Question about Faberware FCP512S Coffee Maker
Broken see thru knob P/N 30595
This knob has broken off at the base. It had a nut and a washer holding it on. The coffee pot is now unable to be used even though the coffee pot still makes coffee because the water spills out of the hole at the top. Was this a built in thing to make the coffee pot unusable after a certain time??? I was at a yard sale today and there sat another Faberware coffee maker in a box to be sold. The same brand and it has the same problem. The knob was broken off. Pat Klemz
  • 5 more comments
  • Pat Klemz Jun 10, 2007
    Where can I get part replaced??? Do you have a part you can send me?????
  • DalaiMama Dec 30, 2007
    Same problem with my FCP512S!! I wanted to super glue it...but didn't know if it would end up poisoning my coffee..???
  • Anonymous Jan 09, 2008
    I have the same exact problem. I noticed that the coffee wasn't perking up to the top see thru knob and also notice that it was leaking. When I noticed that the nut under the cover was loose I tried to tighten it and it broke right off. I always loved this coffee maker. I would like to get a replacement cover for it. Please E-mail me with information. My e-mail is:
    amcb59@aol.com Thank you Ann Marie
  • Anonymous Apr 14, 2008
    I have the same coffee maker and the same problem...I first thought it was because I put the lid into my dishwasher....I feel better that I'm not alone with this problem....although, I'm not happy at all.....I tried the "ESalton.com" site....they are no longer on line....I'm now going to contact Faberware...thank you
  • odenton1a Aug 12, 2008
    The only place to get the replacement part that I could find, was by calling 1-800-233-9054, which is the company now handling service issues for Faberware products. I ordered two, and it cost $20.75 with shipping and handling.
  • roy4n6 Dec 08, 2008
    Same broken knob problem; second coffee maker with the same problem.  First one came in under warranty; this one long past warranty.  Ordered a replacement @ $14.95 incl shipping.  Still a plastic knob -- bad engineering choice.
  • Anonymous Apr 20, 2009
    same problem here
Okay...i did some more fishing around for a replacement part online and found it. www.esalton.com the part is $2. ( I ordered 2 of them)
hope it helps ya!
Posted on Dec 30, 2007
You can contact the manufacturer and get a replacement knob for free the first time and then $5 there after
Posted on Oct 27, 2007
  • 883 Answers
You can try using rear view mirror adhesive, available at auto parts stores. Get it very clean with alcohol first.
Posted on Jun 10, 2007
My tone knob given that it's no more fixed to the body and keeps rotating on itself?
usually they have a small nut that screws don the shaft to hold in place firmely
Apr 29, 2015 | Epiphone SG Prophecy Custom EX Electric...
Hot water will not come down thru coffee
Your pour over coffee brewer has a reservoir that holds more than a pot of water. First thing you need to do is turn off the machine. Then put the empty coffee pot on the burner. Then take another container and fill it with fresh cold water and pour it slowly into the coffee maker until it starts to come out into the coffee pot. Stop pouring in water.
Now turn the machine on and let it heat up. Now you can brew normally. The reservoir has to be filled before you turn it on or you will end up eventually burning up the heating element.
Dec 31, 2013 | Bunn A10 Coffee Maker
Farberware model 138, base shattered. need base and internal braided cord that attaches to the pots plugs via small nuts.
You can get the base and the keepwarn element ( braided rope)on eBay under Farberware coffee parts. Ron
Jul 05, 2010 | Coffee Makers & Espresso Machines
Farberware 12 cup electric percolator leaks
Hi, if you have a China pot toss it. If you have a USA pot, Get ahold of a 1 3/8" socket. Take the base off and you will see a square nut on the bottom of the main heating element, put that in a bench vice and thighen the nut up inside the pot. You will only have to turn it a tiny bit. While you have it apart check if it still leaks, if so thghten a bit more. You will get nowhere without the vice and the socket. .Try to stay away from the keepwarm element ( little white rope looking thing ) Good luck. Ron
Mar 16, 2010 | Faberware Coffee Makers & Espresso...
Source for replacement blade for CBG5 B&D Coffee Grinder
Unable to find any parts supplier who offered a replacement blade for the CBG5 SmartGrind Coffee grinder, the broken plastic center spindle was reconstructed around the attachment nut, and an epoxy cement was poured around the nut and over the center of the blade.
This solution has worked in testing the blade on the grinder, but how long it will hold up has not yet been determined.
T.B.
Oct 07, 2009 | Black & Decker Black and Decker CBG5...
The volume knob has broken off at the base on chan 1 of my peavey KB100 keyboard amplifier. part needs replacing in NW London?
Was it the know or the pot? The pot is the metal(sometimes plastic) shaft with a nut securing it to the enclosure.
Here is your nearest registered Peavey service center. http://www.peavey-eu.com/support_2_detail.php?flag=GB&lan=UK&var=ser&key=SERVICE
This could also be repaired by someone with electronics knowledge. Just would need to know the pot taper and resistance. This would be on the front of the pot on the same side as the shaft. The enclosure would need to be taken apart.
Jun 21, 2009 | Peavey VTB1 1-Channel Amplifier
Zoom A2 Effects processor Cant remove circuit board
After removing one knob carefully, you might find that there are nuts and washers holding the pots in place and the pots are soldered to the second circuit board which is held in place by these nuts and washers.
Feb 21, 2009 | Music
I need the plastic base for a Faberware FCP 240-A 4 cup Percolato
ok heres a simple fix if you dont have the money for replacement or cant find parts
J.B.weld from auto parts store this stuff if strong enough to fix a cracked engine block so im sure the pot can get fixed this way
Dec 06, 2008 | Faberware FCP240 Coffee Maker
Re: KitchenAid Coffee Pot
I had a similar problem with Err 1, Err2, and Err 4. To resolve Err 1, if you have room, remove the coffee filter and coffee, pour more "warm" not hot water into reservoir. If you have 4 cups cold water add 5 cups warm. Then start coffee maker and let it run thru. Then drain coffee pot and start over to make coffee with tepid water. Err 1 indicates the coffee maker temp sensor is too cold from room temp or water temp.
Err 2 is a result of cleaning. First question "Did you remove the charcoal filter?" The charcoal filter can be removed form the filter stick by prying two tabs away gently and removing the filter for removal. The filters can be purchased @ www.Kitchenaid.com
One pot run thru with descaler can loosen scale and make sensor go "blind". Just run a full pot of clean plain water thru one maybe two times. A pot solution should be a solution of 1/4 pot WHITE vinegar, 3/4 pot clean cool water. Run this thru once, then two clean pots of fresh water as if you brewed a pot of coffee. NEVER USE CLR WITHOUT RUNNING NO LESS THAN THREE CLEAN WATER POTS THRU MAKER!!!! This is so you can continue to enjoy drinking coffee, nothing like a cup cleaning you out!
Err 4 is simple, you have a stuck button. Unplug maker and gently press each button making sure they aren't stuck in.
Jul 20, 2008 | KitchenAid KCM511OB 10-Cup Coffee Maker
GE coffee maker with grinder 169103
We were unable to find a coffee pot that fit this model after it was broken so my roomate devised a solution to make it work in the meantime. He took the little plastic tab that closes off a bag of bread and used it under the filter in the filter cup to clip around the devise that holds the brewer open and let the coffee pour out below. Then we used a four cup Pyrex measuring cup underneath to catch the coffee. The first time I tried this without the device the coffee flooded out of the pot and all over the sink and not in the Pyrex because I didn't realize the previous pot held this device open. Just remember to let it finish brewing because it doesn't shut off when you remove the pot once you rig this up. A paper clip might work also. Good Luck!
May 08, 2008 | GE 106591 Coffee Maker
Faberware FCP512S Coffee Maker Logo
1,996 people viewed this question
Top Faberware Coffee Makers & Espresso Machines Experts
Starnley Johnwells
Starnley Johnwells
Steve
Kolbrun...
Are you a Faberware Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
