Question about Tyco Rc Turbo Pro Wheelie Cycle
Out case of battery started melting
While in use there was a burning smell and when I checked the battery it was really hot and part of the outer casing was melting. I taped it up with electrical tape & tried to recharge, but it won't recharge. What went wrong? This was only the second time my son used it.
    Genius:
  • 1,605 Answers
Chekc the bettery charger (alternator), it is nor regulating, the battery is over charged.
Posted on Jan 12, 2009
Car was running, electrical wire burning smell, starter makes grinding noise, with the car running, stop the car, starter keeps making grinding noise, with the car turned off, ABS and trac control
You have the polarity of the battery backward somewhere. Did you replace the starter and hook it up backwards. Difficult but possible. Check your positive and negative on the battery itself.
Nov 23, 2015 | 2001 Mercury Grand Marquis
When I drive my 2005 ford escape I sometimes smell something burning?
Either it is due to heat from engine I.e. burning dripped oil or clutch issues.incorrect use of clutch I.e. Slipping it or resting foot on it will cause the clutch fluid to burn and waft into the car interior.i once had a burning smell issue that was due to a bin liner getting stuck underneath the engine which caused it to melt and emit a terrifying smell that caused a few days of anguish.
May 05, 2015 | 2005 Ford Escape
Electrical burning smell coming from control panel on westinghouse dishwasher
Had the same issue with a 903sa. Strong burning smell. Continued to run for a while then just died. Opened the control panel (4 screws holding the plastic part at the top of the door on - open the door to access).
Mains feed into the controller was totally fried. Case was all melted. Very nasty. There was nothing obvious on the Board other than a mains resistor that looked like it had been pretty hot at some stage. The three pin mains connector (at least I think it was 3 pins) was just a big, charred bit of goop.
Feb 09, 2014 | Westinghouse Dishwashers
Engine died burning smell
If the smell is like burning oil or really hot coolant. you may have killed the motor. If it smells like burning plastic ,look for shorthing wires around the exhaust manifold battery, alternator or place that a wire could be burnt. If a rubber smell check for belt failure.
Jan 19, 2013 | Toyota 4Runner Cars & Trucks
Black and decker firestorm 12V charger has melted the battery
There are no parts available for these tools. The Firestorm line of tools were involved in a recall around 2002. It is extremely hard to find any Firestorm tool around anymore and ever rarer to find any that work. Most of the problems were centered around melting plastics and some involved smoke and fire.
Aug 26, 2012 | Black & Decker Black decker Firestorm...
Smell
Hello, In most cases when you have a burning smell a simple fix is your lint lines are dirty. A lot of time when your filter or your hose that goes out the back (by the wall) gets dirty it gets hot and starts to burn. There have been some cases where it will catch on fire, so always make sure lint filter and hoses are clean. Other forms of burning smell can be the dryer belt is waring out or loose, Kind of link when a vacuum cleaner belt gets worn and starts slipping and burning rubber smell. AND Finally could be the main barring that could be going out.
My advice start with simplest first, check vents and lint filter and go from there.
I hope this helps Mike.
Apr 07, 2012 | Kenmore Dryers
The unit works as of right now...but there is a smell of something burning
Quite often, if you smell like a plastic burning smell, one of the capacitors is faulty, and should be checked immediately. Quite often the compressor start capacitor, will get hot and start to melt. Have it checked by qualified technician or electrician, as they are dangerous and can give a fatal shock if not experienced with handling them, even when power is shut off. $20-$30 part, and 1/2hr. labor should take care of it. The cover on roof unit, has to be removed to access the capacitors, so watch for bees, wasps, when you do so. Make sure power is off at breaker panel.
Aug 01, 2010 | Coleman Heating & Cooling
There is a strong chemical burning smell coming from the fridge/freezer but it still seems to be working ok at the moment, the light is on and still feels cold, any ideas what this could be?
if the smell is very sweet something like peardrops, could be poystyrene packing. check for cable chaffing where it enters cabinet.replace mains cable completely. if mains cable outer cover is getting too hot it will smell as above WARNING polystyrene gives off cyanide gas over 120c/when burning do not inhale(only had 1 freezer melt in 30 years it was set on purpose)
Feb 07, 2010 | Refrigerators
Tyco Rc Turbo Pro Wheelie Cycle Logo
115 people viewed this question
Top Tyco Toys Experts
john h
ray gallant
Robert Reed
Level 1 Expert
Are you a Tyco Toy Expert? Answer questions, earn points and help others
