Question about HP OfficeJet 6210 All-In-One InkJet Printer
Copying with 4" solid black vertical stripe
When copying from the glass or the tray it copies with a solid 4" veritcal black stripe and the other half of the copy is fine. I need serious help :<
  • 215 Answers
What about if you print from computer or do an internal print like a self test? if print looks good on those, you most likely have a scanner problem, which is the mechanism under the glass.
razors
Posted on Jan 12, 2009
I have black vertical lines on my copies. how do i fix this?
when printing? if so check and or replace the drum unit. when copying from the adf? if so clean the slit glass. when copying from the platen glass? if so clean the ccd/scanner assembly
Jan 07, 2016 | Kyocera FS-3640MFP
Officejet 9600: vertical lines (4) in center of page when copying using ADF. No lines when copying from glass. I tried the cleaning procedures on your trouble shooting pages. They did not help. How ca
John:
When using the ADF, the scanner doesn't move. The long rectangular platen glass on the left side of the machine is used, not the large glass. I believe that if you clean the long, thin piece of glass on the left side of the platen, your lines will disappear.
May 21, 2014 | HP Officejet Pro 8600 e-All-in-One -...
Samsung CLX-6220-FX vertical lines when scanning and copying
The reason for such lines if they appear only on scans/copies from the automatic document feeder (adf), but not on regular scans and printouts is that there is dirt on the small glass stripe next to the scanner area that is used for scanning from the adf. Just clean that glass stripe and the lines should go away.
Jan 21, 2014 | Samsung CLX 6220FX - multifunction fax /...
HP 3030 ALL IN ONE. WHEN COPYING OR FAXING FROM TOP FEEDER A FULL LENGTH VERTICAL BLACK LINE APPEARS. WHEN COPYING FROM GLASS OR SENT FROM COMPUTER NO BLACK LINE.
Clean the ADF glass. That's the skinny glass strip at the left of the flat bed glass. There is a speck of dirt on it. Line the black line up with the glass, to get a general idea of where to clean. Damp lint free cloth
Aug 01, 2011 | HP LaserJet 3030 All-In-One Printer
SCX 4826FN everything that goe in through the top feeder (scans, copies, faxes) comes out with a solid vertical black line on the paper. All other printing jobs that pull paper from the tray are ok. It...
This black line sounds like it is definately coming from the ADF scanner glass. This is the thinner strip of glass that is located just to the left of the large original glass. You can verify this by making a copy from the large glass instead of using the feeder on top. If the copy comes out clean then it is definately the scanner glass. Just clean the glass well with glass cleaner and a soft cloth. This glass is only used when copying/scanning using the top automatic feeder
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 04, 2010 | Samsung Office Equipment & Supplies
HP OfficeJet J5780 Vertical Black Line Prints when copying or scaning only. Cleaned rollers and changed black ink cartrigde. Still problem.
Have you tried cleaning the document feeders Scan Glass? (small glass under doc feeder ~ 1" by 9") Most times there is dirt spot on this glass, causing a shadow on scans and copies.
Try copying from the large glass by lifting doc feeder / platen cover and manually placing original. If no line copying or scanning manually from large glass, then small scan glass is deffenitely the culprit. Hope this helps.
Sep 07, 2009 | HP Officejet 5780 Printer
BROTHER MFC 7420 PRINTER SOLID VERTICAL LINE...
Open te lid and look at the glass. You have dirt or white-out or something on the thin strip of glass to the left. Clean that glass!
Oct 07, 2008 | Brother MFC 7420 All-In-One Laser Printer
Panasonic Fp7735
just make sure you cleaned all mirrors, **** glass, and glass of discharge lamps. if you sure that when you copy a lighter image and the black line is also ligthens, those parts i mentioned are the only parts that concerned with.
Jun 28, 2008 | Panasonic FP-7735 Black and White Copier
Gestetner 9940 Fax machine
okay it sounds like you have something wrong with the scanner which could be one of a few things.start by really looking close at the black stripe you need to make a copy of something with text across the entire black stripe. try both laying a sheet on the glass and throught the document feeder. what you are looking to see is if it's still able to scan the text and just is very dark in that area or if it's solid black with no text being exposed. one means that either your scanner is being blocked in that area due to dirt, white-out, smudges on glass, dust etc. the later being a diffective scanner.. I would clean glass paying close attention to the 1 " **** glass on the left that's what the machine uses to scanning with the document feeder. if you haven't solved it yet and you Must then lift the document feeder open, be sure machine is off. remove 5-6 screws securing the 2 guide plates for the glass, before doing so notice there is a gap between the two peices. the **** glass is for using the document feeder the other is orginal glass, they are two pieces so be careful when lifting the glass and clean both sides, then while you have the glass out, very gently hold the shiny mirrors just below and very gently slide to the left, there are 3 mirrors that may need to be cleaned using glass cleaner on very soft cloth, doing this ever so gently.
I hope this helps.
Thank You,
Mikey
Apr 05, 2008 | Office Equipment & Supplies
Copying with page feed results in a vertical line on every page
There must be a strip of glass about one inch wide, next to
the large glass. There is the problem !
Clean that strip thourougly. When you use the feeder the pages
are scanned thru the small strip of glass.
Mar 26, 2008 | Canon PIXMA MP780 All-In-One InkJet...
HP OfficeJet 6210 All-In-One InkJet Printer Logo
115 people viewed this question
Seeker5211
Seeker5211
