Question about Karcher 2500 PSI Pressure Washer
Karcher HD 655 S Does not come up to full pressure
I have a Karcher electric pressure washer which has started to dump pressure before it comes up to pressure. If I slowly adjust the pressure control it comes to about 40 bar and dumps. I have stripped the pump to check for worn seals etc. but everything looks fine. I have used a 1/2 inch garden hose for years with no problems. Occationally it will come up to full pressure momentarily so it seems the pump is OK. Is there any further checks I can do?
  • Anonymous Mar 15, 2014
    My hose disconnected on my pressure washer while i was using it and now it will not work could it be a safety cut out switch
  • Anonymous Mar 28, 2014
    While stripping down a Karcher 620m I undid the bolts which hold pump to motor and lost about 100ml (?) of oil. Looks like a 15/40 or sae30 standard oil. It was clean and good oil.
    How do I refill?
  • 883 Answers
Yes...check the check valve. A one-way directional valve, this part is also known as a DUMP valve. It opens when too much pressure builds in the hand wand (when not spraying water) in order to protect the pump, by returning the high pressure to its source reservoir. I suspect the DUMP valve is stuck in open condition (or nearly open).
Posted on Jun 10, 2007
Clean the Nozzel !
Posted on Mar 20, 2008
Karcher electric pressure washer help starting
The test / reset buttons are for a Ground Fault Interrupter built into the cord / washer. This device will help prevent deadly electric shock in the event of a malfunction - it is the same technology used in "GFI" electrical outlets located in bathrooms, outdoors, basements, etc.
You should have this serviced - or replaced before using.
Sep 18, 2015 | Karcher Garden
I have a karcher kb9020 which pulses when idol any ideas why
The "manifold" as talked about above is also called the "Control head".
For a picture of the very small cracks in the control head see here: Karcher Control Head cracks
The video linked to below talks about the cracks in the control head at 7:00 through to 7:08. They guy incorrectly calls it the cylinder head in the video. How to FIX Karcher pressure washer
If Karcher made the control head from an aluminium casting, or used a metal insert near the point of failure, their product range would be a LOT more reliable.
May 30, 2014 | Karcher PSI Electric Pressure Washer
My Karcher 720mx moter is working fine but i have no water pressure coming from pump
hi put some silicon spray in inlet and outlet then reconnect hoses what is going on is when you store it the seals start to dry out.........
Jan 13, 2011 | Karcher K3.68MR Electric Pressure Washer
How do i get the soap to come out from the washer
To get the soad to come out you will need to adjust your machine to low pressure. You can do this by turning the knob at the end of the lance and then your machine will **** chemical.
Jun 13, 2010 | Karcher K2.26 Electric Power Washer
My Karcher K9.8 electric pressure washer started
Not Simple.
I have the same Problem, the leak is from the seam of the Manifold or on the pressure side of the Pump and the hose housing. In my case there is a small crack in the seam of the Manifold Housing. A manufacturing defect.. A New Manifold Complete Replacement about the half the price what I paid for this pressure washer at Walmart... :( If under 1 year old, and you can find a receipt,Karcher will replace the whole Pressure washer under warranty.
May 18, 2010 | Karcher 1750 Psi Elec Pressure Washer
No power
The most common problem is the unloader valve.The valve that you use to adjust the pressure need to come out and then free up the unloader valve with some penatrating oil and maybe even some emery cloth.If you cant free it up then it will have to be replaced.
May 09, 2010 | Karcher K2.26 Electric Power Washer
Just started using my kb4040 and water i s leaking
Sounds like the water seals are bad. For Karcher parts go here: LINK
Jan 18, 2010 | Karcher 1750 psi Electric Pressure Washer
Karcher prssure washer motor will not start
try going to www.karcher.com
then click on europe
the international,
then service and will then see spare parts, enter k620
tick the button for you are a engineer and you are on your machine
download.
micro switch might be at fault.
Mar 25, 2009 | Karcher Garden
Karcher 2500 PSI Pressure Washer Logo
3,248 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
