Question about Bosch 1224VSR 7/8" SDS-plus Bulldog Rotary Hammer
Drill won't hammer
It sounds like it is hammering but when i put pressure on it it just drills
comax
  • 154 Answers
SOURCE: Bosch 11247 Hammer drill works
Usually replacing the o-rings on the piston, striker and Impact bolt will solve any hammering issues. That is considering there is no damage to the mechanical parts in the hammer mechanism.
Posted on Apr 13, 2009
comax
  • 154 Answers
SOURCE: i have a bosch rotary hammer 11245evs and it was
They are filled with a special grease that comes from Bosch. It sounds like the impact bolt or the striker pin in the unit are not moving the way they should. These are the pieces that work together to create the hitting action. About all that can be done now is the unit has to be dismantled to get those to pieces moving again. Bosch makes what they call service packs for all thier hammers. They have all the o-rings and grease to get your hammer working again. A Bosch service center can supply you with the kit. Ask for P/N 1617000225, or they can take care of it for you.
Hope this helps
Posted on Apr 16, 2009
rowdy45176
  • 2176 Answers
SOURCE: my hammer drill won't hammer.
when was the last time serviced?? If not recently then you would need to replace the o rings and look for other sticking/worn parts. Give me the exact model number and I will try and find you a breakdown and a rebuild kit. They are not that bad if you are handy with tools and take your time. Let me know
Posted on Mar 21, 2010
  • 10 Answers
SOURCE: I have a bosch hammer dirill that won't chip nor drill but motor run fine
Hi, have you tried the various positions on the front part of the gearbox behind the 'chuck'?
If so, then Im afraid it must go in for repair. These are not an easy fix and personally I would recommend you ask for a 'quotation' as it could be just something simple to do with the 'Gearbox' selector, but it could also be something a lot more serious within the Gearbox.
Good Luck & Best Wishes, John..
Posted on Jul 03, 2012
  • 885 Answers
SOURCE: hammer drill won't hammer
Without knowing which model you have: Most Bosch hammer drills use a plastic connecting rod to attach the piston to the rotating spindle. These are a common failure item and fairly easy to replace.
Posted on Jul 19, 2012
How do you put the drill in hammer mode
turn the selector handle to hammer or move the slide button across to hammer
remember that it will not hammer until you put pressure on the drill bit
May 29, 2016 | Hammer Drills
When hammer or hammer drill action is selected hammer action is not working
The ring of the impact bolt in front inside the locking sleeve where the chisel is driven on can be blocked (also broken part ) but not to see until you remove the parts .
Jan 11, 2016 | Hammer Drills
Repair hilti te-17 hammer drill
Sounds like the clutch or gears have gone.
Feb 27, 2014 | Hilti Drills
Bosch 11241EVS won't hammer
Not all bits for hammer drills are the same as the slots in the sides of the shanks are different between makes . There is a standard between hilti and ramset drill bits but other makers have different ideas Check out the shanks of your drill bits and look for the slot that holds in the bit.
May 26, 2013 | Bosch 11241EVS SDS-Max Rotary Hammer
My dewalt drill won't switch to hammer
I had the same problem. You need to manipulate either the speed or the torgue. In some cases both. Sometimes the drill/hammer feature gets stuck in between the two an this is the only way to fix it unless taking it apart but I wouldn't do that yourself. Best to take it back to the dealer or service shop
Feb 28, 2013 | Dewalt DC223KA Heavy Duty 24 Volt 7/8 Inch...
Hammer drill won't hammer
Jul 18, 2012 | Bosch Drills
Jul 03, 2012 | Bosch 1" Sds+ Bulldog Rotary Hammer Drill...
Makita bhp453 chuck screw wont loosen
The chuck screw on drills is put in with lok-tite and is reverse threaded. You need to get the screwdriver on it firmly and turn it clockwise, as you are, with strong, constant pressure until it breaks free. Don't let the screwdriver slide out of the screw slot, if you round off the screw head you'll have to cut the chuck off. If it still won't break free, try putting the drill in a vice or use a screwdriver with a hex nut molded into the driver shaft so you can use a wrench for some more torque.
Mar 11, 2012 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Dewalt dw511 hammer drill won't hammer, only
The hammer inside the drill head are most likely damaged ans/or broken, it is likely the best thing to do is just replace the tool.
Feb 15, 2012 | Dewalt Drills
DRILL FUNCTION BUT NOISY IN USE
Depending on the type of hammer drill you have, the noise should only be heard when you are applying pressure to the material you are drilling. Some drills have 2 bump plates that cause the hammer action. This is what causes the noise. It kind of sounds like the gears are stripped but the chuck still goes just fine. You do not need to grease this, it will make this noise regardless. However you may want to take a look at the gears and make sure they are ok. You may want to add grease if the old grease is broken down or there is not enough in the gear housing. Larger hammer drills have a piston and actual hammer. Such as the Bosch Bulldog series. If it is this type and there is noise when you are in drill mode there may be more serious problems.
Sep 24, 2009 | Drills
Bosch 1224VSR 7/8" SDS-plus Bulldog Rotary Hammer Logo
42 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
