Question about Toastmaster Kitchen Appliances - Others
Older waffle maker is not heating up
Toastmaster waffle maker, model 287 is not heating up and the "power on" light is not coming on. There is a small ceramic part inside that I believe to be the problem. (called a heating element or something)??? It has A185 deg C printed on the side of the part and Z 42/43, 10/250 on the top.
Is there a way to replace this part?
    President:
  • 267 Answers
Thats a high temp fuse you can jump it out to test the rest of the waffle maker but dont leave it jumped out , its not safe that way . that fuse is hard to find try google "fuse high temp 185 c " please rate this answer , i need it to "get my wings" thanks
Posted on Jan 16, 2009
Find a leg for toastmaster waffle maker model 270 or 290
http://www.searspartsdirect.com/partsdirect/part-model/Toastmaster-Parts/Waffle-maker-Parts/Model-270/1097/0213700/00039364/00001?blt=06&prst=&shdMod=
Jun 18, 2014 | VillaWare 3600 Prego Pizzelle Baker
My waffe batter stuck to the waffle iron
After each time you use it, when it cools, it should be wiped clean and lightly oiled (so it's non-stick ready to use for next time).
Oct 14, 2012 | Toastmaster 287 Waffle Maker
Why does my waffles stick?
You have to lightly coat the waffle iron with vegetable oil, and then you won't have them sticking.
Otherwise, it's a mess!
Dec 12, 2010 | Toastmaster TMWB2BELW Waffle Maker
I need an operating manual for cleaning and operating purposes
You can download the manual in PDF format by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Thanks for using FixYa.
Jul 04, 2010 | Toastmaster 287 Waffle Maker
283 S Waffle Iron.
You can try this site: http://kitchen.manualsonline.com/manuals/mfg/toastmaster/287.html
Its not the exact model but sometimes they are close. Hope this helps.
Aug 13, 2009 | Toastmaster 283S Waffle Maker
Repalcement plates for Model 270A Toastmaster Waffle Iron?
There is no way you can get replacement plates for you Toastmaster cheaper than you can buy a new one, the most expensive Toastmaster waffle maker I found was $30. the cheapest was $15 shipping will be at least half of that.
Feb 09, 2009 | Toastmaster 287 Waffle Maker
Toastmaster 287 thermostat
I had the same problem a few weeks ago where the Ready light came on and stayed on. After opening it up I realized the little disc is a thermostat. After some Internet searches I found out who the manufacturer was and emailed a sales guy there. They didn't sell retail, but he recommended www.selcoproducts.com. It took some more research to figure out which kind I needed because there are a lot.
Choose there Thermal Products link, then Disc Thermostats, 1/2" Disc - Automatic Reset. You'll want the Open On Rise type. There are all kinds of different temperatures and I had a real hard time finding what temperature to buy. I found a patent that said 166 Celcius (about 300 F) so I got that type from the 1/2" Disc - OA Series link. It isn't as high a temperature as the old one so I run it for 2 cycles of the Ready light and it worked perfect. You may want to try their higher temperature ones under the 1/2 Disc CR/OR Series - High Temperature - Polyester, or Ceramic if you want to try higher than 365 F. Whichever you get make sure under Mounting it says Rotating Bracket. It will show you individual pictures of each so you'll see what you want.
They have a minimum order of $50, though. So you'll want to buy a few. I had to buy 5, but with the High Temperature ones you probably can get away with 4 since they are slightly more expensive.
Jan 26, 2009 | Toastmaster 287 Waffle Maker
I have an older model waffle make. Toastmaster model 287 that has stopped heating and the "power on" light is not sowing power. I took the machine apart and I imagine the ceramic heating element ,or what...
THAT IS A FUSE you should be able yo get one from someone on line GOOGLE high temp fuse 185c and see what come up . we have them here , but we are a service center . so if i can get one so can you, somewhere .
Jan 12, 2009 | Kitchen Appliances - Others
Pizzelle maker 208 won't heat up.
Most appliances that work with heat, are equipped with a thermal fuse so if the thermostat fails, the fuse opens and prevents a fire. It is basically a good idea since all of our junk now comes from China and half of it is poorly designed and unreliable.
These fuses are normally not user replaceable since they are crimped or welded into series with one side of the AC line. And, they are tough as hens' teeth to find anyhow.
A year ago, I had three coffeemakers of the same model die in as many days. I took a refund.
The Toastmaster toaster we have, bought because of the name and appearance, is the absolute worst toaster we have ever owned. It regularly leaves one side of each slice burned, the other too light. I'm afraid the name means nothing anymore.
Dec 22, 2008 | Toastmaster 208 Pizelle Maker Waffle Maker
Kitchen Appliances - Others Logo
444 people viewed this question
Top Toastmaster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Henry  Thomas
Henry Thomas
Are you a Toastmaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
