Printing error, On paper I got Bad file, Kip code : WOVUFUWU
Kip printer is connected with network when I print the drawing I got the print "Bad file, Kip code : WOVUFUWU" Thanks.
  • 27 Answers
SOURCE: InDesign Printing problem; service error 49.4c02
This is a solution which has been suggested on another site, this has not been tested by myself so no promises.
1. Turn the printer off.
2. Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in slot J1.)
3. Remove all EIO devices from the printer.
4. Turn the printer on.
5. If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each device.
6. Replace a DIMM or EIO device if you determine that it causes the error.
7. Remember to reconnect all cables that connect the printer to the network or computer.
8. If the error persists, replace the firmware DIMM.
Hope it helps, as I said, not tested personally.
Posted on Jun 19, 2008
  • 162 Answers
SOURCE: won't print on the photo paper
You didn't mention what paper you're using so for simplicity I'll assume it's an HP paper. When you installed your printer, it installed profiles for the HP papers and associated them with the printer. If you go to the Printers and Faxes folder, right-click on your printer and choose Properties, you'll get a dialog box for your printer. At the top it'll say something like HP Photosmart D7200 series Properties. Click on the Color Management tab, it'll show you a list of profiles associated with your printer. Your paper profiles will be named something like HP PS D6100_7100_7300-Advanced Photo. Don't worry about the names or selecting them, as long as they're listed you're OK. If they're not listed you'll need to re-install your printer software. Close the Properties box and the Printer and Faxes window.
Now go to LR, select your photo and go to the Print module. Scroll down the right panel until you get to the Print Job Header at the bottom. If you don't see any choices, click the triangle and open it up. Uncheck Draft Mode Printing and Print Resolution. Under Color management, click the triangles to the right of Profile:. This will open up a list of all paper profiles visible under LR. If you don't see your HP paper profile, click Other and it will list all the paper profiles on your system. Find your HP paper profiles and click the box next to each, this will make them visible in the LR drop-down. Hit Close and select the profile for the paper you're using.
Now click the Page Setup button, that will bring you to a dialog box where you can select your printer, page size and layout. Make these choices and then click on the Properties tab for your printer.
Now things get a little sticky... The HP driver has an infuriating habit of changing settings you've already made when you change something else. You'll come up in the Printing Shortcuts tab, ignore this and click on the Features tab. It's been quite a while since I used this printer so I may be wrong about the right order to do things, but here's what I remember: First, select your paper size. Click the Borderless box if that's how you want to print or uncheck it if not. Your Paper Source should be Main Tray for 5x7 or larger, Automatically Select for 4x6's that go in the top holder. Select Best or Maximum dpi for Print quality, then choose Paper Type, set it for Other Photo Papers since you'll be selecting the paper profile from LR. Hit the radio button for Print At Actual Size, go to the bottom and turn Photofix off.
Now go back to the top and click on the Color tab, select Print In Color and under Color Management, select Application Managed Colors.
Now go back to the Features tab and make sure nothing has changed. If it has, reset it, check the Color settings again, check the Features settings one last time. Then hit OK and you're back in LR.
Before you print, go over to the left panel and hit the Add button at the bottom. This will save all your settings and lots of time and aggravation by not having to go through the whole process again next time you want to print something. Name your profile with at least the size, layout and paper type you've set up and it will show up under User Templates. Then the next time you want to print on the same paper at this size, you just have to select this template.
Now hold down the Alt key, hit Print,
Posted on Nov 24, 2008
SOURCE: Error: Printing data is inaccurate, printing processing is stopped
I got the same error with another type of sharp photocopier AR-M257
My error, I was installing the wrong driver.
I installed the Sharp driver with the PS at the end.
You can download from here depending the version of the Windows you have
http://www.sharpusa.com/products/business/copiers/business_copiers_drivers/
Good luck!!
Posted on Dec 05, 2008
prashanthcl
  • 460 Answers
SOURCE: Ricoh printer printing error: undefined offending command: mz
it is a logic card problem. so pls checked it from service center.
Posted on Aug 25, 2009
Danieldesmon
  • 56 Answers
SOURCE: Canon MP190 not printing using only black ink, color ink finished
hai there...you try press the reset and colour button in the same time...the printer will back to normallyl
Posted on Mar 01, 2010
J01 error when printing from d
Are sure the paper in the draw is in the same orientation as you are selecting on you computer in the print properties landscape in in draw and portrait on the computer will not work or vice a versa. Using bypass tray or paper draw? Check the guides in each draw snug up against the paper?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 01, 2014 | Minolta Di152 Laser Printer
How can I resolve a problem on Laserjet printer 4525 with an error 49.2fa7?
#The error might be caused by a
network connectivity problem,
such as a bad interface cable, a
bad USB port, or an invalid network
configuration setting.
#The error might be caused by the
print job, such as an invalid printer
driver, a problem with the software
application, or a problem with the
file you are printing.
#Upgrading the product firmware
might help resolve the error. See
the product user guide for more
information.
For upgrading the Firmware. go to hp.com, download the firmware, read the read me file before uploading the firmware...
May 12, 2014 | HP COLOUR LASERJET CP4525DN Printer
Xerox Phaser 7800DX not printing one particular file; error code 389.601.00
Make sure your are using Postcript Driver & not the PCL6 driver and that the document page size and the paper page size in trays are the same.
Dec 26, 2013 | Xerox Phaser 7800/dx Workgroup Laser...
Error code 49.ff01, hp laserjet 4250tn
This error is usually caused by a bad formatter board
SOLUTIONS
1. Press CANCEL JOB to clear the print job from the printer memory. 2. Turn the printer off, and then turn the printer on. 3. Try printing a job from a different software application. If the job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or print job, contact the software vendor for assistance.) 4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. 5. Turn the printer off. 6. Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in the lowest DIMM slot.) 7. Remove all EIO devices from the printer. 8. Turn the printer on. 9. If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each device. 10. Replace a DIMM or EIO device if you determine that it causes the error. 11. Remember to reconnect all cables that connect the printer to the network or computer. 12. If the error persists, replace the firmware DIMM. 13. Replace the formatter.
Feb 22, 2011 | HP REFURB LASERJET 4250TN PRINTER
Error code 49.FF01 can't turn on or off
A firmware error occurred ( This error is usually caused by a bad formatter board)
SOLUTION
Feb 22, 2011 | HP LaserJet 4250tn Printer
900 service RIP software error - how do you fix it?
Please try to do the following steps. Remove parallel, USB, and/or network connections andrecycle the printer's power so that it is operating as a standalone machine. If it powers up to the Ready state, print the MenuSettings page(s) from the Utilities Menu. If the printer works without error while disconnectedeither from the network or a locally attached computer, there is a strong possibilitythat a corrupted file or network/parallel/USB connection is causing theerror. Look for patterns such as aparticular file or a particular workstation generating the error when data issent to the printer. Clear the print queue and connect all cables back andturn the printer back on. Resubmit the print job(s) and try printing again b> If the error will not clear, please take note of thesecondary code and contact Lexmark Technical Support.
Feb 07, 2011 | Lexmark T522 Laser Printer
Error during print 'Remove all paper from bin'
HP Laserjet 4250 Network connected laserjet printer.
Steps to be follwed to set right :
01. Please check in number of desktops or laptops it connected.
02. Give proper IP Address in the Desktop or Laptop where it has to be orignally installed.
03. Being a network printer, lot of desktop or laptop users might have printing job iniated.
04. Right click the printer properties which is available bottom right hand corner ikon and delete or cacel all printing jobs.
05. The original desktop or laptop where the IP Address created will be rebooted. System should be restarted.
06. Try to print now to close this solution.
07. Still the problem persits, kindy contact local HP Authorised printer service engineer to set right this issue.
Have a nice working day.
Jul 17, 2009 | HP 4250 Monochrome LaserJet Printer
My Inkjet 2800 won't print DWG. (CAD) files. I have no problem with other files; word, excel, photos ... When I try a CAD file, the printer shows "printer error."
Does the printer show you Printer error with number and letters following it? Prior to printing, check the 'print preview' to see how the layout of the printing is showing. If the CAD drawing is not adjusted to fit on the paper in the printer, you may from time to time get a printer error.
Feb 03, 2009 | Computers & Internet
422 people viewed this question
k24674
jasbo
jasbo
