Question about Pride Mobility Products Used Jazzy 1120/2000 Electric Wheelchair
Jazzy 1100 will not charge
Normally when the wheelchair is plugged in it is impossible to operate the joystick. now when it is plugged in the wheel chair operates. why? this must affect the charging ability
dromtonpa
  • 40 Answers
SOURCE: lights just flash on controller and wont move jet 3 wheel chair
Do they flash in series? Like ten flashes then a pause then ten flashes?
Posted on Mar 30, 2009
  • 175 Answers
SOURCE: Jazzy 1113 will not operate!
The click you hear when you activiate the joystick is the electric solenoid on the automatic brakes going on, and then off when you push then release the joystick. This is normal. If it isn't moving, check to see if the free-wheel levers are in gear or in neutral. If you can push the chair, you are in neutral and activating the joystick will just release the brake and run the motors. Turn the two levers to the drive position and then it should take you where you want to go.
You can go to Pride Mobility's website to download an owners manual for your chair here
http://www.pridemobility.com/jazzy/1113ats.asp
Good luck.
Posted on Jul 07, 2009
kmhabdullah
SOURCE: Wiring Diagram Pride Jazzy 1120
mso 9]> Normal 0 false false false MicrosoftInternetExplorer4 mso 9]> mso 10]> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} There are two levers just under the seat at the front. Pull the forward and to right to lock position, which will release the gear so that the wheelchair can be move about without any electric power. Bear in mind though that releases the gear, still too heavy to push as normal wheelchair. Give a go, to find out for yourself.
Posted on Aug 28, 2009
  • 7 Answers
SOURCE: lights just flash on controller and wont move jet 3 wheel chair, it is the secondd row of ligths on the controller, the ones that indicate speed. They are flasing steadily
Check that you don't have the charger cord still connected or the motor disengaged.
Posted on Jun 01, 2010
SOURCE: Jazzy Quantum 600 power wheelchair - On the
THE WHEELCHAIR WILL ONLY TILT IT WILL NOT GO FORWARD OR BACKWARD USING THE JOYSTICK
Posted on Jul 14, 2011
My Dad's 2012 Pride Jazzy Select 6 wheelchair is difficult to maneuver. Since all 4 wheels rotate, backing up straight is impossible. What is my problem?
A light touch on the joystick is first. If it remains difficult then have the joystick reprogrammed. Only a dealer is set up to reprogram a joy stick.
Jan 11, 2014 | Pride Jazzy Select 6 Indoor Power...
How do you charge the Jazzy 600 powerchair?
With the battery charger That was easy wasn't it? No, take the off board charger plug it into the charger port located under the front of the joystick and then plug it into the wall outlet and let er rip overnight The yellow light on the charger should turn green indicating a full charge disconnect from the wall and then unplug from the joystick and you should be all set Hope this helps
Feb 13, 2011 | Pride New Jazzy 600 Power Wheelchair by...
Don't run light go from left to right on a "Jazzy
carly that indication is the charging inhibit mode and the joystick still thinks the charger is still plugged in. Unfortunately there is no quick fix for this and usually requires a joystick or controller replacement. I would have your provider check it for you and maybe try another joystick from another chair to see if that fixes the error if it does then you'll have to replace the joystick. If Medicare paid for your chair then they will pay for most of the replacement cost Hope this helps
Nov 18, 2010 | Pride Jazzy Select 6 Indoor Power...
Jazzy 1121 power chair won't charge when plug in to charge chair can move when you use joystick
you have either bad batteries or a bad charger or the charger might have come unplugged at the controller or power module. When you have the charger plugged in and you turn on the joystick the lights on the joystick should ripple to indicate the charger is plugged in. If you don't see this ripple then either the charger is bad or disconnected. Trace the charger cable from the rear of the chair (you have to remove the seat and shroud to do this) to the front module and make sure that the cable is plugged in. Hope this helps
Oct 22, 2010 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
I AM IN MOROCCO FROM NEW YORK. MY JAZZY 1100 ONLY CHARGES WHEN THE BATTERIES ARE CONNECTED DIRECTLY TO AC AND NOT WITH THE POWER PLUG. WHAT COULD BE THE PROBLEM? THANKS.
hello,if you visit the people who built the wheelchair,Shoprider for example is where i went for 1 solution & there i was able to download a PDF File of the troubleshooter,you should also be able to print it off for your future records,there was so many solutions there,pics of the joystick with different lights lit up and a solution beside each 1.i am disabled myself,i hope i have been of good help Colin.
Jul 08, 2010 | Select Jazzy Used Electric Wheelchair
Jazzy 1113 will not charge, batteries are new, light blinks indicates charging when plugged in but fails to increase usage lights.
Most likely your charge isn't charging properly. You need a multimeter to test the voltage at the joystick. In the 3-pin femal connector measure the voltage across the two horizontal terminals. It should read about 24 volts. Now plug it into the charger and see if the voltage increases, if not, charger needs to be replaced. You can get one that plugs into the joystick on ebay a lot cheaper than going to the mfgr. about $50.00 or so. Even if the lights are blinking, it may not be putting out sufficient voltage to bring the batteries up.
Dec 30, 2009 | Pride Jazzy 1113 ATS Indoor Power...
Good luck.
Jul 05, 2009 | Pride Mobility Products Jazzy 1170 XL Plus
How can you tell when the battery is charging?
Your indication that the internal battery on the joystick is charging IS the red light, which in some configurations
may turn to different colors as charging progressses, but if you note no color change, and/or if when you disconnect the joystick from the power, the light either does not stay on or the stick does not operate independantly of the power source, then the internal battery is defective, has exceeded the number of recharges
cycles and/or is fried.
Buy a new set of batteries for all sticks at the same time and play on.
Apr 17, 2009 | Electric Jazzy 1115 Power Wheelchair
Pride Mobility Products Used Jazzy 1120/2000 Electric Wheelchair Logo
48 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
