Question about Canon PowerShot A75 Digital Camera
No memory card.
Hi there
I have a Canon s5is and till now it worked ok but after I turned it on it say no memory card. I replace it with a brand new but ...
please help me
I have the same problem with my Canon G9. I have found a solution and since doing it the problem has only happened once again. Here is the solution: I have a 32mb sd card that was given with the camera when I bought it. This card has different connectors than the ones that are used on the usual SD cards. As soon as this card is inserted the camera works properly and all other cards work fine after. I'm assuming that the sd card circuit blocks and this 32mb card unblocks it somehow... Hope this will help you.
Posted on Jan 13, 2009
Card lock for powershot S5IS
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jan 10, 2013 | Canon PowerShot S5 IS Digital Camera
Cannon s5is powershot as soon as i turn camera on a memory card error comes up and theres no card in it, does same thing when card inserted. it's got to be something in the camera slot, is there a lock in...
On the SD card there is a little switch you can move. It has 2 positions, LOCKED, and UNLOCKED. To make the card available, put the switch in the UNLOCKED position.
Here is an example-
If that doesn't work, try putting the card into a memory card reader, like on your PC or a special USB attachment. If the memory card is recognized, then it might be a problem with your camera.
Mar 01, 2011 | Canon PowerShot S5 IS Digital Camera
Canon Powershot S5iS message: Card is locked@
On the card itself is a smal switch on the side. It must be in the locked position and that is why you can't do anything with it
Feb 01, 2011 | SanDisk 2GB microSD Memory Card
Is the SDHC memory card compatible with the Canon Powershot S5is Camera?
Yes, the S5 IS is compatible with SDHC cards. You can use them freely.
Nov 27, 2010 | Canon PowerShot S5 IS Digital Camera
Just purchased new Cannon A495 camera installed 2GB memory card turned on camera display reads"memory card error" turned off removed and reinstalled batteries turned on camera problem still exists
Hello Art, Hi, The Canon brand is known world wide, but if the camera you just got is new and defective, why not return it to the dealer, have them try and operate your camera, if its defective they should replace it. Besides I don't advice gadgets with warranty, let the dealer repair it for you.
Jun 15, 2010 | PNY 2GB microSD Memory Card
Memory card error with new memory card
Hi there, welcome to FixYa.
Let's work on the camera first.
1) Turn the camera off and remove the battery and the card.
2) Put the battery back in without the card and turn it on.
3) Turn the camera off and insert the CF card.
4) Turn the camera back on again.
See if that takes the message away.
If it doesn't leave me a comment and we go to step 2.
If it does, thanks for coming to FixYa.
Rob
Mar 14, 2009 | Canon PowerShot A75 Digital Camera
Reformatting SanDisk for Canon s5is
y dont u format it on windows try card reader if nothing happens then ur card is faulty it seems like
Feb 23, 2009 | Canon PowerShot SD200 / IXUS 30 Digital...
Cannot unlock memory card for my Canon Powershot S5IS
OK take out the memory card and on the side of the card is a small switch...slide the switch to the unlock posistion and that should fix ya
!Please rate this response and help us keep this area free!
Thank You!
Jan 21, 2009 | Canon PowerShot S5 IS Digital Camera
No memory card error on canon powershot a400
Maybe you have to format the card before the camera recognizes it
Dec 04, 2006 | Canon PowerShot A400 Digital Camera
Canon PowerShot A75 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
