This vehicle has what is referred to as drive - by wire , or electronic throttle control . when reduced power message shows it's a problem with the throttle position sensors or the pedal position sensors , the gas pedal has position sensors ! GM has had some problems with it ! Drive by Wire Function and Diagnostics by Wells
My 2008 SRX also had this problem, at first I would turn the engine off and that would fix the problem, but then both the check engine light and the reduce engine power light would come right back on. I brought it to my local mechanic and the code that came up was for the timing chain or the crank shaft. They checked with cadillac and they had problems with timing chain so that was replaced. It was fine for a few days and is now doing the same exact thing. Can anyone help?
SOURCE: I have a 2007 Cadillac
My 2005 came up with this also, it continually became more frequent. Had to replace the throttle body.
