Question about Dell Dimension 2400 PC Desktop
My computer is stuck in power save mode how do i remedy this?
My computer is not reading all the components connected and because of this it is staying in safe mode.
  • 790 Answers
Hello!!
Goto system restore and restore ur PC to earlier date and restart .. it works!!! Thank you!!
Posted on Jan 12, 2009
Stuck in power save mode and can not get it out
I suggest your computer isn't stuck on Power Saver Mode
Your monitor went to Power Saver Mode
Power Saver Mode, Sleep Mode, NO SIGNAL = Same/same,
in this instance.
Why?
Because your computer isn't working.
The two leading causes of desktop computer failure is it is dirty inside, and/or a bad Power Supply.
There are issues with bad capacitors on the motherboard, too.
1) State the computer manufacturer, and model number.
I don't like giving generic one-size-fits-all information.
2) Do you have a multimeter, or access to one?
An economical model can be purchased for as little, as $5 to $12.
Available in a multitude of stores. An auto parts store is but one example.
I have seen them on checkout aisle racks, in major discount stores.
3) Is the computer dirty inside?
4) Is there a working computer that has a Compatible power supply, that you can borrow for a temporary test unit?
Won't hurt the Power Supply, if something is wrong with the computer.
(Unless of course you open it up, and everything is melted together inside the computer! lol!) {DOUBT IT}
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
Relieve your body of Static BEFORE reaching inside your computer.
Computer ON a table, computer unplugged from power, computer case open;
TOUCH an unpainted area, on the metal frame of the open computer case.
This action will relieve your body of Static.
IF you leave your computer in the middle of working on it, be SURE to Touch the metal frame again, upon your return.
OR,
Try what JLTJJ recommends,
http://www.fixya.com/support/t220703-dell_e173fp_stuck_in_power_save_mode
Post back in a Comment.
Regards,
joecoolvette
Jan 04, 2013 | Computers & Internet
Power saving mode
Power saving modes are automatic for some LCD monitors some have setting like after 20 ,30 mins to an hour the computer monitor itself will go into standy saving modes like power led switch indication go to yellow led lighting or the monitor of the lcd screen go blank if ur computer have no pictures for displaying as a screen saver modes.Power saving modes it best for uses if ur computer it on all day long.If u don't touch the mouse or a keyboard the monitor will go in the power saving modes for less electricities consumption for less stress for the monitor electronic components for working to hard for the monitor not to malfuctions sooner or the monitor life cut too short because the computer it on all day.
Oct 12, 2012 | Computers & Internet
Dell Monitor is stuck in power save mode. tried
Hmmm...Stuck in power save. I guess when you push the power button, the monitor says power save, then blanks to power save, no matter if the Computer is on or not.
This means the monitor does not see any signal from the computer. I would suspect the computer first. Try a different monitor (borrow one).
If the size of the monitor picture is too high and the monitor is an older LCD, you may have set the image size too high (1280x1024 will not work with this monitor and it will do this very thing).
A broken or damaged connector cable to the monitor can also cause this. Was the monitor unplugged from the computer just before this problem?
Mar 30, 2010 | Dell E173FP 17" LCD Monitor
stlmeuzyk, Internal "switch-mode-power-supply"/"ccfl-inverter-supply" will probably need to be refurbished (repaired). Use Dell warranty first if valid option! Try monitor on different pc or verify your pc is working properly with old, but known-good monitor. If your E228WFP unit is still not working then you or qualified electronics technician will need to tear-down monitor to evaluate and repair the ac to dc power supply printed circuit board. Before you do anything read my fixya profile to learn flashlight test that every ccfl back-lit lcd monitor owner should know how to do and interpret the results of test. The basic design and operation of your E228WFP isn't any different than any other brand!!! Read the older solutions in my profile and follow the links you find there. Then do additional comment if need more info. Good luck with the repair. 12fixlouie
Mar 25, 2010 | Dell E228WFP LCD Monitor
No sound from zenith dvt412 stuck in bypass mode..how to override?
this is a protection circuit.
When bypass mode then it means that something in the power supply module has failed and the unit then goes into protection mode to protect the board components.
Your surround sound need service from a qualified tech. No other remedy.
Mar 24, 2010 | Zenith DVT412 System
LG Flatron W2252TQ Monitor stuck in digital power saving mode
Mike sounds like the little bard in this monitor where the digital and analog connects to is in malfuction and can be purchased for $30 bucks on ebay. You tryed about everything I had on my list is why I come to this conclusion replacing this board will make the monitor work again if I where you I would investigate that.
thanks I hope this was very Helpful for you!
Dec 13, 2009 | LG W2252TQ Monitor
My Dell monitor is stuck in Power Save Mode. Any
The monitor is not receiving signal from the computer. Verify the computer is on and the monitor input is set to the correct mode or auto. Try another monitor if possible.
Aug 10, 2009 | Computers & Internet
My Gateway 500s monitor is stuck in power save mode
Try tapping the F8 key while booting the computer, you will get the start up menu, choose safe mode, when you log on, go to the display settings, that is right click on the desktop, properties, screen saver, advanced and make sure that hibernation is off, along with turn off disks or whatever , probably see turn off monitor after XX minutes, I make ours 15 minutes (150 computers and servers), I don't let the disks turn off. Choose always on also, not home/office. Try this and see if these settings help.
1r1sh
A+
Net+
MCP
Jan 24, 2009 | Gateway 506GR PC Desktop
LG Flatron monitor
Hi...there,
In power saving mode to preventing further damaged to you monitor. You've got a busted backlight inverter that need to be replaced. Happy Holidays!
Nov 06, 2008 | LG Flatron L1750S 17" LCD Monitor
Computer monitor wont stay on
LMAO it sounds like it is going into power-saving mode because there is (or it -thinks- there is) no signal. Has it always done this? Try punching up the controls when you turn it on and changing its behavior through those menus. Doublecheck the monitor's connection to the computer. Alternately, if it is connected and a display is coming up for those 10 seconds; perhaps just going into sleep mode, with the power LED changing appropriately; you can look up the exact model, and find schematics and previously solved instances of your case.
Even if you can't find those, you could read through some introductory electronic circuit books (and the internals of the monitor...unplug and read the books' safety bits first) and determine what went bad and how to replace that component.
Mar 15, 2008 | Computers & Internet
Dell Dimension 2400 PC Desktop Logo
149 people viewed this question
Alun Cox
