I want to convert measurements (in feet and inches) to metres
E.g.what is 15 feet 2 inchea in mwtres
  • 1 more comment
  • Anonymous Mar 30, 2014
    trying to measure my refridgerator in cubic feet
  • Anonymous Mar 31, 2014
    wanting to know how to work out what the cubic meter is when werking in feet like a 6by 4 trailer.
  • Anonymous Apr 01, 2014
    what is the volume
  • 1,525 Answers
4.63296
Posted on Jan 12, 2009
500g=?lbs = ?kg
Posted on Jan 07, 2010
Measurement of an acre against hectar
Hectare is a metric surface area measure of 100 metres by 100 metres.
An acre is defined as "the area of 1 chain by 1 furlong (66 by 660 feet), which is exactly equal to 1?640 of a square mile, 43,560 square feet, approximately 4,047 m2, or about 40% of a hectare." wikipedia.org
To convert acres to hectares, multiply the acres by 2.4711.
Good luck,
Paul
Hectares to Acres conversion
Oct 23, 2017 | Office Equipment & Supplies
Conversion PSI to NM
The conversion is from inch pounds to Newton Meters
The factor: 1 Lb-Ft = 1.35582 Nm.
The direct quote: boltscience.com
Torque is a measure of how much twisting is applied to a fastener. The units used to measure torque are in the form of force times length.
The metric (SI) unit of torque is the newton metre (Nm). In inch units, torque is usually measured as Lb-Ft (pounds feet) or Lb-In (pounds inch). The Torque Converter Calculator will allow you to convert Nm to Lb-Ft or Lb-In or vice-versa. The calculator uses the conversion 1 Lb-Ft = 1.35582 Nm.
HOPE THIS helped
Torque Units Conversion Online Units Converter
Oct 25, 2016 | Cars & Trucks
I need the Linear feet: It measures 24" tall, x 10" thick, x 15 1/2" wide. Can you help?
linear feet is a length measurement as to how long it is --example : a piece of timber 20 feet long is 20 linear feet
the measurements you have provided will give a cubic feet measurements which is a volume measurement. so convert all the dimensions to feet , multiply all together and that will be your volume
May 03, 2016 | Luggage & Travel
How many square meters in 90,000 linear feet of 41.3" wide material?
First, we need to determine the number of square units in the Imperial system. We can choose to do the calculation in feet or inches.
Let's do it in inches first. There are 12" in a foot, so we multiply 90,000 by 12 to get 1,080,000 linear inches. Multiplying this by 41.3", we get 44,604,000 square inches. We can convert this to square feet by dividing the number of square feet by the square inches in a square foot. Since a square foot is one foot by one foot, or 12 inches by 12 inches, there are 144 square inches in a square foot. Dividing our previous answer by 144 will give us 309,750 square feet.
Converting to square metres. An inch is defined as 2.54 centimetres ("cm"). Thus, there are 2.54cm x 2.54cm in a square inch or 6.4516cm^2 in a square inch.
Using the 44,604,000 square inches we got above, and multiplying this by 6.4516, we get 287,767,166.4 square cm. There are 100 cm in a metre, so there are 100cm x 100cm in a square metre. So there are 10,000 square centimetres in a square metre. I get 28,776.7 square metres.
There are 3.280839895 feet in a metre. So there are 3.280839895 x 3.280839895, or 10.76391042 square feet in a square metre. Taking 309,750 square feet and dividing by the 10.76391042 we get 28,776.7 square metres.
Good luck.
Paul
Jan 08, 2016 | Office Equipment & Supplies
How do I do feet and inches calculations on the Casio FX-115ES Plus? For example, how can I do calculations like 10'-3" + 5'-4" + 11'-11" without having to convert the inches to feet?
Calculators work to base '10' not base '12', so you'll have to convert. the S.I. unit of measurement is used for calculators which is metres and they are base '10'. The metre was calculated by a french bloke who got the calculation wrong, but they still use it. Feet and inches are better.
Jul 22, 2014 | Casio fx-115ES Plus Scientific Calculator
Inches to cubic feet
Inch is a measure of length and cubic feet is a measure of volume. There is no conversion between them. It's just like trying to convert inches to gallons, it can't be done.
Now if you want to convert cubic inches to cubic feet, that's possible. Since there are 12 inches to a foot, there are 12-cubed or 1728 cubic inches in a cubic foot.
Jan 10, 2014 | Office Equipment & Supplies
Square feet converted to square metres
Simply square the conversion factor between feet and metres to get the conversion factor between square feet and square metres.
One foot is 0.3048 metres, so squaring that gives one square foot is 0.09290304 square metres.
Aug 20, 2013 | Casio Brand New-Fx-991es Plus - Scientific...
How many feet is available in 1000 square metres?
A foot is a measure of length while a square metre is a measure of area.
One foot is exactly 0.3048 metres, so a square metre is about 10.7634 square feet. Thus 1000 square metres is about 10,764 square feet.
Aug 28, 2011 | Office Equipment & Supplies
Can you tell me how much 30 cubic metres would be in feet and inches thanks
A foot is exactly 0.3048 metres and an inch is exactly 0.0254 metres. So, 30 cubic metres is about 1059 cubic feet or 1830712 cubic inches.
Aug 09, 2011 | Office Equipment & Supplies
275 people viewed this question
jasbo
jasbo
