Question about Linksys EA6500 Dual Band AC Gigabit Wireless Router
Changing the local ip address of a linksys ea6500
The default ip address is 192.168.1.1, how can I change it to another?
  • 196 Answers
SOURCE: Multiple WAN IP Addresses with a Linksys Router
Yes, however we recommend using the following procedure is the only way you can do so without a block of IP addresses. The example below is for instances where you have multiple public IP addresses that are not in block form. For our example the ISP has given us 3 Public IP addresses. One goes to the FTP server, Web Server, and the Router. You can setup the router for whomever your ISP is. If you have a dynamic IP address and you're unsure on the setup, please see the article on setting up the router with a static IP address. If you have a static IP address please our article on setting up static IP addresses with the router, and it will describe how to setup the router with a static IP address. Once the router is setup, it will provide the 3 PC's (In our example) with internet access. The remaining two public IP addresses should be assigned to the WEB Server and the FTP server. Note - The Web and FTP servers will not be on the Local Area Network of PC-1, PC-2, and PC.
Posted on Feb 16, 2006
shaky120
  • 310 Answers
SOURCE: How to set a static IP address in Windows behind a Linksys Router
Sorry mate but you have kinda lost me here, if you need a static IP address for the internet you need to contact you isp and they will provide you one, if you want to set your machine to set IP Address just go into properties for local network connection and use somthing like 192.168.1.1 255.255.255.0 and leave the dns to obtain. but you wont be able to set a internet static ip address by doing this, only way is to contact your isp.. All the best John
Posted on Mar 08, 2007
  • 84 Answers
SOURCE: factory settings for a Linksys RV042
connect your router your computer via LAN cable
click start on windows
click run and type CMD
On the DOS command prompt type IPCONFIG/ALL
look for the gateway address, that is the IP Adress of your router
Posted on Feb 11, 2008
Joed911
  • 4338 Answers
SOURCE: I need to change network name/ssid. the ip
Linksys reset
reset your router back to the default factory settings. This is done by simply holding down the reset button located on the back of the unit for at least 30 seconds. Once the router has been reset, it must be reconfigured. Using your web browser go to URL address http://192.168.1.1. You will then be prompted to login to your router. A log-in screen asking for the password will automatically appear. At this time enter the default password “admin”, in lower case letters into the password field. The username field may be left blank at this time. (Note: both the default username and default password are set to “admin” on some of the newer Linksys router models).
Posted on Sep 06, 2009
govinda123
  • 2260 Answers
SOURCE: upgraded dsl modem to westell G-90-610015-20 and
if you connect the computer directly to the modem, without any router , does it work?
Make sure that your computer will be online when connected to the modem.
If you are not online through the modem, then you should have the correct user name and password for the ISP.
Click Here for step by step solution
Posted on Oct 31, 2009
How to change password to my router
How do I change the Wi-Fi Password on my router? ' D-Link ...
www.dlink.com/.../routers/...routers/.../how-do-i-change-the-wifi...
D?LinkMethod 1. Step 1: Open an Internet browser (such as Internet Explorer) and enter http://dlinkrouter.local or http://192.168.0.1 into the address bar. Step 2: Enter ...
Changing your wireless network password - Linksys
www.linksys.com/cz/support-article?articleNum=135554
LinksysHow do I change the password of my router's wireless network? ... NOTE: If you have a Linksys Smart Wi-Fi Router (EA9200, EA6900, EA6700, EA6500, EA6400 ...
Dec 29, 2015 | Computers & Internet
I need to get into my nat settings
All Linksys routers have a built-in web-based setup page that allows the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or4 ).
Accessing the Router's Web-Based Setup Page
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Windows XP
Windows 7
NOTE:
If the password of the router has been changed, type the router's new password in the Password field instead.
The router's password can be changed by:
i. Running the router's setup CD. Click here to learn how to download firmware.
ii. Changing it on the router's web-based setup page. Click here to learn how to change password on the web-based setup page.
Unable to Access the Router's Web-Based Setup Page
Reset your router for 30 seconds. Try accessing again using the default IP address "192.168.1.1". If you are encountering problems accessing the router's web-based setup page, click here.
Related Articles:
Setting-Up WPA Wireless Security on a Linksys Router
Changing the Wireless Network's Name (SSID) on a Linksys Router
Setting-Up a Router with DSL Internet Service
Downloading at Linksys by Cisco Support Site
Nov 09, 2010 | Linksys Wireless-N WRT150N Router
Linksys no longer appears on my laptop for some reason. how do i restore it. i can't go on line without it?
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 08, 2010 | Linksys WRT160N Wireless Router
How do I find Key# for a new PC. The PC with the actual LInksys Admin Program was on PC that crashed and couldn't be fixed
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 07, 2010 | Linksys Wireless-G WRT54G Router
Forgot user name and password
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 06, 2010 | Linksys Wireless-G WRT54G Router
When i try to install my Linksys wireless G, it ask for a password. I don't know it and it won't let me proceed!
Step 1:
Step 2:
NOTE
Step 3:
Nov 04, 2010 | Linksys Wireless-G Broadband Router
My ip address should be 192.168.1.1 in the setup tab inlynksis but isn;t how do i change it manually
The default IP address of the Linksys router is 192.168.1.1.
First check the IP address of your computer.
START ==> RUN ==> type cme and hit OK==> you will find the command prompt. Type " ipconfig " in the command prompt and hit ENTER.
Now you will find the IP address and the Default.
Default Gateway is the IP address of your router. with this number you can open the set up interface of the router. and change the IP address of your router.
For more info about networking Click Here
Oct 07, 2009 | Linksys Wireless-G WRT54G Router
My router doesnot see me internet
What lights are lit on the router? Is the internet light red or green? Can you access 192.168.1.1 (the usual I.P. address for Linksys routers)? Do you have a static or dynamic IP address from your ISP? (You need to go to the router page to change it but the default is DHCP.) With some cable modems and all DSL service, you may need to change the local IP address to 192.168.2.1 and then save the settings. Next renew your computer's IP information (either from the command prompt or by rebooting) and then point your browser to the new address for the router. One way to check this is to see if you have change the settings is if you see an address of 0.0.0.0. If you do change the settings you may need to power down both the modem and the router before trying the internet connection again. The default router user name is left blank and the password is admin. You can change these at the web interface.
My reference is http://www.linksysbycisco.com/US/en/support/WRT54GC
Also double check that your computer sees the internet without the router, just in case you have a bad router.
Aug 26, 2009 | Linksys (WRT54GC) Router
Linksys EA6500 Dual Band AC Gigabit Wireless Router Logo
445 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
