Question about Kitchen Appliances - Others
Need manual for chefmate waffle maker model WM-77
Model WM-77
SOURCE: Nordic ware Belgiam Waffler maker
This is how I use the nordic ware...
1.Heat pan on medium heat on one side until temp gauge is in the middle. Dont turn pan at all when pre-heating
2. Open pan and coat bottom with a little butter.
3. Flip pan over and add butter to bottom side that has no butter.
4. Add batter quickly so butter doent burn. Add semi-thick batter in pan and only let batter run so there is about 1 inch of space left on the edge.(This space will fill with batter when you close the cover)
5. Temperature gauge should stay near the middle at all times.
6. Do not open the pan to check the batter waffle color or your crispy waffle will turn soft
7. Let waffle cook on first side until the steam that comes out from the side slows down to about half of the amount of steam that came out when battle was first put in. (Should be about 2 minutes)
8. Turn waffle pan over and DON’T open the pan.(you haven’t opened the pan once to look)
9. Let cook until steam reduces (Takes about 2 minutes)
10. Keep an eye on the temp gauge
11.Remember the first waffle always takes longer to cook than the second and third waffle.
12. If you have the urge to open the pan. Open the cover slowly. If it doesn’t open up easily then it is still rare and wait one minute to open. If you need to look, you should only open the pan after you turned it over. Once you open the pan, leave it open. If you close it the cripy top will turn soft.
13. Remember trial and error
Posted on Aug 25, 2008
SOURCE: removing top of waffle maker to clean it
The other night my wife had the same issue. My thought had always been to wipe it down using a wet cloth with simply hot water and rely on the extreme heat of using it to sterilize it.  My wife decided instead to disassemble it.  The problem is that it is not made to disassemble and she bent some parts and broke others and stripped out screw heads.  It is clean now, but can not be reassembled without extracting stripped screws and replacing some parts. My advice to you is - don't try to disassemble it. The factory went to great lengths to ensure that you don't.  Instead use a soft cloth dampened (not dripping wet) with the hottest water you can.
Posted on Dec 29, 2008
  • 47 Answers
SOURCE: Toastmaster waffle maker - have no manual
http://dl.owneriq.net/4/4d7525b4-d3f8-43f8-b5a9-03673112a1e9.pdf
Here it is, you may have to join but it is free!
Posted on Jan 04, 2009
greenspan
  • 1734 Answers
SOURCE: Need instruction manual for oster waffle maker model 3871
Ask here, it seems they can get you every Oster manual
Posted on Jul 03, 2009
SOURCE: I need a manual for a salton waffle maker wm4
There is a site that posts PDF files of manuals for all manner of things..manualsonline.com.
Here's the link for the Salton Waffle maker, they have several versions:
http://kitchen.manualsonline.com/search.html?q=+salton+salton+waffle+maker
Posted on Aug 05, 2009
I need a Manual for a Vintage Rival Waffle Pizelle Maker Model 9705....not 8703..!!! My eyes r awful....I apologize
No problem, as the result is still the same. There are no vintage model manuals available online. Also I just read that Rival won't supply a manual, quoting "we want our customers to buy a new model". And you are short of a Z in Pizzelle :>)
Rival Waffle Pizelle Maker Model 9705 Google Search
Jan 23, 2017 | Rival Kitchen Appliances - Others
Purchase manual
Appears to be the same thing with a different model number.
http://www.salton.com/files/documents/WM-1075%20Booklet%20EN.pdf
Jul 25, 2014 | Salton WM8BEL Belgian Waffle Maker
Need copy of Instructions manual for Hamilton Beach Waffle Stix Waffle Maker model R2601
The closest I could find to your model number is the 26010. Hopefully this is of some assistance:
http://www.hamiltonbeach.ca/use_care.php?mc=CS
If this is not correct perhaps you could repost; confirming your model number and advising on the country of purchase.
May 13, 2011 | Hamilton Beach 26008 Waffle Maker
Manuel for a wm-4 belgian waffle maker
http://www.salton.com/en/service.asp
The unit has an automatic thermostat and is very simple to use. Honestly instructions aren't even really needed. You can use the link above to contact Salton to receive the information your inquiring about.
Thank you,
Lee
Feb 04, 2010 | Salton Kitchen Appliances - Others
Waffles sticking in a Salton wm-4.
Salton wm-4! one of the oldest waffle maker. The waffle is generally known to be difficult to clean. I would only advice you should always grease the plate before use. This helps make cleaning easy. You can also check our post on The Best Waffle Maker in 2017 The best waffle maker 2017 Easy buying guide Kitchenutilitypro
Sep 24, 2017 | Salton WM4 Waffle Maker
Lost manual chefmate tr440
You can get one here. There is a $1.85 charge for the whole manual but you get the manual instantly. Hope this helps.
http://www.scribd.com/doc/18027869/Chefmate-Bakery-Oven-Model-TR440-Instruction-Manual-Recipes-TR-440
Aug 15, 2009 | Chefmate TR 7000 Bread Maker
No instructions for used Sunbeam#3856 waffle maker
download here:
http://www.retrevo.com/support/Sunbeam-3856-manual/id/952ag122/t/2/
Apr 30, 2009 | Sunbeam 3852 Waffle Maker
You stated you still have the manual for chefmate model cm725?
I had great success in finding what I wanted for my breadmaker at http://breadmakerpartsemporium.ioffer.com/. They have manuals and parts for most breadmakers at very reasonable prices.
Jan 04, 2009 | Chefmate TR 7000 Bread Maker
Kitchen Appliances - Others Logo
372 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
