Question about Hoover Washing Machines
Hoover not spinning ophs 712 df
Not spinning clothes
3 Suggested Answers
  • 6277 Answers
SOURCE: I have purchased a hoover
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Aug 12, 2011
  • 6277 Answers
SOURCE: Hoover OPH 617 DF 1600
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
John C
Posted on Aug 17, 2011
Hoover troubleshooting
My Hoover Spin Scrub 60 will not spray on the wash setting but will spray on the rinse setting, what is the problem?
Jan 11, 2014 | Washing Machines
Cycle stopping after filling with water on hoover oph 148
the heater may not be working or you have a broken wire
Dec 31, 2013 | Hoover Washing Machines
My Hoover 700 LA Top loading washer does not spin dry clothes after the was cycle ? The drum does not spin fast enough for the clothes to dry out as before.
Just got Hoover 700 la manual top loader 2. hand...it is taking maximum amount of water on low arrange, and takes an hour on delicates. it also spin dries very strongly, just ruined my clothes..what you would suggest folks..
cheers aysh
Jul 06, 2012 | Washing Machines
Hoover OPH 617 DF 1600 A+ I have done a wash but I now can't open the door and don't know how to get it open? Please help me asap.
John C
Aug 17, 2011 | Washing Machines
I have purchased a hoover ptima oph 714 df without a manual where can i get one?
Manual
John C.
Aug 12, 2011 | Washing Machines
Hoover optima oph714ds error code e14
hoover optima oph 7d14 working ok but at end of wash cycle error e14 comes up what does this mean
Dec 24, 2010 | Washing Machines
My Hoover Optima OPH 714 D washing machine won't start
Hope your tried switching off the machine for half to one hour, to re plug. Machine might re-set.
If helped, pl click, it could help others.
Dec 07, 2009 | Bosch Washing Machines
Hoover error E08
hi I had this fault, google said it was tachometer fault. the e08 fault on my hoover optima was not the tachometer, i checked it, but the fix was very easy, the motor brushes were worn out and i changed them for 10 quid, I made a video of it its on youtube http://www.youtube.com/watch?v=xYn-f78GB4U and it shows you how to test the tacho and how to change the brushes, hope this helps someone
Oct 02, 2009 | Washing Machines
Washing Machines Logo
101 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
