Question about Bosch Classixx WFO 2466 Front Load Washer
Clothes not rung out when cycle finished
Is there a filter that should be cleaned out the drain?
  • portageresor Jan 12, 2009
    thankyou from portageresort , the washer is working great now !!
  • Bosch Master
  • 3,463 Answers
On the majority of bosch washers, the filter is to be found at the front behind a removable plastic panel at the bottom of the washer, remove panel and unscrew filter anti clockwise, clean and refit .
Plz rate my solution.
Thanks.
Posted on Jan 12, 2009
Are there any filters that need cleaning and are there any drainage points to move stagnate water ?
washing water is held in the pipe to the wash tub and in the pump under the machine
try using a straight wash (no clothes) with a high concentration of bleach in the machine or other available steriliser
repeat the rinse cycle after the wash has finished to ensure that any bleach is flushed from the drain pipe.
May 06, 2015 | Washing Machines
Bosch maxx Classic. 7 yo. Washing cycles are not finishing. Timer is showing 1 but does not turn off. Clothes are still quite wet. Have cleaned filter. Anything else I can do?
Looks like the solenoid that controls the drain motor is malfunctioning.
Whenever this happens, the water does not get drained fully and remains in the chamber thus keeping the clothes still wet.
Speak to your local service representative and get the part replaced.
Feb 22, 2015 | Bosch Washing Machines
Start matsui washing machine
Check the washer drain hose for clogs.
Jun 19, 2017 | Washing Machines
Spin cycle
moduel or triack motor controler
Aug 12, 2012 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Hi, i have an AEG Lavamat 1100. Although the machine runs through the spin cycle, and shows the wash cycle as being finished, when i open the door there is still water in the bottom of the machine and the...
Hi bwileman435,
It may not be draining well, because it is dirty, did you clean the Drain Pump filter?
Please follow my below Tip on how to do it:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
Kind Regards d")
* If this solution helped you, please rate it
Aug 05, 2011 | AEG Washing Machines
Clothes have lint on them when the washing cycle is finished is there a lint area i need to clean
The newer Whirlpool top-loaders have lint screens on the inner tub and not accessible. These are supposed to self-clean during the drain cycle. I've heard that liquid fabric softener and detergent build-up may clog the screens when lint sticks to the gooey screens. Try something that will cut the goo like vinegar or ammonia in a small load level without clothes. Without clothes in the washer, that is.
Older Whirlpool washers have lint filters located above the tub, on the lid opening.
Good luck from Detroit, MI.
Jul 18, 2011 | Whirlpool 3.2 cu. ft. Plus Washer
My Whirlpool Duet Sport front loader washing machine will finish washing the close but does not rinse then spin out the water. I have to turn it off turn it back on to spin and drain. I have used the...
Hello & Welcome to FixYa
Error code 5d/Sd means suds have been detected. To solve this problem you have to take the bottom front panel apart and then clean the drain filter pump assembly completely, make sure the washer is unplugged before working on it. Please get back to me if you have any other questions.
Kevin
Jun 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Bad smell in Simpson Eziset 550
pour a few litres of vinegar in the machine on low level of water and do a wash with no clothes in it. should clean tub and drain hose
Sep 06, 2009 | Washing Machines
Washer isn't properly draining in normal wash cycle and start/pause button has to be pushed to restart washer 2-3 times to finish cycle. When cycle finally finishes, a 'drain cycle' has to be run to remove...
remove bottom cover ckd pump for possible restriction..most have acess port on front if not remove hoses also pump impeller may be slipping on shaft or have broken fins
Jul 29, 2008 | GE Washing Machines
Bosch Classixx WFO 2466 Front Load Washer Logo
181 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
