Question about Samsung HT-Q100 System
Ht-qx100 fan replacement
Hi does anyone have an "exploded view" diagram of how to replace the cooling fan to the rear of a samsung ht-qx100 surround sound system ? Thanks, Jon
SOURCE: Samsung HT-q45 replacement cooling fan (back right corner)
http://www.partstore.com
Posted on Jun 21, 2008
SOURCE: samsung surround sound wont connect up properly to samasung plasma tv
i have a plasma samsung 42 inch and i dont know how to connect my jacks red,white, yellow from the dvd to the plasma and what channel should the plasma be on to see the dvd ???? thanks anthony
Posted on Jun 01, 2009
chipsandnuts
  • 70 Answers
SOURCE: Samsung HT-TWZ312 surround sound probs
With the home theater system off, press the 0-1-3-5 buttons in that order on the home theater's remote control.
Power on the home theater system.
With the wireless module on, press the [ID SET] button on the back of the wireless module for five seconds.
If your home theater continues to display rear check after you have tried the steps above, call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
Hope this helps!
Posted on Jul 08, 2009
SOURCE: Samsung Surround Sound - DVD Player making noise
Samsung HT-TZ312 Theater System keeps flashing 'fan check' when i turn on and shuts down after two minutes.
Please Help
Posted on Jun 09, 2010
A Samsung Home Cinema HT-X715T
The fan is probably the problem. Those devices have high-powered amplifiers in them that generate large amounts oh heat. The fan(s) cool these amplifiers. If the overheat, the system shuts down in a protective mode to prevent damage. If the problem persists for too long, damage can result. Replacement of the fan may be all you need to do to get the device operating again. As far as ease of replacement, most fans are fairly easy to access. Depending upon whether is a plug-in or solder-in will determine level of difficulty. Also, size and mounting must be considered, but usually there are acceptable alternatives when replacing original fans. Just be sure that you have the right specifications (A/C or DC, polarity, voltage level). Rotational speed can vary somewhat, but you need adequate airflow without incurring too much noise.
Jan 15, 2016 | Samsung HT-X715T Theater System
I had an F1 Code on my Jenn Air WW2780B Double Wall Oven, and turned both ovens on to heat up, which they did, and the F1 code never came back after that... so far. Could it be fixed?
Hi, This code is an indication of a fault that exist within the actual relay board. It is malfunctioning at this time, and should be replaced asap, if possible.This relay board is located inside the unit, mounted on the cooling fan shroud. Once replaced, the F1 code will be cleared automatically.
Relay board part number: Y04100261
Click here to view an exploded diagram of the cooling fan shroud, with relay board attached. The relay board is labeled number 9, and the shroud is labeled number 1
Oct 27, 2009 | Ovens
Hope this helps!
Jul 05, 2009 | Samsung HT-Q100 System
Cooling fan stopped working.
http://www.samsungparts.com/search/search.asp
try to check all the accessories for your unit here
May 30, 2009 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
Samsung Surround Sound - DVD Player making noise as if the cooling fan is catching on something
Please Help
Apr 29, 2009 | Samsung HT-TZ312 Theater System
I would like to know how to replace rear brakes on A SUZUKI ATV
http://www.bikebandit.com/suzuki-atv-lt160em-1991-rear-brake/o/m6348sch244430
Rear brake schematic for a 1991 LT160EM I'm assuming its the one your requesting.
Apr 27, 2009 | Suzuki VZ 1600 Marauder Motorcycles
Speaker Problems
push the "sound edit" button on the remote, it will bring up things like, bass, center spkr, rear spkrs.. change the volume control on the rear spkrs.
Apr 09, 2009 | Samsung YP-U3 MP3 Player
Samsung HTDS610 Home Theater System power wont stay on!
I have the same problem.
I did my research and this is the solution:
Your HT system is overheated and the fan is not working. Just replace the fan and you will be good to go.
Ken
Aug 06, 2008 | Samsung HT-DS610 System
Samsung HT-Q100 System Logo
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
