Forerunner 205 Gps Training Watch
Garmin nuvi 205 series, keeps beeping and "loading maps" I tried shutting it off and then holding the reset and turn it back on. it will not turn back on this way. if i push reset w/it on, it shuts off.
You can restore the Nuvi 205 system software to its factory condition by running Garmin's WebUpdater service. You may also want to try a hard reset of your Nuvi.
These are both good steps to take when a Nuvi starts acting up.
I hope that helps.
Dec 21, 2009 | Garmin nuvi 205 GPS Receiver
My garmin 205 keeps on loosing signal and it shows the location on the screen were ther is no roads
when the Garmin shows you are driving in the middle of a field, it is because the software doesn't know there is a road there. New roads seem to take two years before they are updated to the units software disks. I bought 2009 software _specifically_ because two of the highways I use had been extended, but the new disk didn't fix the problem! It is kind of funny where the image on screen shows you are in the middle of a field and the car image does a shimmy left and right!! :>)
Dec 14, 2009 | Garmin nuvi 205 GPS Receiver
Unit keeps locking up and i have to power cycle the unit to get it working again my last trip was 3 hours long and it locked up 4 times
When a Garmin Nuvi 205 stops working or behaves strangely, there are two steps you can take yourself to try and get it going again:
  1. Perform a Hard Reset,
  2. Run WebUpdater to reinstall the firmware.
I hope that helps.
Nov 14, 2009 | Garmin nuvi 205 GPS Receiver
GPS unit quit working
Make sure your unit is not in SIMULATOR MODE.
Press the wrench at the main menu, then the Gear (system) icon. Then look for the option that says SIMULATOR. Make sure that function says OFF. With it ON, you can Simulate a driving route but your GPS will not be working in real time mode.
- Jim
SHARCNET-USA
Sep 11, 2009 | Garmin Nuvi 660 GPS Receiver
Does not track properly shows the vehical driving off the road
If it is new and bought recently you should return it to the seller for replacement or attention. You coulod first try to recalibrate the screen. if that does not fid it return it quick before any 30 day rteplacement warranty expires.
Jul 28, 2009 | Garmin nuvi 205 GPS Receiver
My Garmin is stuck in simulation mode at one of my last locations
all garmin nuvi users reset device small button on bottom then plug into computer using usb cable back up the nuvi folder in my computer,just in case, then run virus check on device`s nuvi folder when finished unplug safely , hopefully should be back to normal i have down this with 2 nuvi`s with keyboard problems and it has worked both times hope works for you regards brettjohns1350@bigpond.com
Jun 15, 2009 | Garmin Nuvi 660 GPS Receiver
Since my last time i used garmin nuvi 260 it cant find a signal
Try going outside with a clear veiw of the sky, since it cant aquire a satellite its simulating the last place where you were. Try canceling the route and see if it connects with the satellite.
Jan 08, 2009 | Garmin nuvi 260W GPS Receiver
I have a new garmin nuvi 205 and it will not work...
Look near the SN # and press the reset button.
or
with the garmin off, hold down the right bottom of the screen and turn the garmin on, it will then ask you if you want to perform a hard reset. Choose yes and that should fix your problem.
Jan 05, 2009 | Garmin nuvi 205 GPS Receiver
Garmin nuvi 205W GPS Receiver Logo
21,084 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
