Is this a 2 stage cooling system because only then you will need y2. You can put any color you like on these terminal but it have to match up with the thermostat for example if you put black on R terminal on air handler then you have to put black on R on thermostat
your heat-relay aka heat sequencer, time delay... is stuck most likely remove and replace if it checks closed and no 24 volts is going to the timer portion.for 3 to 5 minutes. some of these switches stay closed for 3-5 minutes.after power is removed
Hello, Usually it has to do with the quality of the install and the brand. If it was not installed properly from the beginning then the equipment will fail prematurely. As far as the heat exchanger goes I have replaced many heat exchangers on Goodmans after 3 years being installed, Goodmans are prone to bad heat exchangers.
You may need a "current sensing relay" to clip around the neutral wire on your blower.
Run the 120v power to the main power (the power switch- hot,neutral and ground) . Run the Hot wire through the "Current Sesing Relay" wires to the EAC unit's 120v. power input. The unit will only run when the fan is on.
