Question about Intermatic & Indoor/Outdoor Rain Tight Timer
Program a Brinks mechanical outdoor timer 42-1015
Brinks mechanical timer for outdoor Christmas light's. I cant get the unit to shut off when programed to shut off at 11:00 pm. what is the problem?
3 Suggested Answers
SOURCE: BRINKS 42-1014 OUTDOOR ANALOG TIMER
I don't have an instruction manual but there's not much to know. Set the on/off times by depressing the white and grey tabs just above the hour notation for the times you want. If the tabs are up then the power is off. If they are pressed in then power's on. Plug it in, turn the dial to the current time and attach a device using less than 500 watts and you're good to go. There is a # to the helpdesk 800-562-5625_36.jpg
Posted on Nov 08, 2010
  • 3289 Answers
SOURCE: I need programming instructions for my intermatic outdoor lighting timer
Hi Jeanne,
Here's a page with detailed instructions and pictures - that will guide you through programming. I hope this helps & good luck!
Posted on Nov 09, 2011
Brinks model 42-1050 manual?
Brinks timers and manuals: - Water Heater Timer
waterheatertimer.org/Brinks-timers-and-manuals.html
Brinks timers and manuals. ... Brinks 44-1020 manual · Brinks 42-1020 manual ·Brinks 42-1020 instructions ... 42-1050 yard stake · Invisa timer 52-9206 · Brinks ...
I need an instructions guide for Brinks timer 42-1050 - Fixya
www.fixya.com/.../t10900275-need_instructions_guide_brinks_timer_4...
Nov 28, 2011 - SOURCE: Brinks model 44-1050 digital outlet timer- I don't. I have an instruction for a Brinks 44-1030 which I believe programs the same.
Brinks-outdoor analog stake timer-42-1050 Timer will not ...
Dec 14, 2015 | Hardware & Accessories
How do I get my Brinks timer to come on at 7.30 pm and turn off at7..30 am
Do you know what model Brinks timer you have? This will help when searching for specifics on programming.
Sep 02, 2014 | Hardware & Accessories
In the "off" mode there is power leakage as some of the LED Christmas lights are still on
1) Buy timer that is rated for inductive, and not just rated for tungsten or resistive.
Rating usually appears in each product manual except with cheap knock-off timers or older timers that might not show rating or have rating sticker on timer.
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
2) Digital timers work differently than mechanical timers.
Digital do not completely shut off the circuit, unless they are rated for inductive.
So inductive loads like CFL or LED will have slight glow.
3) ALWAYS plug outdoor timers into GFCI-protected outlet.
Unplug timer from wall when working with lights, and cords.
Stand on dry surface or plywood and never bare ground.
Plug timer directly into outlet, and do not use extension cord.
4) Don't use LED Christmas lights because they have no warmth and look cheap and un-inviting.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 18, 2012 | Hardware & Accessories
I have a EI600WC timer installed (by electrician) in my garage to control outdoor christmas lights (outlets in eaves). The switch will not turn the lights on!
Yes 100' maximum is problem. To work around problem, you can use timer to turn on a contactor, and then the contactor is not limited to 100' distance.
Copy following link to see wiring diagram, and you can wire it yourself:
http://waterheatertimer.org/images/Dawn-dusk-120Volt-pump2-300.jpg
http://waterheatertimer.org/H230A.html
Assuming timer was installed correctly ... did timer work when first installed, and then die?
This timer cannot be exposed to freezing temperatures because the battery will die in cold temperatures.
Ei600 timer is 5-year warranty version of ST01C timer, and both have same wiring and same battery.
Copy following link to see programming, wiring, and battery replacement
http://waterheatertimer.org/ST01C-program.html
If cold battery is problem, suggest using GE 15312 timer from Home Depot that has same 100' maximum and same load rating characteristics and same programming capability as Ei600 and ST01C, but GE timer is powered by the circuit and not a battery.
http://waterheatertimer.org/How-to-wire-GE-15312-timer.html
You can install timer yourself.
Nov 29, 2011 | Intermatic EJ500C - Indoor Digital Wall...
November 2010 I purchased a Brinks 42-1050 Outdoor timer for Christmas lights. Recently I tried to use if for a temporary pet light. Problem, the clock does not keep time. Can this clock be repaired. I...
This timer cannot be repaired.
Solution 1:
Timer has 1 year limited warranty from hampton products.
Warranty might apply.
Aug 2011: open following links for hampton:
http://www.hamptonproducts.com/customer-care.php
http://www.hamptonproducts.com/contact-us.php
Solution 2:
Buy another identical timer from Walmat etc.
Return defect timer in new package.
Aug 19, 2011 | Hampton Technologies Brinks Timer
How to set the Nordik TM-065? It was bought for
The Nordik TM-065 timer looks similar to Woods/Noma N1506
http://www.advancedtimer.com/TM-065.html
http://waterheatertimer.org/Woods-timers-and-manuals.html#N1506
Plug timer into outdoor receptacle.
Press Time button until correct time displays.
Dot on display is for pm hours
Nordik appears to be on the 24 hour clock instead of am-pm
Set operation of timer by pressing Mode button.
P flashes for program mode.
Press time button until starting time displays.
Press Mode again and E flashes.
Press time button until finish time displays
Press Mode button to exit programming.
Dec 17, 2010 | Woods Outdoor Lighting Timer
How do i set it
i think i figured it out. i have the same one. i bought it last year for my christmas tree lights and it worked great. but this year i can't get it right. finally i think i did. u see, since it is hard to read the dial it makes it hard to set the current time and on/off times. i will give u my example: to have the timer turn on at 4pm and off at 11pm: set the timer at 8pm ( the 8 left of the PM mark). set green marker at 4pm (left of the PM mark) set red at 11pm ( left of PM mark and just before the 12am mark. basically i think the dial is backwards so what looks like pm times is not and vice versa. Crossing my fingers, Good Luck!!
Dec 06, 2010 | Hampton Technologies Brinks Timer
My timer comes on at dusk and the lights blink on and off until they shut off 6 hours later.
1) Put black tape over photoelectric eye on timer.
Photo-eye is small round eyeball that bulges out.
See of lights stay on.
2) Turn timer away from source of light so photoelectric eye does not pick up feedback from lights.
It sounds like photo eye is receiving enough light that it turns off, 'thinking' it's dawn.
And then when lights are off, photo eye 'thinks' it's dark again, so lights come back on.
Let me know if this is the answer, because it's Christmas season, and folks have been asking about blinking outdoor timers. And then you're en-route to become fixya expert and boost your GNP by 3 cents an answer.
Nov 30, 2010 | Woods Outdoor Photoelectric 24 Hour...
Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
4,084 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
