Question about Denon DN-HS5500 Turntable
How do i set up the dn-hs5500 - Denon DN-HS5500 Turntable
3 Suggested Answers
SOURCE: need help with setting up my denon 5500
does denon cames with its internal hard drive..or i have to buy one
Posted on Sep 03, 2009
SOURCE: Denon DN-HS5500 Cue Slip
Try changing the platter speed from 33rpm to 45 rpm The menu for this should be in the preset section on the player.... Good Luck
Posted on Dec 10, 2009
How Do I Reset Date/Time on a Stealth Cam STC-U732IRNG?
SET TIME AND DATE:
1. Switch the camera to the ON position.
2. Press the [MENU] button to enter menu settings screen.
3. Press the [UP] or [DN] button until the word PIR blinking.
4. Press the [OK] button to confirm.
5. Press the [UP] or [DN] button to scroll through different setting modes
until the word TIME blinking.
6. Press the [OK] button to choose the Time settings.
7. Press the [UP] or [DN] button to adjust the Minute setting and press [OK]
to confirm and move to the Hour setting.
8. Repeat to set Hour and then press [OK] to confirm and move to Date.
9. Adjust the Month, Day and Year by using [UP] or [DN] button. Each time
you finish an adjustment you must press the [OK] button to confirm and
move to the next field for adjustment.
10.Once done, the word - dEL - will be blinking.
11. Press the [MENU] button to exit and start using.
Nov 16, 2014 | Cameras
Denondn hs5500 to traktor
Hi Jeib,
Here you go. Check out this review and search engine.
Ion Ion Audio Ittusb Turntable Reviews Ion Ion Audio Ittusb Turntable...
Here is the direct review from a variety of You tube sources with your product in their hands. Take a look.
Denondn Hs5500 To Traktor Reviews Denondn Hs5500 To Traktor Product...
Since your question is generalized. I still wanted to share this forum www.product.info is the place to go become a member and join in the forum. Go for it.
Fare. Well.
May 17, 2014 | ION Audio iTTUSB Turntable
How to assign a dn number to M7324
press Feature *0 (button inquiry) then press the intercom key.
When a set is installed it automatically gets an intercom #
Mar 19, 2014 | NorStar M7324 Telephone
How to factory rest memorex blu ray dvd player modle MVBD2520
Hello
Select the General menu. Select
RESTORE SETTINGS using the Navigation ( UP or DN) buttons (1),
, then press the ENTER button (2). Select YES using the
Navigation (Up / Dn) buttons 1 and press the ENTER button 2
again to restore the settings. Select NO to leave the settings
as they are.
Feb 17, 2012 | Memorex MVBD2520 Player
I installed a cd rom and it keep saying device disconnected the rom is good cause i try it on a next player need help regards knox
My suggestion is to go to the website, and look for the support forums. Have a great support community.
May 09, 2011 | Denon DN-HS5500 Turntable
Oct 06, 2009 | Denon DN-HS5500 Turntable
Need help with setting up my denon 5500
Jun 13, 2009 | Denon DN-HS5500 Turntable
The 5500 doesn't recognize the files on my ipod, which are mainly cd's impoted to itunes, so i converted all the files to MP3 but it still isn't recognizing the files. what do i do?
Actually there are 2 possible solutions to your problem. When you plug in your Ipod or USB drive into the Denon HS5500 the machine will put a file on the drive called "Denon_DJ". This file needs to be deleted each time you add new mp3's to your ipod or usb device or your new files wont be shown.
The second has to do with what type of mp3 you are using and what sample rate it was created with.
For instance I record music with my computer and keyboards. I like to record in 96KHZ because it sounds so much nicer than 44.1k. Well the Denon wont read anything created with a sample rate higher than 44.1K . I downloaded a song from a DJ friend that was recorded in 48KHZ and made into a 196k MP3 file. The Denon wouldn't play it because it is not 44.1. Check your manual or check online.. the Denon reads 44.1k 320kbs and lower files only.. (Bad Denon)
You may also want to avoid what are called Variable Bit Rate files. Most files you download online are ripped at a variable bit rate. The Denon will play variable bit rate Mp3's .. But you will not be able to save cue points or save memos to the system. I found this out the hard way. So. I took all the files I had created that were VBR and put them into Audacity with the Lame MP3 plugin and set the bitrate to 320kbs and now I can save memos.. But everytime I put the USB flash drive into my pc and put new songs on I have to delete the Denon_DJ folder.. Its sad too because thats where the HS5500 stores it's playlist files... :( Bad Denon. They should have asked me to write the software.. xD
I hope that helped you..
Apr 12, 2009 | Denon DN-HS5500 Turntable
Need an instruction manual for denon dn-1800f?
http://www.denondj.com/Assets/Dimages/Products/Manuals/cd709d3d980d4f2d8013fea6e875c68d.pdf?ts=062556
Dec 13, 2008 | Denon DN-1800F CD Player
Denon DN-HS5500 Turntable Logo
16 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
