Question about Zanussi Ovens
How do i connect the cable to my zoa 35502xd single oven
NEW OVEN ARRIVED DISSCONNECTED OLD ONE NOW WANT TO CONNECT NEW ONE DONT KNOW WHERE THE WIRES GO ON THIS ONE
  • 87 Answers
SOURCE: oven heats up very slowly and does not get very hot
Check your power to the oven at the terminals where the power cord connects.Should be 220 volts. Also check the terminals of the bake element for loose connections or a burnt wire.
Posted on Jun 08, 2007
  • 114 Answers
SOURCE: oven not heating up properly
You could very well have an electrical problem. You may not be getting the full 220 volts needed to make the oven function correctly. Call a local appliance technician or electrician for service.
Posted on Sep 27, 2007
  • 249 Answers
SOURCE: neff single oven
fan heating heating element gone replace it ;Ire close bye
Posted on Nov 28, 2007
hotuna
  • 288 Answers
SOURCE: 3 wire oven with 2 wire source
Your new oven utilizes 220 volts, but it also has some 110 volt features that need a neutral to work properly. Your old oven was wired without the neutral, probably when the house was built. There are 2 answers to your question. #1, no you should have an isolated neutral or common (same thing) wire, so it should have one. #2, if you connect the white on the new oven to the ground wire it will work. The neutral wires are all connected to the grounds at the breaker panel. Look at it if you don't believe me. The ground is there as a safety to you. if you connect the neutral (the white wire on the new oven to ground) you will be eliminating the safety feature on that appliance. So, I do not recommend you connect the white wire on your new oven to the ground wire out of the wall. But if you do it will work, you will just not have any back up protection if there ever is a problem with the electrical on that appliance. I hope this wasn't too confusing, the answer is you will need to wire the oven properly by adding another wire if you want to be completely safe and within electrical codes.
Posted on Dec 06, 2007
barkencoa
  • 3463 Answers
SOURCE: bosch hba34b520
Yes, it is o/k to have a single oven connected to a 13 amp power supply supplied with a 2.5mm cable.
A lot of single ovens already come with a 13 amp plug fitted, so you can plug it straight into a 13 amp socket.
If there is no covenient socket nearby, then you can wire the 2.5mm cable srtaight into the oven terminal block.
I must stress that this only applys to a single oven and not a double one.
Plz rate my solution.
Thanks.
Posted on Jan 14, 2009
How to hardwire a 3 wire wall to a 4 wire oven
Simply put, it won't work. New oven=white is neutral, black and red are power but not on the same "leg", and green is ground. If you use a meter, black and red should give you 208-230 or so volts. Wires from wall=White is neutral, blank is voltage (probably 120 or so volts) and bare copper is ground. The dual voltage plug can be used for either 125 or 250 volts, not both as required by the new oven. Need an new circuit pulled and wire/breaker matched to new oven power requirements.
Oct 08, 2017 | Ovens
How do i connect this single phase
three wire, or four wire? are you talking about connecting pigtail to oven? more info, or a photo
Apr 17, 2015 | Ovens
Oven Light Assembly wires
does not matter.
Jan 22, 2012 | AEG Ovens
I have a new Defy hob with the colour connections in 4's, but my oven is an older DEFY and has two rows of 6 connectors... please help. How do I connect a new DEFY hob to an old Defy oven?
I have the same predicament. Did you manage to connect your new hob to your old stove? If so, please let us know how to do it.
Thanks.
Mar 04, 2011 | Ovens
Replacing heat elements in oven
To replace oven heat element follow the steps below carefully
Turn off the power to the oven at the breaker box.
  • Step 2 Take out the screws holding the element bracket in place. These will be on the back wall of the oven, or sometimes on the top.
  • Step 3 Pull the element toward you a little bit until you see the wires behind it.
  • Step 4 Unscrew the leads and take the bad element out.
  • Step 5 Hold the new element up while you attach the wires to it. Don't stretch the wires any more than you have to.
  • Step 6 Line up the element while tucking the wires back in. Be sure not to pinch the wires between the bracket and the back wall.
  • Step 7 Fasten the brackets, making sure they're tight.
  • Step 8 Restore power to the appliance.
  • basically to install the elements , place it in the same position as the old one. Connect it the same way the old one was connected, using the same screws to hold it in place. Just about all the other components of an electric range or oven
  • Jan 03, 2010 | Jenn-Air Ovens
    Fan oven not heating but fan and light work
    Most likely the heating element has failed. You need to replace it. It is not a difficult job, you just remove the old one and fit the new one. you will need to undo a few retaining screws and remove the connecting wires from the old one and connect them back to the new one.
    Remember to switch off the power to the oven before working on it.
    Dec 21, 2009 | Creda Ovens
    How to connect a new element
    The wiring has fallen back in behind the back wall. Go in throught the back of the machine and dont turn on the oven as you now have a live dangling back there.
    Dec 09, 2009 | Ovens
    Neff oven internal wiring colours
    red is positive and black is neutral normally on these ovens, dont recall seeing blue and lilac.
    Apr 15, 2009 | Neff B1421 Electric Single Oven
    I need the squematic wiring GE 24" Built-In Gas Oven
    I have the same problem -- did you ever get this question answered?
    Feb 28, 2009 | GE 24" Built-In Single Gas Wall Oven
    Bosch hba34b520
    Thanks.
    Jan 13, 2009 | Bosch HBL 442 / HBL 446 Electric Single...
    Ovens Logo
    103 people viewed this question
    Top Zanussi Ovens Experts
    ashburton
    marley mcelhinney
    Are you a Zanussi Oven Expert? Answer questions, earn points and help others
