Question about Maytag HYE3658AY Electric Dryer
Dryer will not come on
The dryer will not come on. It has no power to it. I checked the breaker and the plug and it all seems to be fine. I was going to check the fuse but do not know where i could locate the fuse to it. Can you help! Thank you
  • dave3787 Jan 14, 2009
    i have checked the thermal overload it has continuity, i even put a jumper wire and bypassed the T.O.F. and still nothing
    Sergeant:
    Champion:
  • 262 Answers
RIGHT OFF TO THE LEFT OF THE VENT THERE IS A CREME COLORED FUSE WITH TWO WIRES ON IT IF IT IS MADE BY WHIRLPOOL WHIRLPOOL OWNS MAYTAG START THERE AND LET ME KNOW......BILL
Posted on Jan 12, 2009
Our dryer just suddenly stopped! We have no light and it seems no power. We checked out fuse box and everything is fine there. Does this dryer have a fuse that would cause all electricity to stop?
Hello
No .Double check your cicuit breakers.If your dryer is electric there are two breakers.Switch all the way off then all the way on to reset.
I if ok then suspect door switch .It kills everything and if stuck ,the light too.
Happy hunting
Jul 28, 2011 | Kenmore 600 7962 Dryer
Not heating, everything else seems to work fine
Hello there and thank you for choosing fixya
Here are the main things to check when this happnes
1. Is the circuit breaker thrown? Can you read 240 volts at the wall plug with your voltmeter? Don't go by breaker conditions, they lie!
2. Are the wires at the power cord burned where they attach to the dryer?
(2nd most common failure)
3. With your OHM meter, check the electric heating element for continuity.
4. Check all thermostats, fuses and the thermal cut-off for continuity.
Mar 13, 2011 | Kenmore Dryers
I have had my whirlpool dryer about 4yrs + (geq9800pw2) has always worked fine. Last week it started tripping ckt breaker toward the end of drying cycle. As of this morning, it blows ckt breaker...
leave off the oven and a/c breakers and plug dryer and reset the breaker. if not tripping occurs then one at a time trip back the oven first. if no trip then trip off again and trip the a/c. if no trip then trip the oven back. if trip you may have a wire problem. if dryer trip any way then possibly you have a short in dryer. check the heating element wires,power cord at the dryer side(terminal block).
Feb 14, 2011 | Dryers
HE3t Kenmore dryer runs fine but suddenly stopped producing heat
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Dec 31, 2009 | Kenmore Dryers
No power to selector panel
Sounds like the control panel may be dead. If you cannot get any lights to come on at all on the front panel, its probably a goner. You can check the voltage coming out of the control pc board via the schematic inside the dryer panel. I have this same exact problem. I replaced the control board 3 times because the panel seems fine if i plug it into an external power supply but will not work when plugged into my dryer. I have my jumpered and running off of a circuit breaker.
Dec 18, 2009 | Whirlpool GEW9868K Electric Dryer
Dryer has no power
Have you manually reset your breaker? Sometimes breakers can seem fine but they actually aren't. Physically turn the breaker off and then back on. If this doesn't work, you will need to find out if your particular brand and model has a fuse that needs to be replaced.
Apr 08, 2009 | Kenmore 64602 Electric Dryer
Maytag Ele. Dryer Model # lde7334a
Heating element
Thermal fuse
Wiring
Mar 31, 2009 | Dryers
Old Frigidaire apartment size (24'0 top dryer stopped working.
check the breaker i know the washer works so how come the dryer works on 220volts if one side is out the washer will work but not the dryer if that is not it check the door switch the unit also has a thermal fuse that could be out there is no reset button
Nov 30, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Dryer runs, tumbles clothes, but does not heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Heating element
Thermal fuse
Wiring
Aug 09, 2008 | Maytag SDG4606A Gas Dryer
Maytag HYE3658AY Electric Dryer Logo
52 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
