Question about JVC HD-52G886 52" Rear Projection HDTV
JVC HD-52G886 TV no picture when watch tv but have perfect picture when watch a dvd
Installed new bulb. Only have a universal remote. Have printed users manual. When i go to the tv input I get nothing but black. Pop in a dvd and put on input 1 and works like a charm. Is there a board that just runs that part? Clueless and stumped?
    Problem Solver:
  • 19 Answers
It almost sounds like a setting issue that might require the proper remote to control. You mentioned "tv input" are we talkin RF/Cable screw on input or rca type composit video input? and essentaily yes to your question all the inputs are microprocessor controlled as well as the entire functionality of the set. You can probably pick up the correct remote for a few bucks on ebay or elsewhere on the net.
Posted on Dec 08, 2012
  • smeyers12137
    smeyers12137 Dec 10, 2012
    It was the remote. It wouldnt let me program Atsc program w a universal one
Shuttle83
  • 1139 Answers
SOURCE: jvc av-56wp74 power up failure
Hello hwkdoc,
What has happened is that your shutdown circuit relay has tripped and it looks like it also may have malfunctioned. This however is not the cause of your problem but a symptom. The cause of your problem is an over-current condition caused by one of the systems in your TV, I would suspect the high voltage power supply or the switching low voltage power supply. These are the first places to look, if they are not the problem then check the convergence correction amplifiers. Right now the shutdown circuit is keeping the TV from coming on. If you do not have a background in electronics I would advise you to have a qualified TV technician analyze and repair your TV.
Thank you,
Shuttle83
Posted on Oct 15, 2007
BMW Rider
  • 232 Answers
SOURCE: jvc hd ila model hd 52g886 red light blinking, and wont turn on
Hi, don`t know if you`ll be able to find this but D9405 a surface mount diode on the main power supply board is a known issue for yours and many other models, it has to be re-soldered not replaced, other joints in area may also need to be "touched up", other than that I had one where connector CN310 was not seated correctly, one side of plug was cocked way up, other than those 2 you may have a bad ballast (board that the lamp is connected to), Be sure that the lamp door is securely closed as they have a switch built into them and if the switch is not closed the set WILL NOT start, hope this helps you out, BMW Rider
Posted on Dec 12, 2007
SOURCE: JVC 56FN97
Make sure the bulb is seated properly in it's hole. It has to be an exact fit or it won't work.
Posted on Oct 16, 2008
  • 5 Answers
SOURCE: Last night my JVC HD-52G886 picture turned dark
SRP-9022A main power board is bad, usually the cp9211 fuse is bad on this board. Board runs about $150
Posted on Jan 12, 2010
  • 5 Answers
SOURCE: jvc hd-52g886 i turn it on but black picture and
your main power board SRP_9022A needs to be replaced
JVC HD-52Z575 tv shows only a grey picture screen. I was watching a channel and tried to change channels and new channel won't come up, only grey screen.
JVC HD-52Z575 52" HD-ILA HDTV-ready rear-projection TV
www.amazon.com/JVC-HD-52Z575-HD...HDTV.../B...
Amazon.com, Inc.JVC HD-52Z575 52" HD-ILA HDTV-ready rear-projection TV ... The picture was artifacted and the color was good, but not great. ... From 5' some minor issues could be seen and the MPEG2 format did show its limitations, but at 10', it was a truly great experience! ... There is no true gray temperature, only high and low.
HOW TO FIX A JVC HD BIG SCREEN TV - YouTube
? 6:38
https://www.youtube.com/watch?v=r4v-xzUpQDM
Apr 11, 2012 - Uploaded by kyle dubb
Did your HD D.L.P. t.v. stop working? This movie clip will showyou step by step how to easily fix your big ...Missing: grey
JVC HD-52Z575 HD-ready rear-projection D-ILA monitor ...
Jan 10, 2016 | JVC Televison & Video
I put a new bulb in my jvc tv and it still blinks red why
take it out and put it back in it may have been put in wrong or something
Apr 05, 2013 | JVC HD-52G886 52" Rear Projection HDTV
My jvs tv the sound works but no picture someone said the flyback was bad
This is a dlp or digital light projection tv. This set uses a bulb. First check the bulb. The bulb can ussally be removed from the set from the back with a screwdriver. do not touch the bulb front. this set does not have a flyback. 90 percent of the time the bulb will shatter when bad.
May 27, 2011 | JVC HD-52G886 52" Rear Projection HDTV
When i turn power on the power light comes on but no picture the lamp light comes on then starts blinking?
The tv projection lamp has not been replaced in this tv like 1 1/2 or 2 years?The tv been on an watches tv like 4 or 5 hours a day?Yes,than the projection lamp life is over.The tv require a new projection lamp.
Oct 12, 2010 | JVC HD-52G886 52" Rear Projection HDTV
My 52' HD television will not turn on, it is a JVC HD-52G887. The blue light comes on but there is no blinking red light. Please help
unplug the tv, then reinstall the bulb,if that doesnt work youll need a tech to help. (dont buy another jvc tv)
May 19, 2009 | JVC HD-52G886 52" Rear Projection HDTV
No sound on my 52in jvc tv
i unplugged my tv and when i turned it back on had picture but no sound and all cards are still in tack.
Jul 31, 2008 | JVC HD-52G886 52" Rear Projection HDTV
Jvc tv
It may be lamp, Look at the lamp and see if there is any discoloration inside, but do not touch the lamp glass. The oils from your hand will heat up and blow the lamp. The lamp part# for your model is TS-CL110u. Hope this helps.
Dec 15, 2007 | JVC HD-52G886 52" Rear Projection HDTV
JVC HD-52G886 52" Rear Projection HDTV Logo
126 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
