Question about DeLonghi DEBIGE 2440 Electric Double Oven
Delonghi ESM 460 oven and GHS 260 user manuals needed
Does anyone have the instruction manuals for this oven and hob? Or knwo where I can get them? Someone suggetsted espares but they aren't there. Thanks a lot, KP
  • jacquix575 Mar 04, 2009
    I have no manuel and my mum has rubbed off the temperature setting on the front from cleaning it where can I get a manuel s or some more transfers
    Guru:
  • 395 Answers
Oven wont turn on
I have a delongi oven and hob hob is working fine but the oven isnot im turning the nob on the front of the oven and ignition on lighting is fine after I release the knob on the front the supply turns striaght off no flame no gas nothing
Apr 04, 2011 | DeLonghi Ovens
Where can I get a manual? Can it be downloaded? Thanks
.pdf user manuals can be obtained via steve.richardson@fisherpaykel.co.uk Quoting the exact model number located on the rating plate located on your appliance as detailed below.
Range Cookers
Behind the Drop Down Storage Panel beneath the oven door or on the Oven Chassis behind the door
60cm Freestanding Cookers and Ovens
On the Oven Chassis behind the door
Hobs
On the underside of the hob (any oven or hob situated underneath the hob may need to be removed to gain access.).
Feb 15, 2011 | Stoves Ovens
I have a elecric delonghi oven with a gas hob with 6 burners. the oven does not work at all no heat. the light comes on but no heat. the turkey is stuffed an no hat to cook it HELP PLEASE
if the temp indicator light comes on and/or oven fan circulates then its most likely the heating element. if neither then its thermostat or selector switch...
Dec 22, 2009 | DeLonghi DEBIGE 2440 Electric Double Oven
Delonghi ESM465ST Oven Noisy Fan
If it is a fan assisted oven, then you are likely to have 2 fans, an external cooling fan, and a fan inside the oven for ciculating the hot air.
So to answer your query, yes it is a noisy fan you are going to have to establish which fan.
It could be a worn bearing, or the fan blade has come loose.
If it is a worn bearing, thge only cure is a new fan.
Hope this helps with your problem.
Dec 02, 2009 | DeLonghi Ovens
Have installed Delonghi undercounter stainless steel oven and hob bought from local supermarket. Fan making terrible noise like its touching something. My daughter has same oven and has exactly the same...
Do not disconnevt fan under any circumstances, otherwise it will cause big prob, if it is new, I would take it back, if it is under 28 days old, then they are legally bound to change it` for a new one., if more than 28 days old, then get them to repair it under guarantee.
Please rate my solution.
Thanks.
Aug 24, 2009 | DeLonghi AS670 Electric Single Oven
Delonghi oven grill broken, oven still works?
You will probably find it is the grill element that is faulty, a common fault on your brand of oven, to be certain, you need a meter to test it.
Thanks.
Jul 15, 2009 | DeLonghi Ovens
Whirlpool 30" electric freestanding range, oven does not work
Thanks Mike.
Yes it is the same.
Make sure that the timer is set to manual, and not on auto or the oven will not work..
It should tell you the procedure in your user instructions.
Plz rate my solution.
thanks.
Jan 09, 2009 | Whirlpool RBD305PD Electric Double Oven
I need an instruction manual for Delonghi Proline ESM-465 ST oven
Try http://www.espares.co.uk/datastore/ProductManuals/356312.pdf
That's where I found it. Not easy to find though.
If you need to go direct to the espares website you'll have to hunt around a bit. But try looking out for a small Adobe link on the left hand side when in the ESM465 area.
Hope that helps.
Dec 01, 2008 | Ovens
Temperature fault
Hi there, usually when those knobs fall off as long as you can guess where it would normally be, all functions work the same. In terms of falling off, they are made to come off for cleaning. Also, could I bother you, you dont have the manual for this oven do you? As we need a copy? Thanks a lot, Kerrie.
Sep 17, 2008 | Ovens
Delonghi professional dfs903 cooker
have a Delonghi dual fuel DTC90DF range.
The oven has been temperamental for a whil, working then clicking off so that you had to turn it on again and it would work for a while again. Eventually there was a bit of smoke coming through the hob and it smelt of electrical burning and stopped working all together. It is the main fan oven that is now not working.
Please help
Bev
Jan 03, 2008 | Ovens
DeLonghi DEBIGE 2440 Electric Double Oven Logo
701 people viewed this question
Top DeLonghi Ovens Experts
ashburton
Naftali Haskell
Level 1 Expert
Jason Harris
Jason Harris
Are you a DeLonghi Oven Expert? Answer questions, earn points and help others
