I have a washer that makes a loud screeching noise
The noise occurs most often at the end of the spin/rinse part of the cycle - when the tub is spinning to a stop.
    Problem Solver:
  • 9 Answers
Flip your washer over and there is a v-belt between the tub and a motor it either needs to tightened or its too tight
Posted on Jan 12, 2009
Mhw2000 rinse and spin cycle not working
It won't spin if it cannot pump out ALL of the water. Check the outlet pump for obstructions and clear. Check pump to see if its pumping.
Jun 23, 2017 | Maytag Neptune Washer
Kenmore 90 plus series washer won't spin, barely agitates, will drain - but makes loud noise
It sounds like the transmission is done. Can't pinpoint what it is exactly, but I would start there.
Aug 21, 2012 | Kenmore Washing Machines
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
Washer makes a loud, pulsing, screeching noise with no spinning
With a manufacturing date of 7/15/97, your washing machine is clearly worn out.
Nov 07, 2017 | Whirlpool Washing Machines
Loud screeching noise when the wash and spin cycle ends
You either have something caught between the tub and basket or a bearing bad.
Eric
Jun 29, 2009 | Maytag Washing Machines
Kenmore Washing Machine 82110 - Loud Noise
could be the brakes, if the loud noise is like a screech probably your brake rotor and lining need replacing.
Mar 31, 2009 | Kenmore 22422 Top Load Washer
Loud noise in final spin cycle
Check the motor on the machine, make sure that the motor is not grinding on itself. If that is not it then check the tub and make sure when that spins that it is not hitting the side of the housing
Feb 08, 2009 | Kenmore 24032\24036 Top Load Washer
Loud clicking/thumping in rinse and spin cycle
It doesn't look like a motor problem !!! It seems like an unbalanced tub issue. The machin has suspension dampers and suspension rods, and it's look like one of them was damaged or "run away" from its location during machin's movement. Goog luck !!
Jun 14, 2006 | GE Profile Prodigy WPSE4200A
Washer makes loud thumping after finished spin cycle
I replaced the drive block and it solved my problem. (thumping noise at the end of spin cycle) Easy repair. Videos on utube show all the steps.
Jun 07, 2006 | Whirlpool LSR7333 Top Load Washer
Washing Machines Logo
216 people viewed this question
Top Washing Machines Experts
