Question about Maytag MFC2061HES Stainless Steel French Door Refrigerator
Maytag french door refigerator won't maintain temperature
- fridge is only 16 months old!
- compressor has been running all morning (put my hand on it)
- vacuumed as much dust as possible form the coils and fan
- fridge is holding at 50 degrees, freezer at 8 deg. (setpoints are at factory defaults - 0 and 38)
- clearance is not a problem
  • nicholasp3 Jan 12, 2009
    Thanks, but what about the fridge section? It's been over 50 degrees for about 8 hours now, and the temp is not dropping (holding at 52). The blower fan in the fridge section seems to be running. the evaporator fan is blowing room temp air, and the coils are not warm to the touch.
    The freezer section has now dropped to 5 degrees (from 8), but there is ice built up on the back wall (have never noticed any ice buildup in the freezer before).
    Thanks
    Thanks
  • 10,515 Answers
U wld be able to ge ur answer...
  Have patience and read two blogs :)
http://www.bobvila.com/wwwboard/messages/260460.html
and
http://www.appliance411.com/?ref411=Refrigerator
Thanks and Take Cre.
Posted on Jan 12, 2009
  • 242 Answers
Hello , this can be caused by a few different things.
1- Your unit is not defrosting. check the back wall in the freezer to see if there is any ice/frost on the panel also push on the panel and listen for ice crunching.
2- Your evap. fan is not running. to check if your fan is running open your freezer and hold the freezer door switch down you should here it run or feel the air coming out of the freezer supply vent.
3-Your unit is leaking refrigerant. this is difficult to check but can still be done. take the panel off the lower back of the unit to see the compressor , there are two small tubes going into it one is a bit larger than the other you need to find the smaller one usually on the bottom right looking at the compressor , this line goes to the condenser coil that you cleaned the dust off of , with the unit running for at least 5 minutes grab this line about 5-6 inches away from where it comes out of the comp. it may take a few seconds to feel how warm/hot it is but be carefull they can get hot. if this line is hot the refrigerant charge should be ok , if its room temp. or very close than your unit has leaked its refrigerant.
Please let me know if you have any further questions on this , I would like to hear how it turns out.
Phil
  • Maytag Master
  • 19,396 Answers
Check evap system, ensure that the fan is starting and working, and that there is no ice formation on the coils.
If there is ice on the coils or inside the fridge, unplug it and leave it defrosting overnight.
If the compressor is always on, and the fridge reaches temperatures lower than normal, and evap. system is working, then it is a defective thermostat.
If the compressor is always working, and tem does not get low enough, then you need to replace the compressor, or recharge freon. No matter if the Fridge is only 16 months old.
The compressor is under warranty for three years. Call the number listed on the owners manual to get assistance.
  • Ginko
    Ginko Jan 12, 2009
    Hi there, I quote:
    "The freezer section has now dropped to 5 degrees
    noticed any ice buildup in the freezer before)."
    Do a defrost overnight,k if you still have the following:
    "Thanks, but what about the fridge section? It's been over 50 degrees
    the touch."
    Tehn it is either low freon (leak) or bad compressor.
    Get a new compressor from factory and have it installed if situation did not improve after defrost.
    Genius:
  • 2,920 Answers
Your compressor is low on freon...if you dont have it serviced soon you wont have a refrigerator to have fixed. once they lose all their freon they are no good and you said the compressor has been running allmorning which can create a heat problem for the area surrounding the compressor and could cause a fire. you need to get someone there soon
    Genius:
  • 1,199 Answers
You first want to check if fan is running Blower fan may be froze or broken...next I would check the thermostat! it may need replaced!( why compresser wont shut off!,I would call the company being that it is still a new model!
    Top Expert:
  • Maytag Master
  • 77,499 Answers
This sounds like u have a refrigerant leak or a compressor failing, that is the only thing that would account for constant run and the high temps.
  • yadayada
    yadayada Jan 12, 2009
    U say u have had the frig for 16 months, u have never noticed this before? if not the defrost cycle is not the issue.
    Scholar:
  • 160 Answers
The freezer temperature increases by about 20 degrees during the defrost cycle. This is normal and doesn't affect the quality of the food in your freezer.
http://www.repairclinic.com/0088_4_1.asp
click the link for more help.
Why would my Maytag MFX2570AE 4 door french door fridge motor/fan run constantly?
if the compressor goes off and only the fan keeps working thats broken fridg but fan is not a big energy drainer on bill if the compressor works allways it might be to hot in the room or door is not seald or totaly closed give it a strog push when closing or maybe you have under floor heating so you have to insulate bottom from heat or maybe its not insulatdd well from heat of compressor
May 20, 2014 | Maytag Ice2O MFX2570AE 25.0 cu. ft. French...
Maytag MFD2560HES stay at 33 freezer and 50 fridge
Sounds like an electrical fault.
check the balance or levelling of the unit.
could also be the compressor on the way out.
do you have any refigerant leaks ?
Mike @ Compurepair.
Feb 23, 2008 | Maytag MFD2560HES Bottom Freezer French...
I have a 16 SEER Goodman air conditioner and during the morning hours, temperature ranging 75 degrees outside, the compressor comes on but not the outside fan. It only runs for a minute and a half then...
The fan is shutting off in order to maintain head pressure when the outdoor temperature is low. This is common on 16 seer and above systems. It helps your system be more efficient.
Jun 06, 2011 | Goodman Heating & Cooling
My French door Maytag shows that my freezer temp is -2 and my fridge compartment is 40, but both are not cooling. it is now room temperature inside.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 25, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Refigerator is freezing food
Hi, this problem is going to be with the running thermostat. It has gone bad and stays open which in turn will keep the compressor running continually. It can normally be located in the control panel inside the fridge. Locate the thermostat and replace it. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Sep 18, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
LG French door fridge freezer not freezing
hopefully you looked out back ...rear lower panel and checked little white condenser fan running...it really needs too to keep temp stable across the condenser coils and no overheat condition to the compressor.hopefully you wont need the $300 circuit board like I just bought
Jun 26, 2009 | LG LFC20740ST Stainless Steel
Fridge and freezer not working on new Maytag, Help!!
at 5 months old don't try to fix it yourself CALL the store where it was purchased or maytag
you may mess up the warranty if you try to fix it yourself
document all of the calls you make to where and who you spoke with at what time
ask for promises in writing have them fax it to you so you have the promise in hand
Dec 14, 2008 | Maytag MFD2560HES Bottom Freezer French...
Mfd2561hes Maytag Refrigerator
This sounds like you have a Maytag Ice2O. You need to find out if that cound is a relay/overoad failure on the compressor or the compressor going out. I can say from experience that some of those have a tecumsie comprossor in them and the do tend to fail. If you hear a loud electrical humming sound coming from the compressor and your getting a warm up then you need to record this sound on some kind of sound recorder and call a Whirlpool warrenty certified tech. out to look at it if it's less than 5 years old from perchase date then Whirlpool will pick up the part and labor bill of a compressor installation also check your owners manual for warrenty details. Hit me up let me know.
Feb 13, 2008 | Maytag MFD2560HES Bottom Freezer French...
Freezer/Refigerator not working
You need to check if the compressor is running. If it is not the relay on the compressor might be blown out. That is a very comon part on whirlpool made units. Unplug the unit and remove the cover on the compressor and take the relay off. If you shake it and you hear a lot of noise from it like small rocks the relay is bad. Its not a expensive part ti replace.
May 07, 2007 | Kenmore 44109 / 44102 Side by Side...
Maytag MFC2061HES Stainless Steel French Door Refrigerator Logo
66 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
