Question about Sharp AF-S120FX Air Conditioner
Sharp AY-A249J Split System Air Conditioner not working, the timer light flashes 5 times and the power light does not flash at all, the remote has limited function, it turns the indoor unit on and off and the louvre opens and closes, the Outdoor unit AE-A249J does not turn it, it does have power as the PCB has a red light on, not flashing just a solid res light is on
Thanks for your replies, I had a Sharp authorised tech look at it and im told it's the indoor circuit board. Im told its a $360 repair job all up, that sure beats replacing the entire ac or putting up with the heat...
Posted on Dec 18, 2012
  • Shane Dec 18, 2012
    and the test mode when pressed only turned on the indoor louvre and turned it off, test run did not function, there was no error messages on the remote at all..
Samsung split system air conditioner. Switch on
Its probably to thermistor it is a black wire with a bulb on one end and the other hooks to the control board I would replace this first if this doesn't fix it probably be the control board.
Sep 10, 2014 | Heating & Cooling
Aircon runs for a few minutes then shuts down and timer light flashes
when we start the AC indoor working and out door unit compressor working but fan motor not working and indoor timer light blinking
Dec 16, 2010 | Mitsubishi MSZ-A24NA Split System Air...
Air Conditioner cannot be turned on when power-light is flashing
The flashing light is a delay timer, usually activated when changing from heating to cooling and visa versa. The fact that the unit can only run from certain times shows that the timer is activated. You need to cancel the timer function on the remote.
Nov 19, 2009 | Heating & Cooling
Samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Feb 11, 2009 | Heating & Cooling
Toyo Aircon. Starts perfectly. Runs for approx 5 min and then the yellow "timer" light starts flashing and machine stops working. Green power light on...yellow timer light flashing. When you switch unit...
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem. Good luck!
Dec 28, 2008 | Toyotomi TIN/TIG-329D Air Conditioner
Sharp AY-A249J air conditioner not cooling
Maybe get an electrician to make sure the voltage is not dropping to low at start up.
Jan 14, 2008 | Sharp AF-S120FX Air Conditioner
Sharp AF-S120FX Air Conditioner Logo
382 people viewed this question
Top Sharp Heating & Cooling Experts
AJMAL KHAN
Tim Whalen
Brandon Berry
Brandon Berry
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
