Question about Eaton ARC FAULT CIRC BREAKER
Eaton 20 amp branch feeder will not reset after pushing the yellow reset button in the panel
Have 3 of them. Pushed all three reset buttons and none will reset after turning off and back on. Is there something else I need to do?
3 Suggested Answers
  • 101 Answers
SOURCE: My Eaton 20 amp Arc fault breaker tripped during a
Has this problem been corrected yet? If so, great! If not, contact me and I'll help you out. In most cases with these circuit breakers, they need to be reset first (press in the yellow button). And then turn off the circuit breaker, and turn it back on. They're a little temperamental (pain in the neck)! This should allow everything to go back into its original order. Good Luck with this, and feel free to contact me again if this solution hasn't corrected it yet. - Jim
Posted on Mar 30, 2010
  • 5603 Answers
SOURCE: Have three 20 amp Eaton
If you disconnect the load wires on the breaker and it will not reset, the breaker has a fatal flaw.
IF the breaker ONLY fails to reset with the load wires connected EITHER there is a wrong connection like servicing a shared neutral 3 wire cable from the breaker, or there is an electrical fault OR there is interference from a source that couples radio-like noise onto the wires to this.
Posted on Mar 12, 2011
The test button on my 15 amp eaton breaker does not reset when pushed.
spring inside has come off, or their is no power going to it.
Feb 25, 2015 | Eaton Electrical Supplies
I am now looking for a way to reset the control panel. I understand there is 2 buttons that needs to be pushed and I am wondering which buttons and if the dryer needs to be plugged in to preform this. ...
    • 1Press and hold "Drain & Spin" for three seconds to release the child lock, if the keypad is locked.
    • 2 Press "Pause/Cancel" twice to cancel the current operation.
    • 3 Turn off and unplug the washing machine.
    • 4 Wait several minutes before restoring power to properly reset the machine.
    • 5 Select a new wash setting and push "Start" to begin.
    • 6 Contact Kenmore as necessary if the problem with the washing machine persists. Contact information can be found in the owner manual for your appliance.
Jun 08, 2014 | Kenmore Elite HE4 Electric Dryer
Built-in oven-- clock unresponsive
you have to push 2 of the buttons at the same time. usually - and + for 3 seconds. you will see the display change. good luck.
Jun 01, 2017 | Zanussi ZBF360 Electric Single Oven
When I turn on the copier the screen says Xerox with a yellow line on the bottom and 1/6. it stays like that all day. none of the buttons work nor does the touch screen. it won't copy. I have pushed the...
Please once again shut it down. And re-install the cartridge. Also then reset it without cartridge. And if this does not work then simply its time to send it to company service station.
Thank you.
Oct 02, 2013 | Xerox Office Equipment & Supplies
Have three 20 amp Eaton Arc Fault Breakers Type BRAF and two have tripped and cannot reset. What is the solution? Do I need to replace?
Mar 12, 2011 | Eaton ARC FAULT CIRC BREAKER
Flashing lights on Maytag dishwasher
Check whether the door is getting closed fully. Try pushing little hard. If the door close switch problem it may work.
Contact service for help if u can not proceed further with electrical circuits. Micro-controller board to be checked!
May 18, 2010 | Dishwashers
How do I reset a Eaton breaker with a tester on it?
This is a GFI (Ground Circuit Interrupter) Breaker. So you need to turn off the circuit breaker first. Then you need to reset the GFI (yellow button) by pressing in the button. And then turning the breaker back on. Now, with some GFI's, you need power on to reset them. So if this is the case, reset the circuit breaker by turning it off and then back on. Then press the yellow button in, and it should hold. Then you should have power restored. I hope this works for you. If not, feel free to contact me again. Good Luck!
Mar 27, 2010 | Eaton 20A ARC FAULT BREAKER
Oil changed - oil reset button was pushed in forever and still flashes - however, the language will change when pushed - followed directions and when the oil reset button flashed pushed the stem forever...
im not sure how it work but i have a colbolt and in order to reset the light you need to turn key on and pump the gas pedal three times it worth a try
Jul 09, 2009 | 2007 Hummer H3X
Microwave will not respond to any button being pushed
The service man just left it was the 20 amp line fuse. Have one on order.
Jun 11, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
Eaton ARC FAULT CIRC BREAKER Logo
73 people viewed this question
Top Eaton Electrical Supplies Experts
john h
Steve
Are you an Eaton Electrical Supply Expert? Answer questions, earn points and help others
