Question about Husqvarna Sewing Machines
How do I replace the light bulb on a Viking Emma sewing machine?
In trying to replace the light bulb, there doesn't seem to be any way to get at it - no cover to unscrew. The bulb is located above the needle.
  • 16 Answers
SOURCE: changing light bulb on viking designer 1
when one faulty, both do not work. replace faulty one & both will then work.
Posted on Jun 28, 2008
  • 3 Answers
SOURCE: I have a Husqvarna Emma sewing machine. The
I was able to gain entrance into the area by taking out 1 screw (star head), slightly pulling on the plastic compartment to cause a small opening. I then tilted the machine and the needle fell out. The screw is located on the rear of the sewing machine, right behind the bobbin compartment. A flat head screw is also needed to "Pry" open the plastic.
Posted on Apr 19, 2009
  • 10865 Answers
SOURCE: I have a Husqvarna Viking Quilt Designer. I need
Hello there. Here is the link to the husqvarna viking help desk
http://www.husqvarnaviking.com/US/2821.htm
They are wonderful. Tell them your model number and your problem and they will talk you through it.
Posted on Jun 11, 2009
  • 152 Answers
SOURCE: Sewing thick fabric and machine won't send it through
Sergers are not really meant to sew very thick material. The blades have a maximum amount of range, or thickness that they can reach to cut. If you go outside that range, get ready for a big repair bill! You can break loopers and even the needle plate when you "push" a serger. My advise would be to use you sewing machine for the, "pounding" work. The type of material matters too, A thick Quilt like fabric can be sewn becatuse it's not dense material. A thinner harder denim could max out at 3 layers because of it"s hard finish. If the fabric you're sewing isn't dense like, you could just need new knives.
Posted on Oct 14, 2009
  • 111 Answers
SOURCE: how do I replace the
For the one light bulb that is located over the free arm. Put your finger nails on the back edge of the light cover and pull slightly forward and downward, and the cover will come off. You can then pull the bulb straight out. For the light bulb over the needle area. You must pull the light cover straight down toward the pressure foot to get access to the bulb.
Posted on May 03, 2011
Where can I purchase a light bulb for Viking 6000, model 6440 serial # 5145009?
Try your Viking dealer or search the internet for Viking sewing machine replacement parts.
Nov 17, 2016 | Sewing Machines
The light turns on, but the machine doesn't.
it would be a good time to have the machine and the foot pedal checked.
Apr 25, 2013 | Husqvarna Viking 1
Manual for a husqvarna viking victoria sewing machine
I do not see this manual available for a free download. You can try at a local Viking dealer; they will be able to order it or may have it in stock. Otherwise, this site has it http://www.sewingworld.co.uk/Husqvarna_Viking_Instruction_Books_And_Manuals.html (Scroll down; the Victoria manual is listed between the Emma and Platinum 770 manuals).
I hope this helps.
(I know that a local Bernina dealer got us the manual to an older Serger (obtained used) for minimal cost when we provided the model and serial number.)
Oct 18, 2011 | Husqvarna Viking 1
I have a Singer Sewing Machine #9444. There is no electrical getting to my machine since the light doesn't work and the foot pedal doesn't work after I turn on the machine
Try replacing the light bulb or rerouting the wire so it won't be affected by the light bulb or the foot pedle. Becarefull though because if you rerout the the wireing in the foot pedle you're taking away the off/on swich so it'll stay on. You may want to open up the foot pedle and see if there is anything loose, not conected or broken. The pedal is used as an on/off swich so it may just be stuck in the off position and not making contact when you press down on it so it won't turn on.
If you can't fined a blulb for it by the way you can disconect the socket where you screw it in and install a new one. Make sure the new one will fit in the same hole though. Then it should be easy finding a bulb for it. PLEASE MAKE SURE THE MACHINE IS DISCONECTED BEFOR YOU DO ANY OF THESE THINGS. Good luck!
Sep 30, 2011 | Sewing Machines
I have a Viking 6440 (36 years old), and the original light bulb has burned out. I can't get the bulb out! Any suggestions?
Hi anon3...
Spray a little wd-40 on the socket and tap the outside of the socket...wait about a half an hour and try to unscrew it...if that does not work keep screwing the bulb out until you twist the bulb out of the socket...then take a pair of need nose pliers and grab the edge of the bulb and twist it toward the center do the a few times around the outside of the bulb
Please take time to rate me thumbs up
Sep 18, 2011 | Husqvarna Viking 1
How do I replace the light bulb on my husquevarna viking #1 sewing machine?
May 02, 2011 | Husqvarna Viking 1
Need to know the light bulb number for a Fressia 415
For the Husqvarna Viking Freesia 415 sewing machine you need the small, push-in type. Here's the specifics:
Light Bulb, 12V 5W #979603-001
Here's a link to a site that has a pic of bulb and also sells them:
http://www.sewingpartsonline.com/light-bulb-12v-5w-979603-001.aspx
Dec 11, 2010 | Husqvarna Freesia 415
Sewing Machines Logo
48 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
