Question about Napoleon 36" Zero Clearance Top/Rear Vent Natural Gas Fireplace with Black Door
Heat and Glo pilot light works but Burner won't go on. I messed with it and it started up but won't turn off. next day won't start but the pilot light is still on
Heat and Glo model 6000trlp-oak Serial 002425637 I have no idea what the termopile model is. I wish I could see a Video one what I need to do to check. I read your notes but I'm not a sure how to check the parts. I read it and just read i need to use DC meter side.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 12 Answers
Light your pilot and take a light to the termopile (right beside your pilot it sticks out to get heat from your pilot. hold lighter for 5 seconds and turn gas on
Posted on Feb 11, 2013
Pilot light won't turn off
Any parts been changed? valve might be wearing out.
Apr 23, 2013 | Imperial IFS40 Deep Fryer
Napoleon Fireplace propane Pilot won't light main burner even though gas flows in?
  • I'm going to assume your fireplace has a pilot light.
  • Follow the little holes in the burner that lead to the pilot light.
  • Make sure the pilot flame is pointing directly at the closest burner hole. (adjust if necessary).
  • Often, you will need to sprinkle a layer of "glowing embers" in this area. The embers will help the gas travel to the pilot light and ignite.
  • Always start your propane appliance on "High" never "Low". Cold propane likes to drop to the bottom of the firebox and accumulate until it reaches the pilot (this is called delayed ignition). Keeping it on "high" will help the fuel travel over to the pilot without buildup.
Jan 21, 2013 | Napoleon 36" Zero Clearance Top/Rear Vent...
The pilot light went out on my aqua star 125 BNG tankless water heater. I lit the pilot and the burner started and now the burner won't go out it when I turn the water off Serious business anybody got...
Before calling service technician, copy following links for troubleshoot resources:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Jul 13, 2012 | Water Heaters
Right, front flat burner does not light and barely heats. My Hotpoint stove is five years old and gets very little use. What's wrong? Can I fix it? Can you help?
Hello and Welcome to FixYa!
Please provide us with the model details of your unit and What exactly, you are facing. Is the burner properly getting the supply. And is it partially lighting or didn't lighting at all. Is the unit repaired ever since the problem started? Some details of the trouble, you are facing, will help suggesting more precise solutions to the problem,
Feel free to Ask,
Concerned.
Jul 15, 2011 | Hotpoint Kitchen Ranges
Pilot light is working in a.m. when machine is started. After machiine runs up to temp (350 deg) the burner will turn off and pilot will go out also. After finding machine has shut off we turn it off and...
Ensure that the gas pressure being fed to the unit meets the standard as rated on the unit's nameplate.
The thermopile must be free of soot or any form of dirt.
Pilot flame quality must be good and can heat up the thermopile properly.
Wiring connectors must be tight.
Regards.
Jun 23, 2011 | Vulcan LG300 Deep Fryer
Pilot lights fine, but when i turn the heater to low, pilot seams to cut back and burner does not light
it sounds like ur gas pressure regulator is starting to fail......it is either built into ur gas control or in line with the gas control
Jan 14, 2011 | Dyna-Glo RMC-8001SS Heater
I have a dyna-glo model rmc-40lpt, the pilot light is hard to light up, most of the timr I must use a match to light it....after its lit , the burner bar will fire up just fine , high or low but the flame...
are you saying it lights back to the orfice ?? if so i would say the pilot needs cleaning out a long with the burner which could be blocked with dirt or fluff and at the airports to the burner , and the ignition could need cleaning ,
Sep 26, 2010 | Dyna-Glo Heating & Cooling
Hi,dyno glo heater.as long as i hold the pilot in the down position the light will stay on, the minitue i release it shuts off??
The thermocouple from the burner flame port to the gas valve is bad. Shut your gas supply off, unscrew the small fitting with the small copper tubing coming out of the gas valve. Follow that tubing up to the burner and disassemble the pilot light end from the burner. Home Depot has a good selection normally or you may want to go to a furnace supply. It shouldn't be more than 10 or 15 dollars for the new one. Reinstall, turn the gas back on and make any adjustments to flame location at the burner.
Jan 20, 2010 | Dyna Glo "" Natural Gas Heater Mn200tba
Bosch tankless hot water heater 1600H
it sounds more like the ignitor thats messing up, if you are able to remove it and get a new one that would probobly do it for you
Nov 07, 2008 | Bosch 1600H-LP Liquid Propane AquaStar...
Napoleon 36" Zero Clearance Top/Rear Vent Natural Gas Fireplace with Black Door Logo
579 people viewed this question
Top Napoleon Pool & Spa Experts
paulcarew
Gene Haynes
Dan Webster
Dan Webster
Are you a Napoleon Pool and Spa Expert? Answer questions, earn points and help others
