Question about Sewing Machines
My sewing machine is stuck in the stretch stitch area and I can't get it back to the utility stitches
Try turning it off for a few minutes and restarting - a lot of times this will make it re-set. Hope this helps.
Posted on Jan 12, 2009
I would like to know what stitch number to put my sewing machine onto to stitch stretch material. I have a Elna 40 sewing machine regards Judy
Looks like stitch #06 might be a stretch stitch. You could probably also use a slight 08 or 09 zig-zag. Unless you are sewing something really stretchy (lycra) IMHO, a slight zig-zag is fine and actually is a lot faster than a stretch stitch which takes a few stitches forward and then one or two stitches in reverse. The stitch #09 is something that I use frequently for stretch fabrics.
Elina 40 Question and Answers
May 31, 2016 | Elna Sewing Machines
Singer 6510 3 dial machine - no "S" on stitch length dial selector
Lower numbers moves the fabric further for each time the needle penetrates the fabric. . If you raise the number you will get more stitches per inch which means your fabric is moving more slowly. Try moving the number to different locations for examples. If you are attempting to make something so it will stretch you are probably wanting to use a zigzag stitch. A wide zigzag stitch will allow a longer stretch than a less wide zigzag stitch.
Dec 23, 2014 | Singer 6510 Sewing Machine
My new Singer machine ("Curvy") purchased last week (3/2014) has a page on stretch stitches. The way the book is written, it lists Straight Stretch Stitch on the same page as Ric Rac, HOneycomb, and...
A zig-zag is also a stretch stitch. Usually, a "built-in" stretch stitch will stitch forward a couple and then stitch backward and then stitch forward again (time consuming and uses a lot of thread--but suitable if that's what you want). Whatever you are sewing, whether it is a seam or finished raw edge and the fabric is stretch, you will need to use a stretch or zig-zag. A straight stitch will pop the threads as soon as the fabric has to give.
You can test your stitches on some scrap fabric and see what looks best.
An Over-edge stitch is just that, just a stitch over the fabric edge. It probably would not be suitable for sewing a seam.
Apr 09, 2017 | Singer Sewing Machines
Stitch length dial is stuck on SS
Likely broken threads wrapped around internal components. Have it prefessoinally serviced.
Jan 09, 2014 | Brother XR-65t Mechanical Sewing Machine
I am trying to alter a swim suit, and I need to use a stretch stitch. Does the Singer model 2638 have this feature?
Here is the stitch selection page from your manual
I would suggest that you use the stitch called "elastic overlock" using a stretch needle, you need a ball point tip on the needle to press between the elastane fibres in lycra. A stretch needle is blue, coated with a substance that makes it easier to stitch these types of man made stretch fibres, often size 75. If you can't get one of those, then use a ball point needle, size 70 or 80.
You need a stitch with forwards and backwards movement so that the stitching doesn't break under stress. Your machine also has a stretch straight stitch and this would be a forwards and backwards straight stitch so this will work too but can look a bit 'heavy' sometimes. But even triple zig zag narrowed down will work often.
If you are sewing leg edges with lycra, shop made garments will have clear swimsuit elastic sewn into the seam using a coverstitch overlocker, you'll never get as good a result with a regular sewing machine but you can get a reasonable finish with practice. This elastic is available to buy, you might want to use the overlock stitch to attach it to the fabric edge, stretching as you go, then turn it to the inside and use a stretch twin needle and straight stitch to top stitch from the outside, stretching the fabric as you sew.
Trust this helps you a little, 4 thumbs up if so. :-)
Jul 13, 2011 | Singer 2638 Mechanical Sewing Machine
My Kenmore sewing machine model number is 17630, & when I try to set the stitch length from a Straight Stitch setting to a Straight STRETCH Stitch setting, there isn't any difference. I have the length...
Take a look at the stitch length dial. If you turn that dial counter clockwise (to about 7 o'clock), it will set to stretch stitch. Then all of the stretch stitch features will work. When you want to go back to straight stitching, just move that dial back to what ever stitch length you wish.
Nov 26, 2010 | Kenmore Sewing Machines
Pfaff 1222's 3 stretch stitches sew wrong and backwards only.
It sounds like the feed mechanism needs oil.
Feb 24, 2010 | Sewing Machines
How do I do a stretch stitch?
The bes way to hem a t-shirt on a household machine is to use a double needle, straight stitch. You will see two straight stitches on top and zig zag on the back. Just make sure the zig zag catched the top of the hem.
Feb 19, 2009 | Kenmore 12102
Sewing Machines Logo
57 people viewed this question
Top Sewing Machines Experts
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
