Question about Brother DCP-7020 All-In-One Laser Printer
Brother Printer 2250dn ghost printing after refil
SOURCE: Brother MFC-210C is ghosting!
Hiya,
I had the same problem this evening, so I went onto the Brother support site.
This link solved my problem:
"How can I improve poor print quality?"
http://tinyurl.com/27xv4r
Hope that helps.
-areacode514
Posted on Feb 26, 2008
JackHeath
  • 1049 Answers
SOURCE: Brother MFC8500 not responding
Ack, double negative. Bad English...
I've had this same issue. It seems to start happening when the device enters sleep mode, it's like the printer just vanishes. When you remove the printer completely and reinstall it it works again until the printer goes into sleep mode then it disappears again. I've had two do this and once they start I haven't found any way to stop it from happening periodically and with ever increasing frequency until we finally get rid of them. Suspect some level of i/o controller or board failure.
Posted on Dec 10, 2008
  • 526 Answers
SOURCE: Brother MFC-8840D ghost image
most likely you have a bad drum. it can also be the fuser.
what is the distance between the first word and the duplicate that follows it.
Posted on Apr 21, 2009
  • 265 Answers
SOURCE: Brother 7020 laser printer just started printing
Try to replace the high voltage board
Posted on Dec 11, 2009
SOURCE: brother printer ink tanks not resettinmg to full
I had the same problem;
Try this
1. Turn the printer off (push off button)
2. Open cover and remove all the ink cartridges. Just out of the clip will be sufficient
3 With cover still open, Turn printer on again (push on button)
Message should come up to replace all the ink cartridges ( in sequence probably). Follow the instructions
4. When all the cartridges have been replaced it will prompt you to close the cover.
5. Close the cover and it will ask if you've replaced each of the cartridges one by one
6 Use the up arrow (Menu,up arrow, down arrow, set) to indicate 'yes' for each one.
The printer will then do a clean cycle and everything should be ok from here
Good luck
Posted on Sep 22, 2010
Brother hl 2250dn toner error
you are probably out of toner. have you replaced the toner?
Dec 17, 2014 | Brother Office Equipment & Supplies
Drum light indication and error light indication is on
Hello, Sounds like you need a new drum or maintenance kit for the laser. You need to call your maintenance provider for repairs or take to a computer/office supply repair shop.
Dec 05, 2014 | Brother Hl-2250dn 2400 X 600 Dpi Laser 26...
Why does brother 2250dn drumlight keeps flashing after replacement
When replacing the drum on the Brother Machines you need to reset the machine's drum counter. To do this, with the front of the machine open (Where the Drum and Toner unit go) press and hold the go button till all the lights (Toner, Drum, Error and Ready) are lit then release the go button. Close the front of the machine and your drum counter has been reset.
Aug 05, 2014 | Brother HL-2250DN Laser Printer USB Cable...
Ghost printing
Some time the ghost is because of the drum unit, replace it, other times if the environment is really wet I mean raining for several days I have the ghost problem as well, caused by the paper humidity.
Jun 04, 2013 | Brother HL-4040CN Laser Printer
I replaced the black ink with a full refill and my printer won't print anything at all. It is telling me that the cartridge is full. What can I do?
You need to use only cartridge brother original,if you use refill cartridge the printer is not printing.You need to replace the print head of the printer because you use refill cartridges.In the future use only genuine Brother cartridges.If a have been useful please give me a vote :)
Mar 14, 2011 | Brother MFC255CW All-in-One InkJet Printer
How i refill ink in the printer mfc240c?the printer is from brother
If you refill the cartridge you broken the print head (clogged),and need to change.Do not refill the cartridge!!!!I'm a technician brother :)
Mar 09, 2011 | Brother MFC 240C All-In-One InkJet Printer
Mar 31, 2009 | Brother MFC-8840D All-In-One Laser Printer
Hiya,
Hope that helps.
-areacode514
Feb 23, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother DCP-7020 All-In-One Laser Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
