Partitioning hard disk for hp cq60
How does someone create partitions on hp cq60. been trying for the last one week but in vain
  • 1 more comment
  • Jason Edinger May 11, 2010
    That's a bit of a loaded question. Are you partitioning a desktop or laptop? Is Windows already installed? Is Windows installed on a different drive than the one you're partitioning?
  • DEKR
    DEKR May 11, 2010
    DO YOU WANT TO FORMAT AND MAKE A PARTITION AND WHAT OS SYSTEM DO YOU HAVE
  • P222PJP May 11, 2010
    what OS are you using?
  • 81 Answers
Easy. Just be careful and read everything! Download Partition Logic, burn it to a disk and reboot to it. If using XP your good to go, if your using Vista read the notes they have about it. Hope that helps.
http://partitionlogic.org.uk/
Posted on Jan 12, 2009
How do we create a new hard disk partitions? Please help. Thanks.
Here are two methods to create a new partition:
Method 1: Create partition in Disk Management
Step 1: Open Disk Management. Right-click Start button to find Disk Management. If you get the UAC dialog box, then give confirmation.
Step 2: Right-click on the unallocated space and select New Simple Volume from the context menu.
Step 3: Follow the on-creen gude of New Simple Volume Wizard to computer the task. 2222-l4z23du0euvv25ewe4orlrwr-4-8.png
Method 2: Create partition using free partition manager without data loss
Step 1: Install and launch PartitionGuru Free and locate the disk where you want to create partition.
Step 2: Right click the disk and select "Split Partition". This this split current into 2 partitions without data loss.
Step 3: Decide how much space you would like to move to the new partition, and click "Start" button. You can either enter the exact disk size or drag the arrow between partition bars to set the size.
Oct 18, 2016 | Hard Computers & Internet
Good day everyone. I want to reformat my laptop (320 HD) but I cant find the hard disk space beside the recovery file which is stored under partition 1, with capacity space of 1.3GB. Can someone help me...
I guess your gonna reinstall Windows, is it showed up as unallocated space ?
I've it is, format it to NTFS, and your done.
You can now use this partition.
Jun 13, 2011 | ASUS Computers & Internet
Hi i made a partition on my hard drive and when i turned my laptop back on i get this message, non system disk or disk error replace and strike any key when ready can you help please thanks ross
if you create a new partition on your hard drive with anything but partition magic or something similar, the process of creating the partition will wipe all data from the entire hard drive to resize the partition. you will probably need to re-install Windows fresh unless the utility you used just happens to have an undo (not very likely) playing with partition sizes of used drives is not advisable.
Mar 21, 2011 | HP Compaq tc4400 Notebook
Pls help me to partition my hard disk drive as c and D
If the computer is already running with Windows, then you can use a program called Partition magic to partition the C drive into two partitions - a C and a D drive.
If you are installing Windows from scratch then you can use the Windows installation CD to install Windows. When the Windows installation begins, delete the existing partition, then create a new partition but size the 1st partition (C drive) to what you require and continue with the installation.
When Windows has finished installing you can create the D drive by opening Control Panel - Administrative Tools - Computer Management - Disk Management - click on the un-partitioned portion of the hard disk, create a extended partition - and then format this partition in NTSF When completed Disk 1 will be shown as Healthy (system)
Mar 20, 2011 | Computers & Internet
My hp touchsmart 300 hard drive went out i got another hard drive but it needs to be formatted and pratitioned but i cant figure out how to do that
  • Start the computer in Command Prompt Mode. Type "FDISK." The partition window will appear with menu options. Enter 5 if you're partitioning a second drive, and select the drive; otherwise, skip to the next step. Enter 1 (Create DOS Partition or Logical DOS Drive). Enter 2 (Create Extended DOS) to create a partition. Enter N when the program asks if you want to use the maximum available size. Designate the amount of disk space to allocate to the second partition (the partition will be assigned the next drive letter) Type a name for the new partition and press Enter. The partition menu will appear. Repeat steps 5 through 8 to create additional partitions. Press Esc to exit the partition command. Format the newly created partitions
  • Jul 28, 2010 | HP Computers & Internet
    How to create a logical drive in windows vista home basic?
    You must be logged on as an administrator to perform these steps.
    To create a partition or volume (the two terms are often used interchangeably) on a hard disk, there must be either unallocated (empty) space on the hard disk or free space within an extended partition on the hard disk.
    If there is no unallocated space, you can create some by shrinking an existing partition, deleting a partition, or by using a third-party partitioning program. For more information, see Can I repartition my hard disk? For more information about reformatting a hard disk, see the "What is reformatting?" section below.
    aymloekh0fg4hpz2e87n86udvs4fowqwshuaaaaasuvork5cyii=
    Mar 31, 2009 | Microsoft Windows Vista Ultimate Edition
    I used disk manager to create partitions. but sata hard disks are not supporting.I am using disk manager9 version. please tell me how create partitions in fat32 using disk manager.And also tell me which...
    You can use Partition Magic Pro, RANISH Partition Manager, GDISK etc.  OR else You can download the ultimate bootcd Click Here to Download
    Have a Nice Day
    Thanks & Regards Nandu
    Mar 13, 2009 | HP Computers & Internet
    Presario cq60 104tu
    The master boot record maybe be corrupted or virus infected.
    To fix the MBR, boot up with your DOS disk and type fdisk /mbr
    Then install XP, and delete all partitions and then create a new partition, then do a full NTFS format on the new partition.
    Feb 27, 2009 | Compaq Computers & Internet
    Hard disk Problem
    Try to download the Software Partition magic. Maybe this software can help to recover your partition.
    Good luck
    Dec 18, 2007 | HP Pavilion dv6000z Notebook
    Computers & Internet Logo
    44 people viewed this question
    David Payne
    David Payne
