Question about Samsung WB150F
Reset camera to factory settings
Turned power on phone for first time and did not set time and date etc before closing initial set up screen, now cant find where to go to set.
fasacosta
  • 21 Answers
SOURCE: Reset phone to factory
*BEFORE COMPLETING A HARD RESET, BACKUP ANYTHING YOU HAVE STORED ON THE HANDSET, THIS INCLUDES CONTACTS*
1. Select MENU
2. Select Settings
3. Select RESET SETTINGS
4. Select ALL
5. Press OK
6. Press Reset
7. Enter Password (default 00000000)
this was taken from mobilereviews.o2.co.uk
display_flip('id3190', 'divId3190');
Posted on May 02, 2009
Tualiapz
  • 80 Answers
SOURCE: Samsung SGH-D880. Cannot turn off annoying beep
Key tone volume
In Idle mode, press [Volume] to adjust the key tone volume.
You cannot adjust the key tone volume in any other way.....
Please rate this solution
Posted on Jun 09, 2009
LuckyJackson
  • 72 Answers
SOURCE: Setting Date And Time
Change to manual update only and this will allow you to enter correct time and date.
Remember to save and then revert back to automatic...if desired
Posted on Jul 04, 2009
krislil127
  • 55 Answers
SOURCE: Samsung Juke resetting: "Power Cycle" leaves phone useless STILL
the default is always one of these code try them all the last four digits of the phonenumber last programmed in the phone aka your number or 9999,1234,4321,0000,1111 if none of those work you can go the retail store for a flash they hook it to the computer and push software to the phone to correct the issue it takes five mins and its free its a common issue for them to correct if you change your lock code from the default in the future always set up a dummy contact with it in there so that you can easily look it up also please vote for me I'm trying to work my way up to expert level and I cant without your vote please
Posted on Jun 05, 2010
faizkhan989
  • 194 Answers
SOURCE: How to set date and
Go to settings---Date and time--->set your time and date and your time zone.And you can activate automatic update after that.So you no need to set the time again and again
Posted on Oct 14, 2010
Testimonial: "The details helped me to navigate further on the same mode of Date & time setting to get the required solution. This is very helpful. Thanks Fixya"
I would like to know how to reset the factory settings on my Sony DSC-H5 camera. I am having multiple problems that I do not know how to fix.
Select system settings from the menu and find the line "Initialize" - confirm OK. That is all, camera will reset automatically, you will have to set date and time etc.
May 18, 2011 | Sony Cyber-shot DSC-H50 Digital Camera
When eject is pressed, display says locked!
cant open or close dvd player.says locked.can use remote to play etc but cant open to change dvd
Mar 08, 2011 | Panasonic SC-BT200 Home Theater Systems....
I have to reset date time etc everytime i turn camera on
If the Date/Time menu appears when the camera power is turned on, the date battery charge is low and the date and time settings have been lost. Please purchase a lithium coin battery (CR1220) and replace it as follows.
1. Confirm that the camera power is turned off.
2. Slide the memory card slot / battery cover lock and open the cover.
3. Hook your nail onto the date battery holder and lightly pull up.
4. Remove the battery holder in the direction indicated by the arrow. a570isbackupbatremove.gif 5. Remove the battery by pulling it up in the direction indicated by the arrow.
a570isbackupbat.gif 6. Insert a new battery with the (-) side facing up.
7. Replace the battery holder and close the memory card slot / battery cover.
8. When the Date/Time menu appears set the date and time.
Feb 05, 2011 | Canon PowerShot A590 IS Digital Camera
When turned on the screen simply say's ACCESS what can i do to resolve this? Please help!
Try resetting and Power resetting the Camera to resolve the issue.
To reset the Camera to the Factory settings, Initialize it by accessing the Menu items.
Steps to find the "Initialize" option.
HOME/MENU-->Settings-->Main Settings-->Mainsettings1-->Initialize-->OK.
This should reset the Camera to factory defaults.
Also this will resolve all the issues regarding the settings in the Camera.
To Power reset all the power components of the Camera, remove the battery for at least one minute.
If these two steps did not resolve the issue, then Camera may require a service.
Jul 21, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
I have a sony cyber-shot dsc-w55 cammera, and my daughter turned the dial that changes the picture modes to many times and now it only records on every picture mode...any ideas how to reset it?
Based on the information you provided, it seems that the Camera is in Burst or Multi-Burst mode.
You may Initialize the Camera as follows:
Initializing the Camera will reset the settings of the Camera to the factory settings including date and time. It will not delete any data saved in the Camera.
Set the mode Dial on Camera. then, press the Menu button on the Camera. Then, select the SETUP menu and select the SETUP 1 option of the Camera. Then, select the Initialize option to OK.
Good Luck!!!!!!!!!!!
Nov 18, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
No flash and screen flashes "E:91:01"
Hi!
The error E:91 indicates a hardware malfunction in the Camera. In this case, you may try resetting the Camera to the original factory settings.
Follow the steps given below to reset the Camera to the original factory settings:
(a) Press the Menu button to display the menu screen.
(b) After pressing the right arrow on the control button, go to the (setup) setting, then press the right arrow again.
(c) Next, press the left/right/up/down arrow on the control button to select "Setup 1" option.
(d) Then, select the "Initialize" option OK, OK.
(e) Set the clock if date and time screen appear.
(f) Next, turn off the Camera and remove the Battery pack and press and hold the power button for 30 seconds.
(g) Then, reinsert the Battery pack and turn the Camera ON.
Performing all the above steps will reset the Camera to the original factory settings. After resetting the Camera to the original factory settings, please check the operation of the Camera.
If the Camera continues to display the error E:91 then service will be required.
Regards,
Pacific.
Aug 23, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Dropped camera dsc-w120.
Option 1:
Try Initializing the Camera as follow; Initializing the Camera will reset the settings of the Camera to the factory settings including date and time. It will not delete any data saved in the Camera.
Press the Home button on the Camera. Then, select the SETTINGS -> MAIN SETTINGs -> MAIN SETTINGS 1 -> INITIALIZE -> OK.
Option 2:
If issue persists try Power reset the Camera by removing the battery from the Camera and inserting it after 1 minute.
If the issue still persists then Service may requires to resolve it.
Aug 20, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
Won't zoom :(
Option 1:
1. Please press the Menu button on the Camera.
2. Then, select the SETUP menu and select the SETUP 1 option of the Camera.
3. Then, select the Initialize option to OK.
Option 2:
Aug 11, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Htc p3300 not opening
It looks like the phone software had been damaged. Try to do first a factory setting reset from phone setting menu.
If this does not fix it you can try downloading phone software update, probably this will sort it out.
Aug 14, 2008 | HTC P3300 Smartphone
Cant change time on phone
time & date
Your phone needs the time and date for the datebook.
To synchronize the time and date with the network:
Press - > Settings > Initial Setup > Time and Date > Autoupdate
> On
To set the time and date: Press - > Settings > Initial Setup
> Time and Date > time or date.
To choose an analog or digital clock for your home screen,
press - > Settings > Personalize > Home Screen > Clock > Analog or
Digital.
hope this helps
riz.
Nov 04, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Samsung WB150F Logo
123 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
