Question about Canon imageRUNNER 400S Copier
Canon Imagerunner 400 S
Is it possible to make the default for copy in "Black" only. We are trying to limit color copies, but are in a situation where we cannot issue Dept IDs (where you can turn color copies off).
    Sniper:
  • 54 Answers
Plese send m/c model number
Posted on Jan 21, 2009
How to change the power on default copy mode form color to black & white.
Hello Gary
On the main copy display your device is probably set to the factory defaults which means that when you press reset the device is in "AUTO COLOR". Touch the "AUTO COLOR" tab on the screen and a drop down menu will show. Select "BLACK AND WHITE". Now press the "ADDITIONAL FUNCTIONS"key. Select COPY SETTINGS located at the top right. Scroll down till you see STANDARD SETTINGS and select it. Press STORE. You are fixed!!! Please let FIXYA know I helped. :-) SPINAL
Jun 17, 2011 | Canon imageRUNNER C3380i Color Copier
How to set the default copy mode on a Canon irc3380 so that it starts up in black & white copy mode rather than color?
First adjust main screen as you want if to be (ie black and white mode). Once you have your default selected go to additional functions. Go to the copy selection and with in that list there is the section to save default settings. Now when you restart machine B/W and all other setting will be default. Good Luck
Jun 16, 2011 | Canon imageRUNNER C3380i Color Copier
DEAR SIR, MY CANON IR 400 MACHINES COPY IS TOTALLY BLACK .I WILL NOT HAVE ANY TYPE OF KNOWLEDGE . PLEASE GIVE THE ANY RESOLUTION, FOR GET CLEAR COPY OR ANY TYPE OF FUNCTION IS USE FOR CLEARING...
I will tell you the problem but you need Technician. First try cleaning/replace the flash rom or change tthe Camera together with the CCD Board.
May 11, 2011 | Canon imageRUNNER 400S Copier
Tried the solution to set black as the default color on the Canon ir c3200 that was on your site, it says to set as B/W on screen, only gives Auto Color Select, Full Color and Black as choices. Says to go...
might be able to do this through your remote user interface {the copier ip address} go to internet expolrer and type the ip into the address bar and look around for settings under additional funtions
Mar 26, 2010 | Canon imageRUNNER C3200 Copier
How do I sent my Canon ImageRunner C3220 to copy in black and white as the default?
First set it to B/W on screen then in additional functions /copy settings/page down to store settings then store and reset to quit.
Nov 24, 2009 | Canon imageRUNNER C3220 Color Copier
Default Setting Change?
you need to set you initial copy screen up as auto colour select then go into copy settings and store them like that.
Jun 02, 2009 | Office Equipment & Supplies
Need to set default for black/white copies not autocolor
set the machines control panel to the settings that you want and then press the PROGRAMS button and choose set as default and the screen will always be as you set it.., Good luck
Apr 30, 2009 | Canon imageRUNNER C3200 Copier
Set for copier to make balck ink copies no color
on the lcd screen upper leftarea touch the area where it says auto color then set it to black. then touch add function copy settings scroll to the one that says standard setting it will ask you if you want to set the setting then set it in . the default screen now should stay in black
Jan 30, 2009 | Canon imageRUNNER C3170I Color Copier
Copying from Colored Paper
No..The exposure will only give you an overall lighter or darker copy.. Dave UK
Feb 23, 2007 | Canon ImageRunner C-3170U Copier
Canon imageRUNNER 400S Copier Logo
67 people viewed this question
old marine
old marine
