Machine not spinning when it gets to that cycle.
SOURCE: Miele washing machine model W713 front load - issues
If it is leaking from the waste pump area it may be blocked by a small piece of clothing like a sock or something similar! This will also cause it to take too long to complete a cycle. Remove the rubber hose onto the waste pump and check inside the hose and the pump, make sure the pump spins freely and that nothing is stuck in the hose pipes leading to the pump
SOURCE: Miele Premier novo washing machine
Flashing rinse light is a drive fault. No motor action. If it's an earlier model it would be the motor brushes. Later model will be the electronic which controls the motor.
SOURCE: LG WD-8013F wont spin
Hi deppgirl,
I checked the lint filter at the front bottom left hand side and it was full of junk. Once emptied it worked a treat. Pull the flap down and turn the large knob anti-clockwise and pull to remove. Good luck.
SOURCE: Washer will not Spin during SPIN CYCLES
Check the lid switch. Through out time the lid switch housing can come apart from years of heat and cold. When I checked mine, I found the glue deterriated and the housing came apart. What I did to fix it is I zipped tied the housing together and did a functional check and it worked.
SOURCE: kenmore he2 front loader washer won't do rinse spin cycle
kappharmd-
if yours is the same, the drain is hidden behind the lower access panel on the front (how convenient, huh?). I don't understand why they didn't just make a recess hole for it. I've just left one screw loose in the center and it kinda "compression" fits. We clean this out regularly, as my wife and family don't check pockets well. :)
