How do i turn on wireless conection
I was told the switch that turns on bluetooth also turns on wireless conection for my fujitsu seimens lifebook s6010 but all i get is bluetooth on wireless not conected
If you have vista go on start go on start then connect to it should bring up all ur wireless connections available but if your wireless is not enabled you have to search for your wireless button key on your laptop. mines on F2 but its different for all laptops :)
Posted on Jan 13, 2009
How do i make my bluetooth on
Check the drivers: Go to the control panel/devices. Look for the network adapters line. Right click on one or more lines and do an Update of Drivers.
Feb 20, 2014 | Fujitsu Siemens Fujitsu LifeBook E8420...
I have windows xp,sp3 on a Siemens Fujitsu Lifebook T4010D. First of all, the tablet and the pen didn't work after installing the OS, also with all drivers installed. A few days ago, when xp was...
All of these drivers must be loaded;
LifeBook T4010D Driver Name Version Size (bytes) Audio V 6.14.1.3916 1,926,959 ACPI Device Driver V.1.21 9,437ACPI_Ext Device Driver (For model with Integrated Bluetooth) V.1.0 8,365 Bluetooth Device Driver (For model with Integrated Bluetooth) V.3.01.03F 15,615,696 Chipset V.4.30.1006 2,374,963 Fujitsu HotKey Utility V.2.30 1,119,189 Fujitsu Button Driver V.1.1.0126.2004 273,237 Fujitsu Button Utility V.1.0.0825.2004 976,478 Intellisonic V.2.0.1 4,077,455 LAN V.7.84.0.0 154,167 Modem V.2.1.41 883,675 MultiMedia Bay V.1.0.7.4 4,964,535 Radio Control (For model with Integrated Bluetooth) V.1.0 853,561 Smart Card Slot V.2.7.3.2 3,110,839 Security Panel Application V.1.2 3,653,534 TouchPad Mouse V.5.4.402.9 1,928,173 Touch Panel Driver V.1.03 22,505 TPM (For Model with Integrated Trusted Platform Module) V.1.7 17,542,125 Video V.6.14.10.3741 7,234,518 Wireless LAN Atheros (For 802.11a/b/g) V.3.1.2.21 3,980,525 Wireless LAN Atheros (For 802.11b) V.3.1.2.13
Jun 13, 2017 | Fujitsu Siemens LIFEBOOK T4010D Tablet PC
Lifebook P Series Fijitsu, Model Nuber PH520. Even though there are wireless internet connections available shown on other computers, the Fijitsu cannot find any wireless networks. There are not wireless...
Did you turn off your wireless antenna by accident? The on-off switch for Wireless LAN is located on your computer's right hand side - if that's turned off, both wireless and bluetooth will cease to detect any signals or connections.
Sep 13, 2011 | Fujitsu LIFEBOOK PH520 Ultra Portable...
Laptop fujitsu-siemens S7020D, updated software from windows XP to windows 7. The computer detects wireless networks, but windows does not. Conection through ethernet cable works fine, but no wireless. In...
Do a windows update to recover a more up to date driver for the wireless. If not go to Fujitsu's website and download a windows 7 up to date wireless network driver
May 23, 2011 | Fujitsu Siemens LifeBook S7020D Notebook
How can i turn on bluetooth on a fujitsu b series lifebook
in control panel there should be an option for the bluetooth
Oct 01, 2010 | Fujitsu Siemens Lifebook C2230 Notebook
When I switch my wireless connection sith on at the front of my fujitsu lifebook S7010D the laptop encounters an error and closes down
Use another machine to download latest drivers from the following site: http://support.ts.fujitsu.com/com/support/downloads.html Search for
Device Driver - Intel® PRO/Wireless LAN 2200 BG - LIFEBOOK S7010
or alternatively use the Deskupdate to auto update all drivers for your S7010
Save the zip files to a USB key. Turn the wireless connection off using the switch at the front of your laptop. Unzip and install the new drivers. You should be good to go from here.
Good luck.
Apr 18, 2010 | Fujitsu Siemens Lifebook C2230 Notebook
Fujitsu Seimens T4010D Life Note Book
Have you tried to remove the screw thats connected to the Video connector as well. It is a hexagon shaped screw.
Jun 04, 2009 | Fujitsu Siemens LIFEBOOK T4010D Tablet PC
Not picking up wireless networks
What you need to verify is that the wireless adapter is not disabled or turned off. There is a switch on the front edge of the unit that will turn the adapter off and on.
if you go to http://solutions.us.fujitsu.com/www/content/pdf/SupportGuides/S7210_GSG_B5FJ-5241-01EN-00.pdf you can see the picture of where it is, but from the center on teh front edge, where the latch is, moving to the left, is the mic socket, the headphone socket and them the on/off switch you are looking for. slide it the other way and that should get you back on.
If that doesn't turn is back on, verify in the network connections that the adapter is enabled as well.
May 18, 2009 | Fujitsu Siemens Fujitsu LifeBook S7210...
The wireless network won't connect
Yes, the switch is at the back.
The LifeBook S is equipped with a Wi-Fi (802.11b) receiver; the antennas are inside a long, black plastic panel that runs along the top edge of the lid. The wireless receiver's on/off switch is on the back of the notebook, where the power switch was located in earlier models. Meanwhile, the power switch has moved to a more convenient location on the side of the unit, next to the FireWire port.
Wireless LAN/ Bluetooth ON/OFF Switch
The switch allows you to turn on and off the Wireless LAN/ Bluetooth communications. Slide the switch to the right to turn it on, or slide the switch to the left to turn it off.
Nov 26, 2008 | Intel S6240 Notebook
Televison & Video Logo
88 people viewed this question
Top Televison & Video Experts
Electro Med Services...
