Question about Ovens
I need to remove the inner glass panel from my philco double oven to clean it but dont no how
Make: philco model:ph60cdx fuel type: electric
Master_Tech
  • 770 Answers
SOURCE: KITCHEN AID KEBC107KSS03 DOOR. REMOVE INNER PANEL. CLEAN GLASS
LOOK WHERE THE HINGE METS THE OVEN DOOR FACING..you will see on the hinge a tab with the door open pull these forward this will lock the hinges do this on both sides then closed the door slightly and lift up the door will come off then you can unscrew the bottom scres to access glass
Posted on Feb 22, 2008
ginko
  • 19396 Answers
SOURCE: how do i replace the inner glass on the oven door?
moz-screenshot-7.jpgmoz-screenshot-8.jpgTo replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
See diagram below , click on picture to enlarge:
Part here: _.gif PS2087058
Posted on Apr 08, 2009
SOURCE: how to remove the control panel on Whirlpool double oven Model RBD305PDS14
Emge & Associates is investigating gas and electric ovens manufactured by Whirlpool, including such popular brands as Whirlpool, Jenn-Air, KitchenAid and Maytag.
The firm is investigating reports that the electronic control panel on certain models is subject to failure after a limited number of uses of the appliance’s “self-cleaning” setting. While most foods are cooked at temperatures reaching 375 degrees, the “self-cleaning” setting raises the interior oven temperature to 1,400 degrees. Due to defects in the design and or manufacturing, the electronics contained on many ranges are damaged by extremely high heat. Repairs to damaged control panels typically cost in excess of $300 per replacement.
If you have experienced failure of the control panel in your range after using the “self-cleaning” setting, you can join this investigation by contacting Emge & Associates at (800) 629-3409 or (619) 618-2974.
Posted on Dec 19, 2009
SOURCE: My Stoves EFa600H inner glass recently shatterd
Hi Sorry- i do not how to do this BUT the eaxct same thing has happened to us! Cna i ask where you got the replacement glass, how much it cost and how long it took to deliver?
Thanks
Posted on Jan 27, 2010
  • 18 Answers
SOURCE: the inner glass door on my zanussi oven has come
You should be able to repair your existing door. Have a look around the perimeter of the door to see if there are any screws, particularly near the handle. You are looking to take the front fascia off the door, so that you can access the inside. Most doors have the front fascia held on by small brackets glued to the back of the glass that clip on to a fixing on the internal door. The top of the fascia is normally held in place by the handle. Once you have the front of the door off you can retrieve the piece of glass that has fallen out. You will almost certainly find that the glass has come away from the adhesive that was used to hold it in place. You will need to clean up the glass and the metal door and re-stick the glass using a high temperature oven door glue
Posted on Feb 18, 2010
How to clean between glass oven doors on whirlpool oven?
You need to remove the inner door panel, Usually a few screws holding it on. On some models the handle screws also need to be removed. Do it slowly and carefully as the door may want to swing up quickly, once the weight on it is removed. Pay close attention to each step so all screws etc go back in the same place. Make a diagram as you take them out to be sure.
Aug 10, 2014 | Whirlpool RBD305PD Electric Double Oven
How do I remove glass from the door to clean it ?
They may be rivet holes. On my Zanusi the thin panel that goes across the top of the glass to hold it in just slides off forwards toward the cooker.
Then the glass slides out upwards.
Apr 15, 2012 | Zanussi ZHQ575 Electric Double Oven
My neff oven's handle has become loose. I cannot see any screws. how can i tighten handle ? the model is U1422 oven.
You need to remove the inner glass panel, should be 2 screws at top and 2 at bottom and remove. The screws for the handle are behind this
Mar 02, 2011 | Neff U1421 Double circotherm Electric Oven
How do i take the door off to clean it
To take the door off you have to remove inner glass panels from both doors. Then remove the appliance from the housing unit. When the unit is out, you then have to unscrew the top panel and both side panels and lift them clear.
With the door closed, support it with one hand as you carefully unhook the large springs from the door hinge arms. The door frame can now be removed.
The above is from the handbook. You can actually remove the outer glass panel as well but personally would just slide the inner glass panel out and clean the door in situ.
Feb 06, 2010 | Stoves 720EF Electric Double Oven
Whirlpool double oven - model RBD305PD82
Please take a look at the diagram if you think you want to do that.
if you still want to do it and need more details to disassemble feel free to email me. nguyen@ite.net
Jun 09, 2009 | Whirlpool RBD305PD Electric Double Oven
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
KEB5247 Kitchenaid built in electric double oven
Yes the inner door glass is a replaceable part and the door will have to be disasembled but not replaced. I can help with sourcing any parts for you since you used a premium post.
Jan 02, 2008 | KitchenAid KEBC277 Electric Double Oven
Viking: VEDO205 Blew my inner glass door
If you can take the door apart then you can fix it. Remove all the retaining screws to access the inner glass.
Dec 11, 2007 | Viking DEDO205 Stainless Steel Electric...
Cleaning the inside of the glass on the oven door
dont try you will broke something and then gonna think that was better to have a little dirt in there, a tech could do but whats if it comes again....good luck if you insist post back
Aug 07, 2006 | Neff U1421 Double circotherm Electric Oven
Ovens Logo
26 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
