Question about Linksys Wireless-G WRT54GS Router (e125894)
Laptop will not pick up wireless conection from router
I've been through this before when i origanally set it up got it all worked out it was fine we unpluged the computer it shut off and it has never been able to connect again
    Genius:
  • 1,269 Answers
Try to do a power cycle first. Unplug the power to the router for about 30 seconds then plug it back in. If the wireless still not working, you need to change the channel of the router from 6 to 11. You can do it by accessing the router's setup page through internet explorer 192.168.1.1
Posted on Jan 12, 2009
I have two computers one is a pc the other is a laptop I can't get my laptop to run the wireless router connection! I install the disc tn the pc that came with wireless router and it for a day.Now it...
The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, it needs the router'swireless settings configured ie SSID, WPA or WPA2 encryption key and also thewireless cards in all the laptops and or computers needs to be configured withthese router's wireless settings. Then the laptops and desktop computers cancommunicate with your wireless router.
Mar 11, 2011 | Computers & Internet
Router connected fine... not allowing my laptop to pick up wireless signal. not an internet issue as I have connected primary computer via wire and it works fine. need some troubleshooting ideas to...
In your router settings, look for something like "wireless radio" and make sure that is enabled. It sounds like your wireless is disabled.
Or
On your laptop, your wireless card may be disabled. Are you able to scan and locate other wireless networks on your laptop?
Feb 27, 2011 | Computers & Internet
Can conect wireless ,ethernet cable work fine but not wireless
.Log into router ( 192.168.0.1) enter into the browser window.
2. Verify wireless router name( on the computer) >>> ( on/off) on the status page in the router.
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Here is the instruction set for your model router :to set it up wireless follow the emulator instruction at this link:
http://support.dlink.com/emulators/wbr1310_revA/104/wizard.htm
This is for all routers to set up wirelessly.
Aug 11, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Picks up wireless network but unable to connect to the internet. I am trying to connect to the wireless on a laptop and a phone, both work fine else where but i am unable to connect to the internet using...
what is the wireless status in system tray? is it local or local and internet.
1. first check if it works fine with wire conection or not.
2.if it fine with cable then issue is with wireless. probably issue with Wireless security key.
3. go to available wireless networks and select the net work, if it is asking for wireless key please enter that. if you donot remember that perform router reset.that takes care of it.
Sep 24, 2009 | Linksys Wireless-G WRT54G Router
Client Manager will not pick up my buffalo wireless card.
You can find the driver in the Buffalo download archive for older products:
http://site2.buffalotech.com/support/downloads2.php
Choose from the menu.
You also find manuals and set-up guides there.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Jul 31, 2009 | Buffalo Technology Buffalo AirStation...
Laptop does not detect wireless from Zyxel 660 router
Dear! You will have to enable wireless conection to access the router and internet. Check your adapter settings and enable wireless conection. Your problem will be solved.
Thanks
Jul 28, 2009 | Zyxel Prestige 660HW Wireless Router...
Problem with Toshiba wireless conection
If you have your router set-up with security enabled, you should try to re-set the router and then go back onto the routers "control panel" and re-setup the security. You can find out the correct way to reset the router and the correct address to enter into the browser to access the routers control panel by going to the router makers website and checking under Support
Feb 20, 2009 | Toshiba Satellite M45-S331 Notebook
Wired vs wireless
Yes. Wired will be faster and setup is the same. You turn off the wireless on the laptop, and plug in the ethernet cable. The settings are probably defaulted to obtain an IP address automaticlly and that should work.
The wirelss will continue to work as it did before for the other machines.
Carl
Aug 29, 2008 | Microsoft Broadband Networking MN-500...
Laptop not seeing my wireless router
Try to manually "Add device to network" by using the wireless setup wizard. Check to see if the Wireless Zero Configuration service is "Running" before trying to add device. Yuo may also want to disable IPv6 in vista tcp/ip properties page.
Jul 17, 2008 | Linksys Wireless-G Broadband Router
ask a neighbor if they pick up our router signal if not start from scrach if it still dont work hope our router on warranty. cheers
Jan 13, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Linksys Wireless-G WRT54GS Router (e125894) Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
