Question about Xerox WorkCentre M-24 Color Copier
SOURCE: Xerox M24 Transfer Belt Torn
http://www.xrxgsn.com/admin/public/2990/m24consumableext.html
Posted on Sep 09, 2009
SOURCE: a code error 116-321 appears on my xerox m24,what
uff
desconecta el hd de 2.5 en la ess pwb y prueba...
Posted on Dec 02, 2009
SOURCE: upon booting I get this error, A fault has
Sounds to me like you need a drum or one of the other routine maintenance items.
The way to find out is to press your machine status button, then look under supplies. You will probably find that a drum life has expired, the IBT cleaning roll or fuser life have expired.
I am sure if you look there one of those "supply" items has reached its end of life.
In the same area under the machine status , there is also a section there for active messages and fault codes. Make sure you look there. If you have additional questions please ask.
If there is an active message or fault code, e-mail me at rak458@aol.com. Just put Xerox M24 in the subject line please.
Posted on Feb 24, 2010
Testimonial: "Thanks"
SOURCE: Hello, I get this code
That is the fuser exaust fan. It either is running to slow or not running at all.
The board detects a current difference and reports that fault code. Really common.
The fan part number is 127K29340.
To replace it you remove the right side cover, top cover on and the rear cover. You have to take off the shroud around the fan which is only 2 screws and replace the fan.
You can try removing the fan, cleaning it well and lubricate the bearing in the center. But that never is a permanent fix. Will work as a fix until you get a new fan.
Posted on May 27, 2011
Oct 31, 2017 | Xerox Office Equipment & Supplies
Mar 19, 2015 | Xerox Office Equipment & Supplies
Aug 13, 2014 | Xerox Office Equipment & Supplies
Mar 10, 2011 | Xerox WorkCentre M-24 Color Copier
Nov 20, 2010 | Xerox WorkCentre M-24 Color Copier
Aug 31, 2010 | Xerox Workcentre M24 Color Copier
Feb 24, 2010 | Xerox WorkCentre M-24 Color Copier
Nov 11, 2009 | Xerox WorkCentre M-24 Color Copier
Nov 02, 2009 | Xerox Workcentre M24 Color Copier
