Question about Pioneer XMP3i XM Receiver and MP3 Player with Home Kit
My Pioneer XMP3i goes into demo mode upon startup
My Pioneer XMP3i goes into demo mode within seconds of powering on
5 Suggested Answers
  • 1694 Answers
SOURCE: Pioneer P50A5-K goes to stand by mode
1) Pull chassis---remove power/convergence PCB==the one
with the large heatsink on it.
2) Remove solder from pins of four regulators on heatsink.
3)Clean board/pins w/ toothbrush & alcohol.
4)Re-solder, also solder both Stk's for prevent.
5)Re-assemble
Posted on Oct 12, 2007
SOURCE: pioneer pdp 502mx goes to standby no picture after power on
Contact Pioneer at 1-800-421-1404 about getting an in-home power supply replacement. This is a known issue with some plasma displays. Some of you would experience a loud pop and then the power supply fails. You get a red light below the ON button, when you press on, the red light will turn green for a second and then back to red. The plasma display will not turn on after the power supply fails. Call Pioneer at 1-800-421-1404.
Brought to you by http://abstravel.com and http://reservaciones.com
Posted on Mar 29, 2009
xscrewdriver
  • 246 Answers
SOURCE: goes into demo mode on its own
try to resolder IC5301
here is a picture showed the location of IC5301 on
http://www.myfixtips.com/blog/car-audio-video/pioneer-avh-4000dvd-stuck-on-demo-mode-119.htm
Posted on May 06, 2009
  • 149 Answers
SOURCE: XMp3i is stuck on "powering
Bad TSOP flash chip. No way to fix without disassembling, removing the flash chip, and placing a new flash chip on it. Doing so requires a donor radio (with another issue), and will change your XM Radio ID. You'll also need to have a hot air (or IR) rework station for desoldering the old chip, and a soldering iron for placing the new chip on the radio.
I'd say give pioneer a call since it's a design flaw, and a VERY common issue. My best guess is that it's caused by excessive heat & defective chips.
Posted on Sep 13, 2011
On my pioneer p6500 it is stuck on demo mode how do I turn this off so my radio will work
You should still be able to turn the radio on even if it is in demo mode. If you can''t turn the radio on, you have other problems. Did you try pressing the source button? Most pioneer radios tell you how to turn demo mode off when you first put power to it.
Apr 12, 2012 | Pioneer Car Audio & Video
Tip
How to Turn Off Demo Mode
<span style="font-weight: bold;">Blaupunkt:</span><br /><br /> <ol> <li>Press the (PWR) to turn the unit off.</li> <li>Press the (DIS) and (1) simultaneously for more than 3 seconds to activate the demonstration mode.</li> <li>Press both buttons again from more than 2 seconds to cancel this mode.</li></ol>or<br /> <ol> <li>Try pressing and holding menu for 10 seconds to turn it off.</li></ol><span style="font-weight: bold;">Bose:</span><br /> <ol> <li>Unplug the unit and wait ten seconds.</li> <li>Plug it back it and press repeatedly on the eject button.</li> <li>The demo disc will eject.</li></ol><span style="font-weight: bold;">Clarion:</span><br /> <ol> <li>Press and hold the "D" button to enter the settings menu.</li> <li>Use the next track button until SCRN SVR is displayed, use the rotary knob to select "OFF".</li> <li>Press the "D" button to exit the settings menu. </li></ol><span style="font-weight: bold;">Garmin:</span><br /> <ol> <li>DO NOT DO THIS TO A FUNCTIONING UNIT. Hold down your MENU key, Go to your SYSTEM tab, SYSTEM INFORMATION.</li> <li>When the software version window come up, hit ENTER.</li> <li>Press RANGE UP 3 time, Range DOWN 3 times, RANGE up 1 time, RANGE down 1 time.</li> <li>The system should reset, when asked to use RETAIL mode say NO.</li></ol><span style="font-weight: bold;">JVC:</span><br /> <ol> <li>Hold down the SEL button for 2-3 seconds.</li> <li>Use the &lt;&lt; or &gt;&gt; buttons to find DEMO.</li> <li>Turn the VOLUME knob until it says OFF or DEMO OFF.</li> <li>Press SEL again.</li></ol><span style="font-weight: bold;">Kenwood:</span><br /> <ol> <li>Go into standby mode, hit menu and then press "hold". A menu should pop up.</li> <li>Use knob to select demo.</li> <li>Press in on the knob and hold until it says "demo OFF".</li></ol>or<br /> <ol> <li>Switch to Standby.</li> <li>While holding down 5, press Reset with a paperclip or similar and continue to hold down 5.</li> <li>Demo mode should now be off.</li></ol><span style="font-weight: bold;">Magnavox:</span><br /> <ol> <li>Press and hold the menu button for 5-10 seconds until the normal menu pops up and then go to the section that says demo and turn the demo mode off.<span style="font-weight: bold;"></span></li></ol><span style="font-weight: bold;">Pioneer:</span> <ol> <li>Turn the vehicle's key to the Accessory or ACC position.</li> <li>Press the "Source" button, located on the left-side of the radio, and press the "Off" button that appears on the screen to turn off the unit.</li> <li>Locate the "Volume/Mute" button, located on the left-side of the unit.</li> <li>Press and hold the "Volume/Mute" button until the demo mode turns off.</li></ol>or<br /> <ol> <li>Turn the radio off.</li> <li>Push "Memory 5" or "Memory 6" (depending on your model) for just a second.</li> <li>When you hear a beep, demo mode is off.</li></ol><span style="font-weight: bold;">Pioneer Premier:</span><br /> <ol> <li>With the unit Off and the car ignition On and Running, press button number 5 and release that button to turn off Demo mode.</li></ol><span style="font-weight: bold;">Sharp:</span><br /> <ol> <li>When the unit is in the power stand-by mode (demonstration mode), press the X-BASS/DEMO button.</li> <li>The demonstration mode will be cancelled and the display will disappear.</li></ol><span style="font-weight: bold;">Sony:</span><br /> <ol> <li>Press display twice to turn off Demo mode.</li></ol>or<br /> <ol> <li>Press and hold the select button.</li> <li>Press the select button repeatedly until the desired item appears.</li> <li>Rotate the control dial to select the setting DEMO.</li> <li>Rotate the control dial to select the setting DEMO-OFF.</li> <li>Press and hold the select button.</li></ol><br />or<br /> <ol> <li>Press the STOP and the EJECT buttons simultaneously for 5 seconds.</li> <li>UNLOCKED should now appear in the display and you should be able to eject the disc.</li></ol>If Demo mode comes back on every time you turn off the ignition and back on, you have a wiring problem with your Constant +12 Volt Memory wire.
on Jun 22, 2011 | Audio Players & Recorders
Aug 07, 2011 | Pioneer GEX-INNO1 XM Radio Receiver with...
My strde445 is 10 years old now...whenever I disconnect the AC power cord (even for a dew seconds) the Demo mode is activated...accordingly to the manual the DEMO mode should only be activated if the AC...
They don't actually say it in so many words but the "two week" comment and the Demo Mode startup on even the briefest power loss implies there is a battery or a charged capacitor for memory keep-alive somewhere inside the unit and it is dead or malfunctioning.
Maybe someone can add something more specific to look for. Either way, a tech needs to check it out.
My 8-year old Pioneer loses settings on extended power losses, too. Oh well.
Dec 28, 2010 | Sony STR-DE445 Receiver
STR-DE845 Stuck in Demo mode, tried the power and ...
To get the STR-DE845 ( or STR-DE945 ) out of DEMO MODE - Turn unit on and HOLD POWER BUTTON FOR A FEW SECONDS ...Turn unit off and when you turn it on again it should be reset ...It worked for me.
( Note : You may need to do this procedure before it goes into its actual demonstration of features ... Press and hold the power button immediately when it initially starts scrolling it's DEMONSTRATION MODE message . )
May 12, 2010 | Audio Players & Recorders
How to set demo off in Pioneer AVH 4150 I Wanna conect the two wires ...red and yellow directly to 12 volts permanent but the demo still work and drawn my battery
im not sure what you mean by demo, but the yellow wire goes to the battery, the red one needs to goto a power source that only comes one when you turn on the key to start the car. with both yellow and red connected to the battery, the stereo stays powered up and will drain your battery. the yellow is only to keep your settings so it doent draw very much power from the battery, with the red connected to the battery also, its drawing a full 12 volts thus draining your battery,
Jan 13, 2010 | Car Audio & Video
Can not get the thing out of demo mode read instructions no luck.
Look for the function button. Once found (on unit or remote), turn off the power. press and hold the function button until the units sub menu pops up. use this screen to set time and other options. one of the options is to turn of demo mode. At least that used to be how pioneer did it.
Aug 22, 2009 | Pioneer AVH-P4000DVD Monitor
Stuck in demo mode
to deactive demo mode press menu on the remote...then w/that screen up push the screen mode little gray button at the top of the remote...note that this will not change anything on the screen...i know weird huh...now type in the numbers 9012 you should now be at a new menu the top opption is demo mode...choose it and then choose on or off...good luck i see this i an old post but i hope it helps someone...
Jul 08, 2008 | Sony DHG-HDD250 200-Hours Video Recorder
Display
try checking on the settings maybe you accidenally change the lighting schemes in your unit.
Oct 18, 2007 | Pioneer DEH-P6900UB CD Player
Pioneer XMP3i XM Receiver and MP3 Player with Home Kit Logo
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
