Question about Bosch Tools & Hardware - Others
Motor brush spring broke
Looking for a replacement part -who and where would be a good source
  • cd_bowyer Jan 12, 2009
    The unit is a Rotozip
  • David Ford
    David Ford May 11, 2010
    What is the model and brand. If you find this you can try Ereplacementparts.com if not let me know and I will research it.
    Scholar:
  • 58 Answers
Try this site: I hope this works for you.  http://www.rotozip.com/GetSupport/AskandAnswer/Answers/PartsRepairs
Best regards  Michael Mittelsdorf
Posted on Jan 13, 2009
Took my mr coffee burr apart a little spring fell out now the grinder doesnt work where dose the spring go
Im first wondering why u took a good grinder apart ??? could it be that it was working only intermittently ?? if that is so , im betting the little spring is either the spring that pushes the start switch back up when u let go (otherwise it would run forever) or it might be a motor brush holder tension spring , that's most likely why its working only intermittently the brushes are worn down and need replaced , a neet hack 4 this is to use electric drill brushes ! I found they fit and can be sourced from a well stocked hardware store !!
Dec 21, 2016 | Coffee Makers & Espresso Machines
Do they have a reset button?
No. Check the power cord and see if it has full voltage through it. If so pull the motor brushes (black caps top and bottom of tool) and see if they are ok. If the brush spring is collapsed you'll need to replace it.....if the motor is good!. If the brushes look good the next step is the switch. You can test it with a multi-meter. If not that then maybe the module or maybe the brush holders. If none of that motor trouble. It sounds like a lot to check but it's not difficult. Good Luck!
Oct 09, 2014 | Milwaukee Tool 10 Amp Sawzall Plus with...
What conditions would lead me to replace my motor brush
Motor brushes wear out just like brake pads on a car. And just like a car, if they wear out too far they can cause damage to part they rub against. MBut unlike a car, there are no warning signs. The motor will continue to operate normally right up to the point where you have a problem because you let them wear out completely. They are simple to examine and replace however. Just unscrew the little plastic buttons and you can pull out the brushes. They are almost always made up of a spring (much like the spring in a retractable pen) which is attached to a small copper or brass bracket, which is attached to a small black block, shaped like a very small stick of butter. When that stick of butter gets short enough that the little bracket starts to hit the spinning contact of the motor you will have a problem. Just take them out and look at them. If they look very short, replace them. If you have a new brush to compare to, you will know what very short looks like. But you should also know that it takes a LOT of use for brushes to wear out.
Good luck.
Jul 26, 2012 | Drills
The compressor motor is getting hot, I removed the cover and one of the brushes is shooting sparks when the motor is turned on, the brushes seem to have plenty of pad left and seem to be aligned properly...
If there were a problen with the field or the armature, both brushes would make fire(look at both sides of each brush for spark). Sparking is normal, however heavy blue fire would indicate problem. When one brush is making unusual sparks I would suspect that the spring applying pressure to the brush against the armature has failed. Look at both brush springs and see if there is a color difference or feel the pressure that the springs are exerting. They should be equal. You can push on the brush slightly with wood or plastic tool. To see if there is an improvement. Replace parts as needed. Test the motor with amp meter and compare to amp rating on plate to be sure that there is not a problem with motor. If amp draw is slighly high, check for tight bearing, leaking head gaskets/reed valves or leaking checkvalve at the tank. Good luck.
Sep 09, 2011 | Dewalt D55168 1.8 HP Wheeled Portable...
I have a pride 1170xl with E675HT motors. I broke the black plastic brush holder getting the brush out. Can the brush holder be replaced separately or do I need to buy the whole MOTOR END CAP? I may be...
Mark,
The manufacturer parts manual indicates the following information:
The motor brush caps are available from Pride:
PLSINDV1059 Motor brush cap (Reliance 0003-0035) retail $2.68
The brushes are:
DRVBRSH1000 Motor brush Jazzy (Reliance 0002-6957) retail $36.31
The guys in tech service at Pride (800-800-8586) are always a good resource for the information you may need. If you are exceptionally nice to them they will drop a new brush cap in the mail for you for free.
You can also check with Reliance Motors at their website for information and cross reference for other brushes available based on the Reliance part numbers above.
A good local motor rebuild shop can recommend a comparable (more durable) brush based on the specs. I think you may be disappointed with the pricing of the more durable brushes.
You can try on-line at:
http://www.graphitestore.com/items_list.asp/action/prod/prd_id/255/cat_id/37
Hope this helps.
Feb 06, 2011 | Pride Mobility Products Jazzy 1170 XL Plus
I need new brushes for Powermate Air Compressor motor. Where can I purchase them or do I need to have a Technician install? Model #CL0551109 Thank You J.L. Brooks
Brushes are not listed as a replacement part for your compressor. Not to worry because universal brushes are available at tool repair shops, hardware stores and ebay. Measure your brush and order same size or slightly larger and sand to fit. Dont worry too much about the length of brush as they can be shorter than factory and still work fine (just longer than worn brushes). Some motors have a spring pushing brush onto armature and others utilize the spring attached to brush to make contact. You can cut off wire from back of brush if needed, however if your motor needs brushes with spring attached, find close match and solder your old contact and spring to new brush. Also check for other problems because brushes should last the life of motor on your unit. Good luck
Aug 17, 2010 | Coleman Powermate 27 Gallon Air Compressor
Bosch 4000 tablesaw won't start. Brushes replaced
I found that the remaining problem was a intermittent at the switch, which disassembly and cleaning resolved.
Tilting the motor / blade assembly down allows access from below, to the 3 screws fastening the controller circuit board cover on the brush end of the motor. From there, one can easily test exposed wires for power supply, see that brushes are contacting and clean accumulated sawdust.
Jan 06, 2010 | Bosch Electric Table Saws
Fixing the springs to the carbon brushers to a 24v battery bosch drill
The brushes come as an assembly with the spring and brush in one unit. If your springs are bad you can order a set of brushes. The part number is 2607034901 and they run around $6.50. If your springs are melted looking there may be an underlying problem with the motor, mainly that there is a short in the motor or even switch. If the brushes are just worn and not touching the commutator bars then it is safe to just replace the brush set and you should be ok. Any questions please post back.
Oct 12, 2009 | Bosch 13624 24V Cordless Hammer Drills
Hilti 905 breaker brush change
Two small round threaded covers on side of drill motor. Open and spring with brush comes out, replace.
Jun 24, 2009 | Drills
I need replacement carbon brushes for the motor. I haven't been able to find a source.
Try looking for a power tool repair shop, they usually have some brushes and can order more. I have put Hoover brushes in my Shop-Vac.
Look for some that are close to matching,( spring size,spring length, brush length). If the brushes are a little large they can be made smaller by dragging on a flat file. Carefully fit them so they slide into the brushholder nicely.
I have even soldered different ends onto the pigtails, whatever works----I am a pragmatist!
You could also look for an electric motor repair shop in your area- they have suppliers.
Apr 27, 2009 | Hoover Portapower C2094 Bagged Canister...
Tools & Hardware - Others Logo
323 people viewed this question
Top Bosch Tools & Hardware - Others Experts
Jim Parker
Jim Parker
Awesome12
Are you a Bosch Tool and Hardware - Other Expert? Answer questions, earn points and help others
