Question about Chamberlain KLIK1 Remote Control
How to re program a klik1
I have a genie garage door opener and a chamberlin klik1 control. I'm trying to program the remote
ktkodama
  • 37 Answers
SOURCE: Remote does not open garage door
It sounds like the wall button has the lock feature engauged.
Is there a small green LED flashing inside the wall button?
Push and hold the lock button for about two seconds and the LED should stop flashing. This will unlock the garage door opener and your remotes should start working. You may have to reprogram your remotes and homelink again since you triedprograming in the lock mode.
Good luck.
Posted on Jan 20, 2009
SOURCE: have chamberlain security plus 950cb lost instructions.
http://www.chamberlain-diy.com/doityourself/pdfdocs/114A2184.pdf
This web address came from the Chamberlain site. I also needed to relearn my remotes due to a newer car that has a built in garage door opener that needed to be set. I also needed to reset my keypad remote, those instructions I was able to get from the same site. Good Luck
Posted on Apr 26, 2009
  • 10865 Answers
SOURCE: i have a chamberlain 950-315cb
Here is the website which will provide you with all of the info you need on the chamberlain remote and door openers
http://www.liftmaster.com/consumerweb
Posted on May 19, 2009
  • 6 Answers
SOURCE: Locked out & Remote not working
There should be a green button on the back of the motor unit, press it for 2 seconds and then hold down your remote button until the light flashs. or for 3-5 seconds and then activate the remote. that might solve your problem
Posted on Jul 24, 2009
  • 23 Answers
SOURCE: cannot open garage door using 950cb remote control
First of all you should check & ensure the infrared is emiting from the remote control. Though we cant see this infared beam with bare eyes, i found a trick to do so in http://www.unique-stuff.co.cc/fixing_remote_control_check_infrared.html When there's a sign of batteries weakness, replace them immediately.
Posted on Jan 24, 2010
Car garrage door opener
smart or learn button is located on the back of the garage door opener. (the machine that is over your head) on most units such as liftmaster, craftsman, chamberlin. its on back or side by the light bulb and is green, yellow, orange/red, purple. genie units are black button behind light cover. or external on old units. push and hold your cars homelink button will blink slow, at the same time push and hold the remote for the garage door. led light in car will blink fast. let both go. now go to the garage door head unit, (overhead) and push the learn button. button will blink and you have 30 sec. to go to car and push the cars garage door button. head unit should flash its light, letting you know that it is programed succesfully. genie units push 3 times
Dec 10, 2013 | Building Materials
Garage door opener Chamberlain - programming problems
I bought a new keypad and 2 VISOR remote (30498). As to programming garage door opener, I did like here:
- it tooks me 20 minutes and works great
Feb 07, 2013 | Sears Craftsman LiftMaster Chamberlain...
How to set acsctg type 2
There is a button on the motor head you can press. Press it then press the button on the remote 3 times and try it. If not try it again. Genies are bad for not coding in the first time. Make sure there are new batteries in it. Thanks BB
Jul 19, 2010 | Genie Company IntelliCode GICT390-1BL...
Genie Compact 3-Button Remote control will only open 1 door/not 2
On some of the remotes you will find a toggle switch to change frequencies, this might help. Note all new openers are operating on a different frequency than slightly older ones due to military interference. Even though both might be intellicode they might not work together on the same remote. Sometimes some openers are harder to program than others. So lets try to program the harder one. You need to find and press the learn button on the motor head. Then press the button on the remote once. The led light by the learn button should not flash. If so try it over. The light should either stay lit or go out after the first press. If it does press it again and then a third time. If it ever flashes during the program process try again. The third or fourth time the motor should operate. If not you either have a bad remote or more than likely a bed logic board. Thanks BB
May 15, 2010 | Genie Company IntelliCode GICT390-1BL...
Have a 3 Genie remote and the center button works in programming one garage door, but the side buttons will not work to program the other garage door. Can you help?
The other opener has to be a genie, compatible genie to be exact. An older one will not work with new devices. If it will not program it will be the openers fault not the remote. Thanks BB
Feb 16, 2010 | Genie Company IntelliCode GICT390-1BL...
GARAGE CONTROL SYSTEM
Try holding the hand held remote up next to the homelink (built in remote). Hold down the botton on the hand held remote and the botton you want to program in the car at the same time until the homelink light goes out. This could take 60 seconds or more. Now depending on which model garage door open and how old it is you may need to program the car to the opener. Usually this is done by pushing the botton on the back(Liftmaster,Sears, Chamberlin) or the botton on the front(Genie) and then go to the car and push the same botton on more time. I hope this helps.
Feb 05, 2009 | 2005 Honda Pilot
2 different openers stopped working by remote at the same time
Both the older genie and a newer chamberlain (3-4 yrs old) both run on 390Mhz frequency. sounds like you will have to change your receivers on both operators (365LM 315Mhz) then get 3 button remote so you can program both doors on one remote.
Jan 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain KLIK1 Remote Control Logo
Top Chamberlain Televison & Video Experts
Raj Patel
Are you a Chamberlain Televison and Video Expert? Answer questions, earn points and help others
