Question about Maytag Dryers
Heating element on
I went into my laundry room the other day and even though no laundry had been done for days the room was hot.
I investigated and it seems the heating element is stuck on even though unit is not running.
Any ideas???
  • vjreiners Jan 13, 2009
    Thanks for the help I t sounds like the centrifugal switch. My wife just told me that if she unplugs the dryer and then runs it on Air Fluff only then when the drum stops the element has never come on.(which is normal) If she then runs it in normal dry mode when the door is opened the drum stops but the element continues to heat.
Two possibilities, the element has shorted to ground and must be replaced or the centrifufal switch in the drive motor has frozen contacts.
Posted on Jan 12, 2009
GE dryer very hot on top--hasn't been used
Often times the element has broken (burned out) and is now touching the element housing causing it to heat up and stay on even though the dryer is not even running.
Mar 10, 2014 | GE Dryers
Dryer is putting hot air in the Landry room
Most likely your vent is clogged and check for clogged vent and heating element and clean lint filter housing with vacuum
Dec 09, 2013 | Samsung White 7.4 Super Capacity Electric...
Heater smell when AC comes on...
The fan that blows the air blows through the heater coils before it blows through the A/C.As long as the heater doesn't come on, there is not much that can be done. ZCooking the attic room will be a problem because it is the heat rises thing, and on top(literally) of it all, the roof is radiating heat.
Sep 21, 2009 | LG Heat cool Window Air Conditioner
Whirpool lgr6620pto will not heat up and will run all day untill i open the door
Heating element is either burnt in two or vent pipe is clogged with lint or birds have made a nest in the pipe on the outside wall or roof. Yes, a bird can lift that little flapper door up and will fill that pipe until it is clogged. To check to see if it is a heating element, close the door to your laundry room & the light out, turn the timer knob to any selection, with the door open & no clothes in the drum, find the door switch located somewhere around the door frame and hold it in while turning the start knob on. If the element is good you will see a red glow coming from the vent holes at the inside back of the drum. No glow, no good.
Jul 09, 2009 | Dryers
Dryer is hot even when off for two days
You have a bad timer that will not shut off.
Apr 02, 2009 | GE Dryers
Dryer Overheating
your element should shut off when dryer is not running.their is a short somewhere.could be timer or even the motor switch.
Mar 11, 2009 | GE Spacemaker Washer and Dryer Electric...
Oven elements just stopped working
If I understand your use correctly, you were using the oven to heat the space? Or for baking?
Regardless, it sounds as though the elements have failed. If you used the oven for heating the space (with the door open) the broiler element comes on during preheat of the oven to get the oven to temperature more quickly. The elements are NOT designed to heat a space, and will quickly burn out if used in this manner.
Jan 23, 2009 | Ovens
Dryers Logo
57 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
